Need help with boot options
Ive looked around but im not seeing where the options are for me to boot to terminal instead of the gui desktop. Id like to be able to startx into the desktop on occasion but I only use it in terminal most of the time so the desktop isnt needed all the time.
I tried the grub option but Grub doesnt exist with this image so thats no help.
(12-18-2016, 11:56 AM)longsleep Wrote: I decided to roll a new Ubuntu Xenial image which is not using the proposed repository. Starting from 20161218-1, Xenial images now use the latest released rootfs to improve repository compatibility. Eg. this makes it possible again, to install the mate desktop environment (whose dependencies are broken when using the proposed repo like before).
Get 20161218-1 from https://www.stdin.xyz/downloads/people/l...es/ubuntu/
As always, for a list of changes and full details see the first post in this thread.
this is my image at current, using the xfce desktop. ive got ssh installed and im fully updated. I just cant figure out how to change the boot settings.
(01-21-2017, 11:19 PM)Gnx Wrote: Ive looked around but im not seeing where the options are for me to boot to terminal instead of the gui desktop. Id like to be able to startx into the desktop on occasion but I only use it in terminal most of the time so the desktop isnt needed all the time.
If you do not need the gui then use one of our base images. They boot to an frame buffer console ( black screen , which may or may not be used ) and of course you can logon to them with a serial console or via telnet or ssh.
Otherwise, the easiest way to accomplish what you want is to boot to an xdm screen ( chooser ) that allows you to logon and start the desktop;  BUT, do no auto logon !  In this setup the machine boots to a signon panel but DOES NOT start X or the window manager.  Again, you can logon to one of the fbcon(s), serial console, or ssh into the SBC from remote.  This is preferrable IMHO to booting into an fbcon and then running startx.
  Pine 1 will no longer boot (bricked) dstallmo 0 3,436 06-22-2023, 12:22 PM
Last Post: dstallmo
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 5,596 06-10-2019, 12:07 PM
Last Post: pqueiro
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 7,084 06-05-2019, 11:50 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 5,246 03-23-2019, 04:06 AM
Last Post: ktaragorn
  Resize /Boot mmcblk0p1 on SD? chadc 7 19,223 08-24-2018, 01:23 PM
Last Post: goathunter
  Ubuntu boot very slow with wifi driver remainder 9 28,594 08-03-2017, 07:23 AM
Last Post: victorssantos
  straight boot into desktop Ola 2 6,647 08-01-2016, 11:12 PM
Last Post: Ola
  UBUNTU first boot Clouddead 6 12,192 06-29-2016, 12:40 PM
Last Post: pineacle
  in search for the /boot/config-...... file pelgrim 19 35,395 05-31-2016, 07:07 AM
Last Post: pelgrim
  Boot Ubuntu in CLI mode utdrmac 6 14,871 04-24-2016, 03:12 PM
Last Post: androsch
