Kernel for A64 git
This gmac kernel makes a HUGE difference.
I now have a stable GbE connection. Cpu maxes out during nfs transfers instead of sitting there waiting ...
...still not anywhere near GbE speeds but its stable at least .... I'll do some more checks tomorrow
thanks in advance !
quick edit ... some results ... http://forum.pine64.org/showthread.php?t...6#pid21886
(11-01-2016, 01:29 PM)waldo Wrote: This gmac kernel makes a HUGE difference.
thanks in advance !
Is it both TX and RX? RX remains really bad on my board... Sad
Just to give some feedback, the 3.10.104-1-pine64gmac-longsleep works for me, I see consistent 100MBit (I don't have anything on my network to measure above that) download speed from my ISP where I just got around 68MBit with the unpatched version. No other regression so far, but I will let it run for a while and see what happens.
I ported the music player platform Volumio 2 to Pine64 and used patch details overlayfs.v18-3.10-rc7.patch  from https://github.com/adilinden/overlayfs-patches to create the kernel prerequisites for overlayfs.
Patching was straight forward, I have done it before for a few other sbc's like sparkySBC (allo), Odroid C2 (Hardkernel).
I now have 2 options:
- maintain our own (volumio) kernel and update with longsleep's kernel changes as long as mainline is no option
- longsleep can be persuaded to add the overlayfs patches to the BSP kernel and we can pull from there.
@longsleep: would it be possible to get these patches into your kernel?
Not sure if tllim informed you about this...
-Gé-
(10-29-2016, 07:09 AM)longsleep Wrote: I just released a new Kernel build line "pine64gmac" which has a possible fix for the Ethernet Gigabit issue which happens on some boards. The fix is based on a patch provided by tllim (thanks!).
For now consider this a test release and you can switch to the pine64gmac Kernel line easily with
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_kernel.sh) latest gmac
You can switch back to the normal Kernel line with
bash <(curl -s https://raw.githubusercontent.com/longsleep/build-pine64-image/master/simpleimage/platform-scripts/pine64_update_kernel.sh) latest default
(assume the Network still works with the gmac Kernel Smile).
To see what changed:
https://github.com/longsleep/linux-pine6...gmactxonly
If feedback is good, this fix will go into the default Kernel. So let me know how it goes.
To check if the fix is applied on boot:
root@pine64:~# dmesg|grep 'init ephy' [   16.070919] init ephy for pine64
Sorry, bad news, board still doesn't work in GbE even with the new kernel. Its better than before, getting at least some throughput (about 10mbits) but thats still much worse than FastEthernet (94mbits) and ways too slow for GbE.  Huh
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
Androsch -   Have you swapped out your power supply with something different, and capable of supplying higher current?
I've got 5 pine64's  (2Gb + GbE)  and all of them work great at GbE speeds - the only times they had networking issues was when I was using inferior power supplies.   The ones I was originally using were rated for 5V2A and yet when I replaced them with a higher-quality supply, my networking issues went away.
(11-17-2016, 01:15 PM)ak_hepcat Wrote:
(11-10-2016, 04:21 AM)androsch Wrote: Sorry, bad news, board still doesn't work in GbE even with the new kernel. Its better than before, getting at least some throughput (about 10mbits) but thats still much worse than FastEthernet (94mbits) and ways too slow for GbE.  Huh
Hi, just tried with a new 5V/3A supply using longsleeps new gmac-kernel and now its at least about
[ ID] Interval           Transfer     Bandwidth       Retr [  4]   0.00-30.00  sec   331 MBytes  92.4 Mbits/sec  3584             sender [  4]   0.00-30.00  sec   330 MBytes  92.4 Mbits/sec                  receiver [  6]   0.00-30.00  sec   305 MBytes  85.4 Mbits/sec  3292             sender [  6]   0.00-30.00  sec   305 MBytes  85.4 Mbits/sec                  receiver [  8]   0.00-30.00  sec   333 MBytes  93.1 Mbits/sec  3467             sender [  8]   0.00-30.00  sec   333 MBytes  93.1 Mbits/sec                  receiver [ 10]   0.00-30.00  sec   300 MBytes  83.8 Mbits/sec  3235             sender [ 10]   0.00-30.00  sec   300 MBytes  83.8 Mbits/sec                  receiver [SUM]   0.00-30.00  sec  1.24 GBytes   355 Mbits/sec  13578             sender [SUM]   0.00-30.00  sec  1.24 GBytes   355 Mbits/sec                  receiver
Its still not too good and many retries, but at least more than the old FastEthernet speed Undecided
OK, also added longsleeps network-script.sh to /etc/rc.local and set the governor to performance like tkaiser already suggested (still using gmac-kernel from longsleep, with normal kernel its unusable in GbE), so i now have about 500 mbits with still many retries, but i can live with that at the moment. Its much better than FastEthernet now and using this board as server for minecraft is more limitated by cpu than network now.
Thanks everybody for suggestions and support!
~cool, androsch; excellent report.
(11-18-2016, 12:52 AM)androsch Wrote: OK, also added longsleeps network-script.sh to /etc/rc.local and set the governor to performance like tkaiser already suggested (still using gmac-kernel from longsleep, with normal kernel its unusable in GbE), so i now have about 500 mbits with still many retries, but i can live with that at the moment. Its much better than FastEthernet now and using this board as server for minecraft is more limitated by cpu than network now.
Next up, you can apply some local QoS to your interfaces, and see if that doesn't help you out a little.
This might get you started pretty quickly:   https://github.com/akhepcat/qdisc
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,726 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,941 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,397 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 124,654 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,558 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,667 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 5,180 07-13-2017, 08:38 PM
Last Post: cztian
  Mainline kernel [Solved] jeroen79 11 30,051 02-08-2017, 06:19 AM
Last Post: umiddelb
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 8,071 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
  Jackd triggers kernel warning cztian 0 5,257 09-03-2016, 08:16 AM
Last Post: cztian
