Linux Support
#41
(11-01-2016, 07:48 PM)modsbyus Wrote: What should I download on their site? Just the 64bit image? I am using VirtualBox.
Sent from my SM-G930V using Tapatalk
http://docs.armbian.com/Developer-Guide_...eparation/
In the requirements I downloaded 64bit 16.04 ubuntu. Then when doing the system setup I installed mate desktop and ssh server when prompted for additional stuff
Sent from my Nexus 6P using Tapatalk
I was using ubuntu 16.10, but I am installing 16.04 per their guide now. I'll let you know how it goes tomorrow. Time for bed now Smile
Sorry again folks, I had to modify my changes so that they would be appropriate for inclusion in the main armbian repository which means my repo is in a little bit of a flux at the moment.
The build currently generated from it does not function so please hold off for a moment.
I'm hoping to have my changes squared away in a couple of hours.
The version I downloaded yesterday is working pretty good. can't seem to find a good working virtual keyboard but its working after all
Ok, repo should be good to go again.
Now there will be a switch: pine64_lcd=on/off in the /boot/armbianEnv.txt file
The default values is off so make sure you change it.
(11-02-2016, 07:12 AM)Ghelorn Wrote: The version I downloaded yesterday is working pretty good. can't seem to find a good working virtual keyboard but its working after all
Have you tried Onboard?
sudo apt-get install onboard
I haven't finished compiling the img yet, so I haven't tried it.
Great news! The support is now merged into the armbian main repos so just building from there will include support for LCD/Touchpanel
(11-02-2016, 09:39 PM)vintagewaffle Wrote: Great news! The support is now merged into the armbian main repos so just building from there will include support for LCD/Touchpanel
Thanks for your work on this! I have been waiting for this since I supported the Pine.
Onboard fails to start and florence crashes when you press any key on it.
The only one I have been able to get to work just from repos is xvkbd.
(11-02-2016, 10:14 PM)modsbyus Wrote: Thanks for your work on this! I have been waiting for this since I supported the Pine.
No problem, I'm just happy I could get it to work. Everything was already out there it just needed someone to actually put it all together.
Information LCD Support on Linux pfeerick 8 28,228 02-08-2021, 03:30 PM
Last Post: HBeserra
  [EXPERIMENTAL] Linux on the LCD screen Terra854 24 58,668 07-21-2017, 07:41 AM
Last Post: apple4ever
  Touch screen support shariq_2001 14 32,943 12-07-2016, 07:47 AM
Last Post: Luke
Photo Playbox LCD on Linux MackPI 10 25,202 10-19-2016, 07:49 AM
Last Post: Zoidiano0
  Received a bad LCD, can't get support. bryanlyon 3 8,466 09-27-2016, 03:55 AM
Last Post: Luke
  Touchscreen support? NoahJ 12 26,102 07-09-2016, 12:01 PM
Last Post: yodermk
  LVDS support Flood_of_SYNs 2 10,068 12-22-2015, 05:08 PM
Last Post: balornt
