Camera
I can see that Pine64 supports himax 5mp camera module. Is it possible to have more megapixels camera option? I saw on himax website they have a 13mp image sensor too (HMD131) can Pine64 support it? I am not able to figure out whats the exact difference between HM5065 and HMD131 as I am not an electronics guy!
(01-13-2016, 09:50 AM)Sasank Wrote: I can see that Pine64 supports himax 5mp camera module. Is it possible to have more megapixels camera option? I saw on himax website they have a 13mp image sensor too (HMD131) can Pine64 support it? I am not able to figure out whats the exact difference between HM5065 and HMD131 as I am not an electronics guy!
Currently the SoC chip use in Pine A64 accept the camera resolution up to 5Mpixel, we are currently explore whether able to go higher.
... TL
... TL
Thank you for your reply. I was referring to this 13mp sensor http://www.himax.com.tw/products/cmos-im...rs/hmd131/
... TL
We need to explore whether able to support more than 5Mpixel possibility before able to goes for another step of identify camera sensor such as Himax HMD131.
What is the status of the camera module, when will it be available?
And price?
According to https://www.kickstarter.com/projects/pin...ts/1469130, the camera is 5 megapixels, and it will be $15.99 for kickstarter backers during the initial backerkit stage and $21.99 normal retail price. I assume at this point, it may be Android only for the initial release. Hopefully Linux will get support for it in time.
Could I use an USB camera on android as standard main camera?
For the camera module to work, it requires Linux kernel support.
If it is indeed the HM5065 (5MP), then a google search shows some kernel files.
For someone that want to try something cheaper, there is a 0.5MP (half megapixel) camera module at
http://www.cnx-software.com/2015/09/26/h...th-motion/
If you search around, there are not many options for camera modules (CSI interface).
Hi, does anyone know if we can attach more than 1 camera module into PINE64 ?
MC
(02-22-2016, 08:55 PM)mengchoontan Wrote: Hi, does anyone know if we can attach more than 1 camera module into PINE64 ?
MC
Well, there is only one camera port on the Pine (top left), so unless that port can be divided between multiple cameras, I would probably say only one camera can be attached via the camera port.
  Anyone get the camera to work yet? Havensal 16 41,205 09-13-2022, 03:31 AM
Last Post: harryaxe31
  camera port details? gourmand007 6 21,770 03-07-2021, 05:29 PM
Last Post: DippingMyToesIn
  About the camera robopo 11 31,740 03-06-2021, 12:28 AM
  CSI / Camera Module Compatibility? vade 8 25,618 04-03-2020, 05:39 AM
Last Post: Ellesar Dragon
  13MP Camera cable extension saviod 2 8,874 06-21-2019, 06:05 AM
Last Post: saviod
  Himax 5 Megapixel Camera Module cannot fit into 7″ LCD Touch Screen Panel themyshop 3 11,509 05-10-2018, 04:28 PM
  Webcam vs camera module on pine64+ fkpkot 4 15,381 02-27-2017, 03:57 PM
Last Post: MarkHaysHarris777
  Camera is working on Linux @lex 50 138,380 10-26-2016, 03:17 PM
Last Post: @lex
  camera module and lcd integration jodybrown99 5 15,273 10-11-2016, 11:35 AM
Last Post: hikaricore
