USB OTG Boot
#21
(01-22-2016, 08:39 PM)janjwerner Wrote: OTG is available on the upper USB port. I used cheap USB-A to USB-A cable
(http://www.amazon.com/gp/product/B000R4L4CM) and it works just fine.
jjwerner@SantokuVM:~/sunxi-tools$ sudo ./sunxi-fel version AWUSBFEX soc=00001689(unknown) 00000001 ver=0001 44 08 scratchpad=00017e00 00000000 00000000
This is surprise to me, I thought the OTG should be locate on the lower USB port.
#22
@tllim,
I can clearly confirm, you have to use the UPPER USB port on the Pine A64+ board to use FEL. To enter FEL mode you have to boot without a SD card inserted.
Once you booted the Pine into FEL mode you can detect it on your host computer
$ lsusb Bus 001 Device 017: ID 1f3a:efe8
With the latest patch for sunxi-fel from @ssvb, you can easily upload/download data from the boards memory
$ sudo sunxi-fel version AWUSBFEX soc=00001689(A64) 00000001 ver=0001 44 08 scratchpad=00017e00 00000000 00000000
More details can be found at: http://linux-sunxi.org/Pine64#FEL_mode
#23
(01-24-2016, 01:51 PM)Quintus23M Wrote: @tllim,
Noted and thanks, looks like I remember wrongly.
#24
So is there any way to boot from USB?
Raspberry pi 3 supports it for some time now: https://www.raspberrypi.org/blog/pi-3-bo...rage-boot/
#25
Please can someone help me identify the "Upper" and "Lower" usb host receptacles?
eg: which is closer to the board?
BR
Marius
#26
(02-24-2017, 04:15 AM)Learnincurve Wrote: Please can someone help me identify the "Upper" and "Lower" usb host receptacles?
BR
Marius
If I remember correctly from the hardware documentation, the "upper" port is the one farthest from the baseboard.
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,753 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Secure boot & OTP efuse program devangpanchal90 0 4,208 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  boot process for pine a64 awaysu 1 6,690 01-24-2018, 05:09 AM
Last Post: xalius
  Can't boot headless after running update_uboot.sh Borglesnorgle Williams 2 7,315 08-17-2017, 04:08 AM
Last Post: Borglesnorgle Williams
Exclamation Pine A64 Plus Fails to Boot grobbs 35 71,432 06-28-2017, 08:53 AM
Last Post: sarav_sara
  Boot issues: What todo when you muck up your FSTAB file Dagremote 1 6,285 04-16-2017, 10:28 PM
Last Post: pfeerick
Question Pine64 cannot boot jamiechang917 6 15,440 04-16-2017, 10:21 PM
Last Post: pfeerick
  U-Boot for A64 git longsleep 38 104,659 03-21-2017, 01:59 PM
Last Post: longsleep
  OpenWRT supports ARMv8 - arm64, u-boot problem? rgdonato 4 11,197 03-20-2017, 03:59 PM
Last Post: rgdonato
  How to boot alternative kernel image with u-boot? zhouer 3 10,544 06-27-2016, 04:15 AM
Last Post: ssvb
