Questions about GPIO
(02-16-2016, 03:15 PM)limitlesscodes Wrote: Alright, so I kind of figured out pin assignment using the GPIO image on the wiki. I still would like to know what PC, PD, PH, etc. means and when to use them vs. others. Also I would like to know if there is any better way of exporting the pins through C rather than doing something like:
//near beginning of file system("echo 71 > /sys/class/gpio/export")
and
//near end of file system("echo 71 > /sys/class/gpio/unexport")
You can fopen the file and write the string "71" to it like your first post.  That's essentially what the echo is doing.
and
You are right! I knew I was missing something :p thanks.
  GPIO specifications in device tree ramstadt 1 5,656 01-16-2019, 03:17 PM
Last Post: ramstadt
  +PINEBOOK Q4OS Pinebook Questions StewB 0 3,712 08-24-2017, 03:53 PM
Last Post: StewB
  Low-Level-GPIO-Access Thoams131 2 6,909 01-11-2017, 02:54 PM
Last Post: Thoams131
Question PPS-GPIO Sebastian 11 27,011 07-12-2016, 07:25 PM
  C#.NET / Mono GPIO library? abutler77 0 4,375 06-12-2016, 10:34 PM
Last Post: abutler77
  Lazarus and GPIO gbestwick 0 3,595 05-22-2016, 08:51 PM
Last Post: gbestwick
  GPIO javascript library. neeeds 1 5,692 02-19-2016, 11:31 PM
Last Post: limitlesscodes
