Yocto for Pine64
Hi all,
just release an initial version of a yocto meta layer for pine64. Currently it was tested with my board which is a 1MB board. It currently just supports pine64 plus but it shouldn't be hard to have it working for Pine64 with 512MB.
You can find the meta layer and instructions here: https://github.com/mont3z/meta-pine64
Chees,
Montez
(09-15-2016, 08:44 AM)mont3z Wrote: It currently just supports pine64 plus but it shouldn't be hard to have it working for Pine64 with 512MB.
All that's needed is to pick the right device tree file in u-boot (important to get Ethernet working since different PHYs and access methods are used). In case you rely on longsleep's u-boot branch it might already work (detection works based on available DRAM size and in case it's 512MB the other .dts will be chosen). As a reference the commit that made this work: https://github.com/longsleep/u-boot-pine...b4e12d2dd0
Hi tkaiser, thx. I'm gonna check this.
(09-15-2016, 09:27 AM)mont3z Wrote: I'm gonna check this.
Great! I would believe especially the little Pine64 could benefit from full Yocto support.
I believe so too.  I use Yocto linux on my Intel Edison(s) and really like it; they are headless, but powerful IoT servers and Yocto is solid as the rock of Gibralter...
We use Yacto on our meters, I would be a big fan of a solid build for the Pine. Go team!
Sent from my iPhone using Tapatalk
  Programming languages support under PINE64 baryluk 6 20,690 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,664 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,186 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,669 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,130 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,216 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,981 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,600 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,687 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 60,118 10-26-2017, 05:51 PM
Last Post: gregjo
