[09/10/2016] [ALPHA] Fedora Images for Pine64
[Image: SZFGBOM.png]
Changelog
9/10/16 (Fedora 24) (ALPHA RELEASE)
- Initial release
- Kernel based on 3.10.102-3-pine64-longsleep-98
- WARNING: As this is a alpha release, things might not work as expected. Use it at your own risk.
Downloads
Direct download from the project page
Login details
Username: pine64
Password: pine64linux
Known bugs and Workarounds
Do note that you will not be able to use a desktop environment on Fedora at the moment as once you install it, the screen will freeze out on boot (you can still be able to ssh into the Pine if this happens). I am currently working on a fix for it, but at the moment, please do not install a GUI.
If you can come out with a fix for any problems whether or not they are listed here or if you found new bugs, post them on this thread so that I will be able to patch the image and the entire community will benefit.
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
(10-09-2016, 03:12 AM)Terra854 Wrote: [Image: SZFGBOM.png]
Changelog
- Initial release
Downloads
Login details
Username: pine64
Thanks, I will try out.
Great, I will give it try with my Pine64.
Besides, with updates from Armbian 5.20 to 5.22 fails, I don't have a working system for Pine64 anyway.
Thanks,
Nice work. I'm playing around with it now.
Things I've noticed:
*) The ethernet interface takes about two minutes after booting to become active/usable. My first order of business was to install 'net-tools' so I could more easily look at network stuff (i.e. ifconfig).
*) I poked around and located some Pine64-related scripts in: /usr/local/sbin. I have successfully used resize_rootfs.sh to be able to access the full size of my SD card.
*) The update scripts (pine64_update_uboot.sh and pine64_update_kernel.sh) both report: Version latest not found.
Edit: Correcting the date/time (with ntpdate) has made the update_kernel script work. I also had to install gpg. I'm now on a newer kernel than was distributed with this image.
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 10,663 10-02-2020, 11:38 AM
Last Post: mathiraj
  Programming languages support under PINE64 baryluk 6 20,779 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,715 10-19-2019, 05:13 AM
Last Post: roel
  +PINEBOOK Fedora 30 on Pinebook sdgathman 0 6,527 08-14-2019, 11:41 AM
Last Post: sdgathman
  Volumio for PINE64 Released mikelangeloz 11 39,396 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,698 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,164 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,576 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,993 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,663 06-21-2018, 05:45 PM
Last Post: evilbunny
