No HDMI Output
I had installed Android 6.0 running properly but yesterday I changed the TV and did not show nothing on TV, I put the Pine64 where I was continuing, with the same problem. I have reinstalled Android using the app and it still does not work.
Pine64+ 2Gb // Wifi+Bluetooth // ABS Enclosure
So let me get this straight, the installation worked but then you switched TVs and you are no longer seeing anything on the screen, correct ?
If yes, then what is the native resolution of the TV you are currently trying to run the installation on ?
Yes. The Pine64 I have connected on the TV in my room but the other day I connected it to the TV in the dining room, from that moment I did not show image. I have reinstalled Android using the app but it remains the same. Both are 1080p.
Sorry I do not speak English very well.
what is the TV brand and model ?
(05-02-2017, 10:45 AM)Luke Wrote: what is the TV brand and model ?
My room: LG M2794D
Dinning room: LG 47LF65
This morning I found an old MicroSD and I installed Android. The result is that it works fine although slow because the card is old. This afternoon I will buy a UHS-I card.
Edit: With the new card (Sandisk) works well the first time. I've put it in the Pine64 and configured Android. I turned it off to put it in the box and it again fails the HDMI output. The old card always works.
  HDMI CEC on Android fneves 39 84,658 03-10-2018, 06:08 PM
Last Post: lupa18
  Can android 6.0 output spidf or coaxial if a buy the DAC? v1n1c1uS 0 3,348 03-03-2018, 10:40 AM
Last Post: v1n1c1uS
  USB Mic + HDMI Speaker jack_shepherd 0 3,327 11-27-2017, 03:27 AM
Last Post: jack_shepherd
  Android 6.0 (HDMI Video Output) [20170112 v2.0.1] no sound philips 0 3,974 07-23-2017, 11:14 AM
Last Post: philips
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,187 05-05-2017, 01:50 AM
Last Post: Quezbeme
  HDMI Color Inverted on TV Apicalis 2 10,378 03-28-2017, 10:33 AM
Last Post: lyhaku
  Supported 4:3 and 16:10 resolutions over HDMI on Android karlitos 26 55,285 03-06-2017, 03:59 PM
Last Post: dikov
  HDMI not working gubaguba 7 14,534 01-25-2017, 09:45 PM
Last Post: MakerLing81
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 11,240 12-11-2016, 05:57 PM
Last Post: Luke
  Build the Lichee and Android source-"Android 5.1.1 Image (HDMI Video Output) Release SuperX 2 7,116 08-12-2016, 02:00 AM
Last Post: xalius
