Pine as a Pi-hole ... Does that make it a PineHole?
Just a quick writeup on how I got Pi-Hole running on a Pine A64 512MB.  I am by no means a professional or expert, just know enough to really mess things up!  If I screwed anything up or am doing anything the hard way, please don't hesitate to correct me!
What is Pi-hole?
pi-hole - A black hole for Internet advertisements (designed for Raspberry Pi)
https://pi-hole.net/
Install Ubuntu following damikeh's How To
Boot it up, personally I would suggest changing the default password and possibly adding another account, and changing the hostname but that's just my personal preference.
Update the repos and check for upgrades by running
sudo apt-get update sudo apt-get upgrade
Then I installed my preferred CLI txt editor (nano) though any should work.  While we are at it, going to install PHP which we will need for Pi-hole Web Interface
sudo apt-get install nano php7.0-cgi php7.0-fpm
This may prompt you asking if you want to continue, respond with Y for yes.
Now we need to setup out network with a static IP address.  I'm using the built in ethernet and am setting my IP to 192.168.1.240 and my router is located at 192.168.1.1 and we will use Googles DNS servers
sudo nano /etc/network/interfaces.d/eth0
By default this will probably look something like
auto eth0 iface eth0 inet dhcp
But we want it to me more like (changing any values as needed for your local network)
auto eth0 iface eth0 inet static address 192.168.1.240 gateway 192.168.1.1 netmask 255.255.255.0 network 192.168.1.0 broadcast 192.168.1.255 dns-nameservers 8.8.8.8 8.8.4.4
Now we need to restart the network so changes take effect, this should be able to be done without restarting the board itself, but none of the usual ways seem to be working for me so we can just reboot the board
sudo reboot
Now once we login we can check and make sure out network settings are working by running ifconfig
tomd@marvin2:~$ ifconfig eth0      Link encap:Ethernet  HWaddr 36:c9:e3:f1:b8:05          inet addr:192.168.1.240  Bcast:192.168.1.255  Mask:255.255.255.0          inet6 addr: fe80::34c9:e3ff:fef1:b805/64 Scope:Link          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1          RX packets:20537 errors:0 dropped:0 overruns:0 frame:0          TX packets:19598 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:1000          RX bytes:6151787 (6.1 MB)  TX bytes:3605516 (3.6 MB)          Interrupt:114 lo        Link encap:Local Loopback          inet addr:127.0.0.1  Mask:255.0.0.0          inet6 addr: ::1/128 Scope:Host          UP LOOPBACK RUNNING  MTU:65536  Metric:1          RX packets:264 errors:0 dropped:0 overruns:0 frame:0          TX packets:264 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:0          RX bytes:19785 (19.7 KB)  TX bytes:19785 (19.7 KB)
If all went well, our inet addr should now match our desire static IP!
Now getting Pi-hole on the rest of the way is easy!
curl -L install.pi-hole.net | bash
It will take a few as it downloads and installs necessary packages, it will get made that PHP5 packages aren't available but we already install PHP7 so it seems to work for me!
Just follow all the prompts, I left the network interface stuff alone since we already configured that and once the installer finishes, it should be ready to go!
Next you'll need to change the DNS server your computer or device is using to the IP you set for your Pi-hole (192.168.1.240 for me).
Then to access the Web Control Interface, point your browser to
http://192.168.1.240/admin/index.php
You should get a page similar to mine
[Image: pinehole.jpg]
Let me know if this helps anybody out!  If you have problems, I'll do my best to help troubleshoot but am no means an expert on this!
I tried this on my pine64. I have issues when devices reach out to pi-hole for dns queries. I mean when i run from the pine-64 it works fine but when I try to access from a different device it doesn't work.
I tried to nslookup and this is what i get:
C:\Users\curiousgally>nslookup -debug www.google.com
DNS request timed out.
timeout was 2 seconds.
timeout (2 secs)
Server: UnKnown
Address: 192.168.1.11
timeout (2 secs)
timeout (2 secs)
timeout (2 secs)
192.168.1.11 is my pine-64 ip address i have used in pi-hole configuration. I have setup dns address in my router to the same. So windows is able to see it as dns end point through router..but not getting any response.
On my pine-64 netstat gives the following:
ubuntu@pine64:~$ netstat -anlp | grep -w LISTEN
(No info could be read for "-p": geteuid()=1000 but you should be root.)
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:53 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:8920 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:8096 0.0.0.0:* LISTEN -
tcp6 0 0 :::80 :::* LISTEN -
tcp6 0 0 :::53 :::* LISTEN -
tcp6 0 0 :::22 :::* LISTEN
Wondering why other machines not getting dns response from pi-hole.
Any help is appreciated.
Thanks.
I finally got this working, I think. But now there is a "dummy" adapter listed. I never heard of them before today so I'm Googleing. Is there anything wrong with leaving it alone? I'm just happy it's working so I'll leave it be if it doesn't lag or anything.
If it ain't broke, fix it until it is.
Try removing dhcpcd5 after the install.  It has been known to cause DNS lookup issues with piHole on Debain based systems.  piHole will run just fine without it except for the DHCP server.  You will have to remove this every time you upgrade piHole too.
sudo apt remove dhcpcd5
(01-05-2017, 08:21 PM)chadbhowell Wrote: Try removing dhcpcd5 after the install...
Just an update, I switched to my odroid-c2 but same setup and removed dhcpcd5 as suggested and that seems to have done the trick.
still had to change "dev" to the actual ip address in the setup wizzard (curl ...) but no dummy adapter now.
thanks for the tips. the official pi-hole installer is making progress every day it seems. was happy to donate toward the project. I have a netgear x10, a $500 router with terrible dhcp support, this pi-hole project is doing a great job filling in the gaps in my network.
Hi, one of the Pi-hole developers here. dhcpcd5 is a vestigial package that we brought over from the Other platform that we started out on. If you set your static IP address the way most of the distributions do, via /etc/network/interfaces, then you can remove the dhcpcd5 client daemon and things should run just as well as stock. If you have any other questions or problems please let me know and well work on getting them solved. We do plan on removing the dhcpcd5 package as a dependency on platforms that don't require it, but there is no firm date for that resolution.
Thanks!
Hey all,
I'm trying to set this up on my pine running longsleep's 16.04 image. It never jumps to the installer.
s@pine64:~$ sudo su root@pine64:/home/s# sudo curl -L install.pi-hole.net | bash  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current                                 Dload  Upload   Total   Spent    Left  Speed  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0 100 42644  100 42644    0     0  65512      0 --:--:-- --:--:-- --:--:--  355k ::: ::: You are root. ::: Verifying free disk space... ::: ::: Updating local cache of available packages...root@pine64:/home/s#
I installed PHP7 per the instructions above but it didn't seem to do anything. Any ideas?
Thanks!
S
Try running:
curl -L install.pi-hole.net | sudo bash -x
That will at least show you the command that the installer script failed out at. It's run as `set -e` so that it will stop on a failure. The place it looks to be failing is at the `apt-get update` process part of the script.
Try running:
Thanks. It does indeed look like it's failing at the update.
sudo curl -L install.pi-hole.net | sudo bash -x [sudo] password for s:  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current                                 Dload  Upload   Total   Spent    Left  Speed  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0+ set -e + tmpLog=/tmp/pihole-install.log + instalLogLoc=/etc/pihole/install.log + setupVars=/etc/pihole/setupVars.conf + lighttpdConfig=/etc/lighttpd/lighttpd.conf + webInterfaceGitUrl=https://github.com/pi-hole/AdminLTE.git + webInterfaceDir=/var/www/html/admin + piholeGitUrl=https://github.com/pi-hole/pi-hole.git + PI_HOLE_LOCAL_REPO=/etc/.pihole + PI_HOLE_FILES=(chronometer list piholeDebug piholeLogFlush setupLCD update version) + useUpdateVars=false + IPV4_ADDRESS= + IPV6_ADDRESS= + QUERY_LOGGING=true ++ stty size ++ echo 24 80 + screen_size='24 80' ++ echo '24 80' ++ awk '{print $1}' + rows=24 ++ echo '24 80' ++ awk '{print $2}' + columns=80 + r=12 + c=40 + r=20 + c=70 + skipSpaceCheck=false + reconfigure=false + runUnattended=false + command -v apt-get + PKG_MANAGER=apt-get + UPDATE_PKG_CACHE='apt-get update' + PKG_INSTALL='apt-get --yes --no-install-recommends install' + PKG_COUNT='apt-get -s -o Debug::NoLocking=true upgrade | grep -c ^Inst || true' + apt-get install --dry-run iproute2 100 42644  100 42644    0     0  22652      0  0:00:01  0:00:01 --:--:-- 44099 + IPROUTE_PKG=iproute2 + apt-get install --dry-run php + phpVer=php + INSTALLER_DEPS=(apt-utils debconf dhcpcd5 git whiptail) + PIHOLE_DEPS=(bc cron curl dnsmasq dnsutils ${IPROUTE_PKG} iputils-ping lighttpd lsof netcat ${phpVer}-common ${phpVer}-cgi sudo unzip wget) + LIGHTTPD_USER=www-data + LIGHTTPD_GROUP=www-data + LIGHTTPD_CFG=lighttpd.conf.debian + DNSMASQ_USER=dnsmasq + [[ '' != true ]] + main + echo ::: ::: + [[ 0 -eq 0 ]] + echo '::: You are root.' ::: You are root. + [[ -f /etc/pihole/setupVars.conf ]] + [[ false == true ]] + verifyFreeDiskSpace + echo '::: Verifying free disk space...' ::: Verifying free disk space... + local required_free_kilobytes=51200 ++ df -Pk ++ grep -m1 '\/$' ++ awk '{print $4}' df: /mnt/usbhdd2: Transport endpoint is not connected + local existing_free_kilobytes=8223152 + [[ 8223152 =~ ^([0-9])+$ ]] + [[ 8223152 -lt 51200 ]] + update_pacakge_cache + echo ::: ::: + echo -n '::: Updating local cache of available packages...' ::: Updating local cache of available packages...+ apt-get update
  Pine 1 will no longer boot (bricked) dstallmo 0 3,436 06-22-2023, 12:22 PM
Last Post: dstallmo
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,812 08-30-2020, 10:35 AM
Last Post: jrronimo
  Successful build on arm64 pine a64 1GB on armbian alladinrouteme 1 6,963 09-23-2019, 03:30 AM
Last Post: cr2016
  Pine hangs up on boot if I add my exFAT USB drive to /etc/fstab pqueiro 0 5,596 06-10-2019, 12:07 PM
Last Post: pqueiro
  Pine Board using linux stuck during boot sequence ktaragorn 0 5,246 03-23-2019, 04:06 AM
Last Post: ktaragorn
  PINE A64 upgrade to 18.04 possible? RandomUser324 4 13,967 11-29-2018, 11:46 PM
  Xenial Minimal Image (PINE A64(+)) 0.5.5-65 pineadmin 0 5,650 06-15-2017, 12:37 AM
Last Post: pineadmin
  Xenial Minimal Image (PINE A64(+)) 0.5.2-59 pineadmin 0 5,334 05-25-2017, 09:27 AM
  Unable to start Pine Topgun505 16 31,819 11-13-2016, 12:01 AM
Last Post: Gnx
  Problem with Pine honkimonk1 1 5,503 10-11-2016, 09:03 AM
Last Post: Luke
