External DAC
#71
@mrv,
Any chance to know what you did try/test?  Wink
Michelangelo, from Volumio did a good job,  it works!!! but only via lan. Wifi for me is not working
Pine64 2G complete with wifi module + usb DAC (HiFimeDIY Sabre USB DAC ES9023 96Khz/24bit - USB receiver: SA9023)
http://hifimediy.com/sabre-dac-uae23
Wink
(11-19-2016, 02:29 AM)aarturo Wrote: Michelangelo, from Volumio did a good job,  it works!!! but only via lan. Wifi for me is not working
Sorry, it was me that did the work and created the image. Michelangelo published it with a few enhancements Tongue
and yes, wifi is still a pain.
I have not figured out yet why the wifi/bt module initially works in ap mode but as soon as switched into wlan 'client', nothing....
-Gé-
-Gé-
# gkkpch sorry for the mistake. Anyway good job!!!!!
Volumio in ok, but i still prefer Runeaudio (Rasp pi B + hifiberry dac).
Can you do the same job with Runeaudio distro?
Ciao
Hi! Thank you very much for the volumio for pine. I was hopping for something like that for the begging of pine project. Now I do not need some Hat DAC from Pine guys even if they make it someday. I am using Cambridge Audio DAC Magic Plus as external DAC and I have WD World 2TB NAS drive on my home LAN network. It works jut fine without any problems. It was a long wait an I was thinking to go back to Rpi. Hoping to see final version on Volumio site with regular updates! Regars!
(11-19-2016, 05:06 PM)aarturo Wrote: .......
No, can't do that. I'm a Volumio team member.
Ask Frank, he's the only one left contributing to Runeaudio and therefore your only hope.
-Gé-
-Gé-
Thank for your support  pine64 , i been waiting pine64 DAC board 1 year Big Grin
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
(11-18-2016, 08:42 PM)cr2016 Wrote: @mrv,
Yes, just the basics
1) Does it boot
2) Do I have ethernet issues
3) Are the controls working as normal (e.g can I see it as DLNA renderer, is the webUI available and responsive)
4) Is music playing, from the library and from webradio
5) Can I add sources, does it connect normally
6) Can I control it, can adjust volume, play on the various sources (headphone, hdmi etc)
Have not tried to add an USB stick for wifi
possible issue I had was that the Factory reset was hanging. Seems that sdcard was corrupt or something. Did not repeat, so i'm not sure if it was due to a bug, filesystem full or sd corruption.
Anyway, I found it much more responsive than my RPI (v1b) volumio setup. (which is no surprise)
So now finally I have some good use of my 2nd pine board. (I consider pine useless for all things that have hdmi out as it is not working on any of my monitors or tv screens in a stable way. If the ethernet speed is fine, headless use seems okay with the pines)
@mrv,
And... which DAC did you use?  Wink
@mrv: i will have a look at the factory reset issue. It should not be any different from other boards, but better check.
-Gé-
  Popping on SPDIF - External DAC mjgoode 3 15,169 05-14-2019, 11:12 AM
Last Post: TrisWood
