Can I plug in the Pine with touchscreen to My tv via HDMI?
I  have connected my Pine to touchscreen using Android and it works fine. My question is if I can connect my Pine to my tv to see it on a bigger screen when I am at home and want to watch Kodi for example?  Or do I need to buy another board strictly dedicated to my TV? Any help is appreciated thanks.
(10-15-2016, 05:38 PM)acv2boriqua Wrote: I  have connected my Pine to touchscreen using Android and it works fine. My question is if I can connect my Pine to my tv to see it on a bigger screen when I am at home and want to watch Kodi for example?  Or do I need to buy another board strictly dedicated to my TV? Any help is appreciated thanks.
You can only use one video output at a time.  So, to use the same board for LCD and hdmi, you will need two SD card ( one for Android LCD , one for hdmi ) .
The boards are so inexpensive that you can probably afford to own more than one of them... I have three atm.  Dedicate one to the TV ( I have dedicated one to my playdesk ) and dedicate one to your playbox. Solved.
Thanks for the info!
You can use the LCD image with HDMI only after the system boots. If HDMI is connected during boot, it will hang.
  Can I use HDMI + USB touch screen? Voyager 9 27,014 01-19-2017, 09:09 AM
Last Post: biobill
  Pine's HDMI-VGA adapter SkimMilk 4 11,588 01-18-2017, 05:40 PM
Last Post: wpersin
  MAC address of Pine wifi and Bluetooth addon clawinus 2 9,141 11-07-2016, 09:14 PM
Last Post: pfeerick
  Xiaomi TV BT remote on Pine? kjez 1 5,013 06-10-2016, 05:34 PM
  HDMI --> VGA Adapter Compatibility marco97pa 18 35,991 05-08-2016, 04:05 AM
Last Post: frewind
  Different ways to control Pine. jfox815 4 12,455 04-16-2016, 09:28 PM
Last Post: thatnovaguy
