Is it a Pine64 that is inside the RetroEngine Sigma?
(01-02-2017, 02:16 PM)tllim Wrote: I votes for try out Ayufan Android 6.x build.
OK thanks, I will then start with Android. I just hope it doesn't commit suicide after a few weeks, like Android is usually doing.
(01-02-2017, 07:16 AM)Squirrel61 Wrote: Considering emulation, I see a number of possible solutions.
a) Install Android on the board and then install emulators from the Play Store. There are countless. Is there any Android version that is best? I've seen the "regular" Android 5.x, but also 6.x beta and even 7.x beta.
b) Install RemixOS, which seems to be a good alternative to Android, offering the same possibilities. Or am I mistaken here?
c) Install a Linux distribution and then port RetroPie, RetroArch, EmulationStation or something similar to it. This seems the most flexible and compatible solution, except it looks like a whole lot of pioneering needs to be done.
I can't speak for Linux as I've never tried it on my A64, but I'm happy with my Android emulation setup. I'm using ayufan's 5.1.1 non-TV build, which is rooted, you can install opengapps on (using FlashFire) and then works more reliably than Pine's own 5.1 release. Then get RetroArch from the Play store, and you're away.
Depending on what you want to emulate there's also the question of what controller to use. I got myself a Probox2 Remote+ for Christmas and am pretty satisfied with it for general airmouse use as well as a controller for 4 button games (at a stretch it can be used for 6 button ones, if you remap the volume keys), it's just a shame the mic doesn't want to work with non-probox systems.
Thanks a lot, that is really useful information! I don't care experimenting a little and finding out things by myself, but I wanted to avoid wasting lots of time on something that will never work nicely.
So Android is the way to go! The Probox remote makes me think of the Wiimote, of which I have a few, so I think I will try linking one to the A64. I don't know however if it can also act as an airmouse, but I will find out!
Question External storage problem for pine64 Dani6102 3 7,651 07-26-2023, 10:57 AM
  Pine64 as wireless audio device S265 3 9,849 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 4,870 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 46,269 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 5,917 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 5,833 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 8,134 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 6,210 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 9,398 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 13,412 05-03-2019, 02:48 PM
Last Post: Mendota
