LCD touch panel emits low power
I think that my LCD Touch Panel is defective (I hope I'm wrong).
First of all I've to say that I owe 2 Micro SD cards. The first one has the "Lollipop Beta 2 (LCD Version)", and the second one has the "Lollipop Beta 2 (HDMI Version)" both downloaded from the website.
Here is an image that shows how my LCD Touch Panel is connected to the board. (My mobile camera is ashame).
[Image: IMG_20161230_095834.jpg]
As you can see it's all correctly connected with all the pins down... The thing is that I've tried both HDMI Img (on my living room TV) and LCD Img on my LCD Touch Panel. Here i'll show u the results.
HDMI (living room TV):
[Image: IMG_20161230_003130.jpg]
LCD Touch Panel:
[Image: IMG_20161230_095802.jpg]
As you can see the image works in both screens, but the LCD one can barely be read. I can assure you that i got to the "desktop" on both applications and that the Touch Panel works (I know it isn't connected in the posted screens, but I did test it before), but I don't get why it emits that low brightness (I've turned the Android brightness to max already and it's not that).
I would appreciate any advice, cause I don't know if I am doing anything wrong.
From your photo, looks like the LCD panel backlight didn't lighted up. For installation procedure, here is the link: http://files.pine64.org/doc/guide/PINE64..._Guide.pdf
Still not working, I followed your installation procedure which is exactly as what I tried many times before.
(01-01-2017, 11:29 PM)tllim Wrote: From your photo, looks like the LCD panel backlight didn't lighted up. For installation procedure, here is the link: http://files.pine64.org/doc/guide/PINE64..._Guide.pdf
Already tried it, can it be something else?
If install properly, no sure whether the backlight circuit on Pine A64 board or LCD panel itself having issue. Please contact Pine64 support, http://support.pine64.org, and issue a support ticket.
  7 inch LCD touch panel is upside down? joshpl 2 5,299 12-07-2023, 06:18 AM
Last Post: stormwyrm
  LCD panel Driver IC MIPIguy 1 5,662 08-12-2017, 05:04 PM
  I2C Touch Panel mbt28 0 3,624 06-12-2017, 11:32 AM
Last Post: mbt28
  Touch screen support shariq_2001 14 32,936 12-07-2016, 07:47 AM
Last Post: Luke
  LCD Touch Screen Problem. Gavin 8 16,332 11-27-2016, 10:26 PM
Last Post: michaelquezon
  Lcd panel's pixels are not square bokeer 0 3,184 11-22-2016, 08:08 PM
Last Post: bokeer
  LCD Panel not working at all treize 7 16,882 09-19-2016, 10:24 PM
Last Post: billjon
  LCD Panel Connected but does not work maipercaso 1 5,122 08-20-2016, 08:14 PM
Last Post: MarkHaysHarris777
Photo Running Out Of Options LCD Panel Just Not Working AUDIOTEK 4 9,041 07-27-2016, 06:34 PM
Last Post: AUDIOTEK
  LCD Pannel working... Touch screen NOT working?? Why Chopshop13 3 9,123 06-13-2016, 08:24 AM
Last Post: PapaStahl
