Android kernel booting
Hi Drag00n and Patrick,
I will email the latest boot.img (with Gbit Ethernet working) to both of you tomorrow. If other folks interest, we can post at Wiki page.
Regards,
TL Lim
Thanks!
Another changes worth mentioning?
(02-15-2016, 07:06 AM)tllim Wrote: Hi Drag00n and Patrick,
Regards,
TL Lim
I'm also interested in latest boot.img.
Could you please post the latest boot.img at Wiki page?
Thanks.
Regards,
TL Lim
Thanks.
I will post on wiki once latest boot.img provided by engineer on today.
Regards,
TL Lim
Thanks.
Hi folks,
You can download the latest boot.img from this link: https://app.box.com/s/bprrzom6tkviewlupw9327gvs0s219dv
The same image will post on wiki later today.
Regards,
TL Lim
Regards,
TL Lim
Thanks.
Hi folks,
Regards,
TL Lim
The boot image already posted on the wiki page at http://wiki.pine64.org/index.php/Pine_A6...SP_Related
You'll need more than this boot.img file to get Gb ethernet working.  I had to program the whole android image with phoenixcard and reload ubuntu onto the first partition to get the Gb ethernet working with linux; overwriting just the boot.img wasn't enough.  Probably a DTB and/or FEX change in addition to the kernel update.
Anyway, here are preliminary numbers on the Gb ethernet throughput.  The Pine64 board was hardwired to a 4-core, 2GHz Intel Core i7 laptop running Ubuntu 14.04.3 with a Realtek RTL8169 NIC.  Tests were performed with iperf on quiescent systems:
            1 thread       4 threads
inbound     880Mb/sec      940Mb/sec
outbound    400Mb/sec      850Mb/sec
These numbers are quite good for an ARM SoC. The FreeScale iMX6 line maxes out at around 1/2 these values (due to a bug in the chip itself), and the Cubietruck (Allwinner A20) runs at around 500-600Mb/sec.
Edit: changed above values from Gb to Mb (oops!)
@TL Lim will you release the changes AS source? Best would be a pull request to https://github.com/longsleep/linux-pine6...ne64-hacks :-)
Thanks, Simon
#19
(02-17-2016, 01:11 AM)longsleep Wrote: @TL Lim will you release the changes AS source? Best would be a pull request to https://github.com/longsleep/linux-pine6...ne64-hacks :-)
Thanks, Simon
The only change is the Gigabit support.
#20
Thanks, Simon
Would be nice to get this change into longsleeps kernel sources. The network performance there really needs a boost. Using the binary only kernel isn't a practical option.
I managed to get Docker support into this kernel and I'm in contact with Kai Kreuzer discussing the best way how to integrate OpenHAB.
Cheers,
Uli
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,280 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,841 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,300 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 121,175 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,216 06-21-2018, 05:45 PM
Last Post: evilbunny
  Kernel for A64 git longsleep 179 428,605 03-25-2018, 03:25 PM
Last Post: Luke
  Gentoo for pine64 - longsleep kernel incoherent 0 5,580 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 5,084 07-13-2017, 08:38 PM
Last Post: cztian
  Mainline kernel [Solved] jeroen79 11 29,483 02-08-2017, 06:19 AM
Last Post: umiddelb
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 7,865 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
