I dropped my Pine64
Hi.
Sorry, for the price of the thing, I decided to put it to rest and wait for the other one to come in.
Thanks everyone for pitching in.
Best regards.
Marc "Duke Justice" Arbour
See my Pine64+ 2GB Poor Man's Heatsink Setup
so, I take it that it didn't work ? sorry :/
[edit] I just looked at the pictures in your sig. Did you have one of those large heatsinks attached when the board fell ? If so, then perhaps it damaged a trace / shorted something out as it moved or slipped ?
yeah, rats.
(11-07-2016, 02:27 PM)Luke Wrote: so, I take it that it didn't work ? sorry :/
Yes it did.
I don't think it did as it's spaced with a copper spacer and it all was squishy in CPU thermal paste. And I did inspect the board thoroughly.
It served its time well. Always the best leaving us first. Couldn't a banana pi m3 have died in its place?
Thanks to you all.
Best regards.
you could try a powered hub in addition to usb power just for chuckles.
(11-07-2016, 03:00 PM)dkryder Wrote: you could try a powered hub in addition to usb power just for chuckles.
You forgot to mention the half-dozen resistors tacked across the 3.3v and 5v rpi/euler power pins to ensure maximum smoke/bang and ensure minimum disappointment Wink (look up BigClive's resistor roulette if you don't get it!)
hahahahahaha
Big Clive's Resistor Routlette !
Thanks to you all...
Ended up buying 3 more Pine64's.
  1. to replace the one I just dropped/broke.
  2. to replace the one I am using to replace the one I dropped, in case I drop it too.
  3. to make sure I still have on in case I drop them both.
Now, i DO wish I make the Nov 11th shipment.
Have a great evening.
Best regards.
  Pine64 Suddenly Turnoff with Lcd mix359 4 16,087 07-08-2021, 08:50 AM
Last Post: e-minguez
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 6,201 01-24-2019, 07:00 AM
Last Post: ecolezen
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 6,177 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Does Pine64+ have an internal hardware watchdog ? rahlquist 8 25,004 04-26-2018, 06:27 PM
Last Post: pfeerick
  Using the pine64 with AVR - HDMI pass-through Moshe.Vazan 4 10,203 01-02-2017, 02:58 PM
Last Post: Moshe.Vazan
  pine64+ cad files danlcarr 1 5,994 08-31-2016, 08:26 AM
Last Post: martinayotte
  Pine64+: 3 working, 1 shows nothing on tv zumtra 1 6,883 07-30-2016, 05:47 PM
  mounting root filesystem via NFS on pine64+ issue martind1983 2 7,550 07-29-2016, 06:37 AM
Last Post: martind1983
  Cannot get PINE64 boards to boot andymelton 13 28,347 07-06-2016, 09:20 AM
Last Post: montero65
  Pine64 2G never up w/ strange Chinese words + w/o S/N tankie64 1 5,883 05-13-2016, 04:36 PM
