Chromium?
#41
With some help from Fourdee - I got Chromium up and running on DietPI on Pine64 :
http://dietpi.com/phpbb/viewtopic.php?f=...2993#p2984
I sorta got it running on the Longsleep Debian XFCE build - but I was unable to connect to my Google account, and forget about running more than two tabs at once...
Works pretty much flawlessly following Fourdee's info at the DietPI forum... which is based mostly on stuff that's been posted in this thread... but new locations for the arm64 deb files...
Note: The linux build essentials posts from the tail of this thread have been preserved and moved to "LInux Build Essentials Research" tid=2265.
Look forward to anyone interested in continuing that discussion there; The Chromium thread may continue... carry on !
marcus
Gdebi installed ok - but come up against a dependency problemo.
Using Debian Mate image here
- any ideas?
debian@pine64:~/Downloads$ sudo gdebi chro*
Reading package lists... Done
Building dependency tree
Reading state information... Done
Building data structures... Done
This package is uninstallable
Dependency is not satisfiable: libstdc++6 (>= 5.2)
(04-25-2016, 07:29 PM)baryluk Wrote: I applied some of the Riku's patches and fixed one minor issue with some syscalls in the sandbox, and was able to build chromium 50.
You still need --disable-seccomp-filter-sandbox
Packages:
https://drive.google.com/folderview?id=0...aring#list
You only really need chromium_50.0.2661.75-2_arm64.deb (about 40MB).
Hello I am using Mate, after update, upgrade and dist-upgrade, I cannot install this ver50 anymore, So I install 53 instead, but the page cannot load anything at all, even the settings page, completely useless, how to fix?
Packages:
this one helped!
http://forum.pine64.org/showthread.php?t...6#pid16066
(04-23-2016, 02:32 PM)baryluk Wrote: It works!
[Image: mpnBz7w.png]
(High CPU usage is mostly due to the fact that MATE system monitor is consuming quiet a bit of cpu for drawing stuff. When using top, chromium is using few % when idle basically)
Remember to run with:
$ chromium --disable-seccomp-filter-sandbox
(probably due to the bug in the old kernel, seccomp and seccomp filter is in 3.10.65 according to /proc/config.gz)
Packages:
http://repo.linaro.org/ubuntu/linaro-ove...m-browser/
Debian bug: https://bugs.debian.org/cgi-bin/bugrepor...799939#113
There should also be 49.0 in debian experimental, didn't checked it yet.
Hi there I'm new in this forum. I'm struggling trying to make chromium work like it should do but the procedure you describe let the browsing safety "uncovered" and, since this is the only device I've to study at the moment I'd prefer to solve the problem in different ways. I get the error with seccomp and sandbox, is there anyone that knows how could I fix it? thank you so much for your attention
Packages:
The chromium is now available in Debian in testing and unstable: https://packages.debian.org/search?keywo...ection=all
Just run apt-get update && apt-get install chromium from root.
(01-02-2017, 12:25 PM)baryluk Wrote: The chromium is now available in Debian in testing and unstable: https://packages.debian.org/search?keywo...ection=all
I just did it:
sudo apt-get install chromium-browser
when I ran chromium, it shows the popular "Aw, snap!" display, no matter what menu I click, i.e. settings, about, all the same...
Now will try to install from linaro repo .......
(02-07-2017, 08:06 AM)victagayun Wrote: I just did it:
then I remove it:
ubuntu@pine64:~$ sudo apt-get --remove purge chrom*
then download as zip those files in google drive and unzip, here are the file :
ubuntu@pine64:/media/ubuntu/03_32GB$ ls camera chromedriver_50.0.2661.75-2_arm64.deb chromedriver-dbgsym_50.0.2661.75-2_arm64.deb chromium_50.0.2661.75-2_arm64.deb chromium-browser_50.0.2661.75-2_arm64.changes chromium-dbgsym_50.0.2661.75-2_arm64.deb chromium-l10n_50.0.2661.75-2_all.deb drive-download-20170207T231214Z.zip iBoy.2017.1080p.NF.WEBRip.DD5.1.HEVC.x265.mkv wbfs.torrent ubuntu@pine64:/media/ubuntu/03_32GB$
 then did
ubuntu@pine64:/media/ubuntu/03_32GB$ sudo gdebi chro*
 I got this :
Reading package lists... Done Building dependency tree         Reading state information... Done Reading state information... Done This package is uninstallable Dependency is not satisfiable: chromium (= 50.0.2661.75-2)
any ideas?
ubuntu@pine64:/media/ubuntu/03_32GB/53$ ls chromedriver_53.0.2785.143-1.1linarostretch1_arm64.deb chromedriver-dbgsym_53.0.2785.143-1.1linarostretch1_arm64.deb chromium_53.0.2785.143-1.1linarostretch1_arm64.deb chromium-browser_53.0.2785.143-1.1linarostretch1_arm64.log.gz chromium-browser_53.0.2785.143-1.1linarostretch1.debian.tar.xz chromium-browser_53.0.2785.143.orig.tar.xz chromium-dbgsym_53.0.2785.143-1.1linarostretch1_arm64.deb chromium-l10n_53.0.2785.143-1.1linarostretch1_all.deb ubuntu@pine64:/media/ubuntu/03_32GB/53$ sudo gdebi chro* Reading package lists... Done Building dependency tree         Reading state information... Done Reading state information... Done This package is uninstallable Dependency is not satisfiable: chromium (= 53.0.2785.143-1.1linarostretch1) ubuntu@pine64:/media/ubuntu/03_32GB/53$ sudo apt install -f Reading package lists... Done Building dependency tree       Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. ubuntu@pine64:/media/ubuntu/03_32GB/53$
I got it!
run chrome, chromium, chromium-browser
ubuntu@pine64:~$ chrome bash: chrome: command not found ubuntu@pine64:~$ chromium bash: chromium: command not found ubuntu@pine64:~$ chromium-browser [1:1:0208/211749:FATAL:sandbox_seccomp_bpf_linux.cc(146)] Check failed: 1 == (*__errno_location ()) (1 vs. 9) #0 0x007fb7858e50 base::debug::StackTrace::StackTrace() #1 0x007fb78753ac logging::LogMessage::~LogMessage() #2 0x007fb5d9073c <unknown> #3 0x007fb5d8f8f4 <unknown> #4 0x007fb5d8fd6c <unknown> #5 0x007fb5e73770 content::RendererMainPlatformDelegate::EnableSandbox() #6 0x007fb5e73588 <unknown> #7 0x007fb588e124 <unknown> #8 0x007fb588e698 <unknown> #9 0x007fb588d818 content::ContentMain() #10 0x0055644c4290 ChromeMain #11 0x007fb09a78a0 __libc_start_main Received signal 6 #0 0x007fb7858e50 base::debug::StackTrace::StackTrace() #1 0x007fb785929c <unknown> #2 0x007fb7a45510 ([vdso]+0x50f) #3 0x007fb09b9528 gsignal [end of stack trace] ubuntu@pine64:~$
add filter box
ubuntu@pine64:~$ chromium-browser --disable-seccomp-filter-sandbox
Has anyone tried to compile chromium 55+ yet?
I was hoping the same netflix pi fix would potentially work on the Pine. Rpi is on chromium 56 as seen below:
https://www.raspberrypi.org/forums/viewt...3&t=176402
I didnt want to try it without getting some insight here before hand.
  Midori and Chromium (52) Cannot open display DuMees 3 9,713 01-12-2017, 02:36 AM
Last Post: DuMees
