Found this fully working RASPBIAN Image that boots to desktop
You need to edit a file you can find on the sdcard by putting it in the card reader on your laptop. There is a configure.txt where you can edit. My wifi worked from the beginning.
can you copy and paste your config file here for all to see and compare to? thanks.
(12-27-2016, 07:10 PM)speedro86 Wrote: You need to edit a file you can find on the sdcard by putting it in the card reader on your laptop. There is a configure.txt where you can edit. My wifi worked from the beginning.
well can you say what did you config in this file? i have the build in bluetooth/wifi expand card but it says network interfaces unavailable.
Whooooooo, it seems to be a great secret, he don't want to tell us......hehehehe   Cool Tongue
i think he is referring to config.txt in bpi-boot folder
read some details here,
https://www.raspberrypi.org/documentatio...fig-txt.md
Why cant he just share what his config file says?!
Thanks for the link dkryder, a lot more than 'some details' there  Smile
Speedro86 - Are you using WiFi with the WiFi/BT module or are you using a WiFi dongle?
#19
This image is not worth the time i spend trying on it.
Wifi NOT working, Sound NOT working, BT NOT working.
Grapics extremly sloooow, try to drag a window around.
Forget it.
#20
yes the config.txt in the bpi-boot folder. If you cant get things working, I dont know what to say, other than editing this file for hdmi, everything else worked first time(for me). Here is the file exactly as I have it:
# For more options and information see
# http://www.raspberrypi.org/documentation...fig-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
  Gentoo Linux test image xalius 23 73,339 01-28-2019, 11:05 PM
Last Post: necrose99
  eta linux image?? firosiro 1 6,752 08-03-2017, 10:05 PM
Last Post: pfeerick
  Possible to get 4K resolution on Linux desktop? tycoonbob 6 17,547 01-12-2017, 01:28 AM
Last Post: swinging
  Pine64 as a viable desktop replacement ? here are my thoughts! Luke 11 27,341 01-06-2017, 04:49 AM
Last Post: dkryder
Big Grin Docker image based on gentoo crossdev arm64 and distcc uulaoba 0 4,614 11-19-2016, 09:34 AM
Last Post: uulaoba
  Ready-to-use image with no graphic interface and SSH on babolivier 9 18,498 10-08-2016, 06:19 PM
Last Post: pfeerick
  Remote Desktop Support? Rochambeaux 20 46,664 10-01-2016, 05:08 PM
Last Post: HayseedGeek
  How to make multicast working on ubuntu and debian brengthdom 3 10,674 09-18-2016, 02:05 PM
Last Post: brengthdom
  Creating a complete linux image yuvgin 2 8,111 09-14-2016, 10:00 AM
Last Post: tkaiser
  How to boot alternative kernel image with u-boot? zhouer 3 10,558 06-27-2016, 04:15 AM
Last Post: ssvb
