Success! Pine64 PBX
Hi there,
I've literally just finished working on getting the Pine64 working as a PBX,
I'll be at some point providing an image for anyone who wants to use it.
***UPDATE 11/27/2016***
here's the image, you'll need a 32gig SD Card since I didn't get time to shrink the image, or if anyone wants to by all means.
https://www.dropbox.com/s/nlbng1cn4cle84...ar.gz?dl=0
Console Login / Pass
root
centos
PBX webgui login / pass
pinePBX
pinePBX
(11-20-2016, 08:03 PM)Mach10 Wrote: Hi there,
I am interested in the pbx...
I should have some time today to get the image ready, I've been testing it for a bit now and it works great!
the only issue I'm having right now is to get rid of the free space from the image to make it more compact, since I'm using a 32gig SD card
To shrink an image under Linux :
sudo modprobe loop sudo losetup -f sudo losetup /dev/loop0 myimage.img sudo partprobe /dev/loop0 sudo gparted /dev/loop0 sudo losetup -d /dev/loop0 fdisk -l myimage.img truncate --size=$[(endsect+1)*512] myimage.img
when gparted started, select "partion resize", resize it a bit bigger than space needed, the "apply".
"endsect" should be replace by end-sector display by fdisk.
Thanks for that, I'll update the image next time
holiday palace online
Thanks, Mach10.  Testing now.  Lots of modules to upgrade.
Looking good. Smile
  Programming languages support under PINE64 baryluk 6 20,777 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,715 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,389 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,697 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,164 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,570 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,993 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,662 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,702 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 60,311 10-26-2017, 05:51 PM
Last Post: gregjo
