connect lipo battery to euler bus
(09-08-2016, 11:04 PM)pfeerick Wrote: Also, I don't think the charge current is anywhere as high as you think it is... the AXP209 is capable of charge currents of up to 1.8A, but I haven't seen the pine64 report anything above 600ma charge current, so it certainly isn't configured that way on mine, and I haven't touched the AXP registers. The AXP209 defaults to 500mA or 1200mA (automatic determination based on input supply stability so it looks like it must be limiting to 500mA ... but then again, the register defaults also indicate the charge LED should work out of the box, so some register settings certainly appear to have been changed to less than optimal settings!
This seems to be another inconsistency between these boards.  But , if my 8000 mah batt is being fully charged in 3.5 hours (that is consistent between the two machines) then the current has to be somewhere around 2.3 amps.
I think the charge times are definitely affected by what else is plugged in, whether the hdmi is running, and other factors... but, also I think that the machines are not consistent in this regard either; I'm hearing all sorts of conflicting statements (and I only have three boards to test on).
The other thing that may be a factor is that most 'automatic' charge controllers are not dumb... they don't just charge at their set current... but ramp it up based on how the battery voltage responds... if the voltage rises too quickly... it drops the current as it senses it's charging the battery too hard.
Since you're using the pine64 batteries with thermistors and I'm not, in the absence of any other data, I'd be thinking it's the lack of thermistor that is altering things... although from how the datasheet reads, connecting the temp sensor pin to GND should disable the temperature sense part of the charge algorithm.
Anyway, my battery is charging again after a full cycle down to flat with a shutdown script triggering at 5% remaning capacity, and on the recharge it is back up to 3.7v, 6% capacity charging at 415ma (so says the pine) with total load of 580ma on the 5v side.
Edit: I had to go back and edit my previous post, as I was reading the datasheet for the PMIC on the CHIP, not the pine64... and unfortunately the chips PMIC has some more sane defaults... like the charge led being controlled by the charger by default, whereas the 803 on the pine64 defaults to register (so software) control :-(
(09-09-2016, 05:51 AM)MarkHaysHarris777 Wrote:
(09-08-2016, 11:04 PM)pfeerick Wrote: Also, I don't think the charge current is anywhere as high as you think it is... the AXP209 AXP803 is capable of charge currents of up to 2.8A, but I haven't seen the pine64 report anything above 600ma charge current, so it certainly isn't configured that way on mine, and I haven't touched the AXP registers. The AXP209 AXP803 defaults to 1200mA charge current,  ... but then again, the register defaults also indicate the charge LED should work out of the box, so some register settings certainly appear to have been changed to less than optimal settings!
I've been able to get the a current draw of 1.2A @ 5v,  with the pine64 *off* and powered via euler (vs microUSB boot surge of 1.22A, charging at 640ma @ 5.2v). The datasheet indicates the default charge setting for the PMIC is 1.2A, so depending on how they mean supply current or charge current at that point, it seems right, or is a bit inefficient with the voltage drop for the battery.  However it only runs at this rate for about 2 minutes and then shuts down completely. I can get it to pull approximately 1.52A on bootup, then it falls back to 603-670ma @ 5v  when idle, and the PMIC register at /sys/devices/platform/axp81x_board/axp81x_regs is claiming the PMIC has overheated, which is nonsense, as it has a heatsink (which is cool to touch) and has a 120mm fan over the board keeping the board cold to touch.
So there is definitely  something odd going on here... can you confirm if this is with the pine64 on or off, how it's powered, and which you're using? I'm starting to wonder if the PMIC on this board is a bit flaky... as there doesn't seem to be any good reason for it to be running so. Then again, datasheet isn't the best on some points - it doesn't detail what the charge 'smarts' of the PMIC is, if this one has any at all. It seems to indicate it only follows a CC/CV profile, with over-voltage/over-temp protection.
Did anyone manage to set PMIC register (32?) for the charge LED? Could it been set via /proc or /sys?
Gesendet von meinem SM-T235 mit Tapatalk
(09-10-2016, 03:39 AM)pfeerick Wrote: So there is definitely  something odd going on here... can you confirm if this is with the pine64 on or off, how it's powered, and which you're using? I'm starting to wonder if the PMIC on this board is a bit flaky... as there doesn't seem to be any good reason for it to be running so. Then again, datasheet isn't the best on some points - it doesn't detail what the charge 'smarts' of the PMIC is, if this one has any at all. It seems to indicate it only follows a CC/CV profile, with over-voltage/over-temp protection.
hi, I am presently running my Android batt to the ground ... then I'll start a change cycle and see what I can see by looking in sysfs.
I can do that same thing for my debian build too, as far as that goes.
I was wondering where I could find a suitable battery for the pine64 on ebay or amazon. Does anyone have references to provide me? By the way, is it possible to recharge it directly on the pine64 by using the micro usb cable?
Thanks for your replies
I'm sorry, I'll repeat the question: Can you confirm if this is with the pine64 on or off, how it's powered, and which distro you're using?
I gather from you you just said that this might be on Android... is that correct? This would explain a lot of things (specifically, why registers might have been reconfigured from their defaults).
I have three systems on battery:  (1) debian mate  (2) ubuntu mate  (3)  Android 7 ; special hardware
This is with the Pine board 'ON';  specifically, I have never charged my pine boards with them off.  To say is concisely, they have always been 'ON'. All of my boards are powered with 2.5A adapters @ 5v with passive low-pass filtering and connected exclusively via the euler bus at pin(4 5v+) and pin(6 ground).
Again my Android system is consistent with my debian and ubuntu system(s). They are using essentially the same kernel and almost the same hardware.  Although my special hardware is configured differently, all of the components are the same. All three systems use the same PMIC; AXP803
Later tonight I will be able to put them into charge cycle (they're still running all day on batt) and then I can see what the sysfs system says about currents and voltate; also temps.
(09-10-2016, 06:52 PM)MarkHaysHarris777 Wrote: I have three systems on battery:  (1) debian mate  (2) ubuntu mate  (3)  Android 7 ; special hardware
Thanks for that... I predominately use debian so wanted to check if you were on the same distro, otherwise that could be the source.
After a reboot with the microSD card removed, and a complete power down, the battery finally charged at 1.2A and followed the proper CC -> CV profile at the higher current, so the PMIC doesn't appear to be faulty... microUSB this time. Euler power with a 5A 5V supply or microUSB with a 4A 5V supply didn't make any difference. Without changing the software, only factor seems to be letting the PMIC power up with defaults. So the next thing to work out then is if the charge current registers on the PMIC are indeed being changed from the default 1.2A charge current, and what is changing them.
So, a few days later, and a few battery cycles and tests later... and this is what I have concluded so far.
  1. The APX803 PMIC is lying to me! The cheek of it! The lithium fuel gauge calibration is way out of wack, and doesn't appear to be self-calibrating. It said the battery had 5% to go once the battery had been running for around 12 hours, yet, when I instead tracked the battery voltage, and triggered a shutdown at 3.10v (0.2v above the emergency shutdown of the PMIC, 0.1v above the generally accepted flat voltage of 3.7v nominal lithium batteries), it ran for approximately 26 hours, and said the battery was at 0 for the extra 14 hours of runtime I got out of it!
  2. I don't seem to be able to get anything above 1.2A of charge current, when on reliable 5.25v 5A power via USB or euler. If I boot android, debian linux or ubuntu linux, the charge current is clamped down further to around 410ma. If I power cycle the pine64 without a microSD, it will charge the battery at 1.2A with the pine64 in the 'off' state (as the PMIC only needs 'AC' power connected for it to do its job), so the PMIC is not 'faulty', and from the timing of the drop in charge current, it appears that it is something in the kernel image, not uboot, that is changing the register values.
  3. Changing the default CPU governor from the default used on the debian pine64.pro image of ondemand (or performance if you run the tune_network script at some point) to interactive will (unsurprisingly) improve battery runtime and also drop the CPU temperature a few degrees. Yes, I know there is the conservative and even powersave governors, but interactive gives the best networking performance from the tests on my setup so is a good setting to default to anyway, and it means the CPU clocks low if there is no load, but can still kick up to full speed if it is needed. powersave if it is implemented slowly would keep the CPU locked low at 480MHz... which seems a waste of a perfectly good 1.2GHz CPU Big Grin
When the battery was trained down to 3%:
           CPU              Battery Time        Freq Cores Temp  Volt Curr Capacity 15:15:35: 1152MHz   4    49  4.11   -469   100 15:15:40: 1152MHz   4    49  4.12   -452   100 15:16:00: 1152MHz   4    49  4.13   -365   100 15:17:20: 1152MHz   4    49  4.12   -375   100 15:17:30: 1152MHz   4    49  4.13   -367   100 15:18:00: 1152MHz   4    49  4.12   -376   100 15:19:00: 1152MHz   4    48  4.12   -369    99 15:24:11: 1152MHz   4    48  4.11   -441    99 15:24:21: 1152MHz   4    48  4.12   -373    99 15:24:41: 1152MHz   4    48  4.11   -442    99 15:25:22:  480MHz   4    46  4.12   -311    99 15:25:32:  480MHz   4    46  4.11   -384    99 15:25:42:  480MHz   4    46  4.12   -308    99 15:26:32:  480MHz   4    45  4.11   -381    99 15:26:42:  480MHz   4    45  4.12   -308    99 15:27:02:  480MHz   4    45  4.12   -311    98 15:36:25:  480MHz   4    44  4.12   -307    97 15:37:15:  480MHz   4    44  4.11   -312    97 15:37:25:  480MHz   4    44  4.12   -307    97 15:37:55:  480MHz   4    44  4.11   -307    97 15:45:43:  480MHz   4    43  4.11   -307    96 15:48:53:  480MHz   4    43  4.10   -318    96 15:49:04:  480MHz   4    44  4.11   -304    96 15:51:04:  480MHz   4    44  4.10   -305    96 15:51:34:  480MHz   4    43  4.11   -304    96 15:51:45:  480MHz   4    44  4.10   -305    96 15:55:16:  480MHz   4    43  4.10   -305    95 16:03:58:  480MHz   4    43  4.09   -308    95 16:04:18:  480MHz   4    43  4.10   -305    95 16:04:28:  480MHz   4    43  4.09   -307    95 16:04:38:  480MHz   4    43  4.09   -306    94 16:05:19:  480MHz   4    43  4.08   -382    94 16:05:39:  480MHz   4    43  4.09   -305    94 16:06:09:  480MHz   4    43  4.08   -378    94 16:06:19:  480MHz   4    44  4.09   -306    94 16:14:01:  480MHz   4    43  4.09   -310    93 16:16:12:  480MHz   4    43  4.08   -311    93 16:23:24:  480MHz   4    44  4.08   -307    92 16:27:45:  480MHz   4    44  4.06   -379    92 16:29:35:  480MHz   4    44  4.07   -311    92 16:29:46:  480MHz   4    44  4.06   -382    92 16:31:46:  480MHz   4    44  4.06   -381    91 16:33:07:  480MHz   4    43  4.07   -308    91 16:38:08:  480MHz   4    43  4.06   -310    91 16:38:18:  480MHz   4    43  4.07   -307    91 16:38:28:  480MHz   4    44  4.06   -309    91 16:40:49:  480MHz   4    43  4.06   -311    90 16:42:50:  480MHz   4    44  4.05   -383    90 16:43:30:  480MHz   4    44  4.06   -310    90 16:50:12:  480MHz   4    43  4.06   -313    89 16:51:22:  480MHz   4    43  4.05   -311    89 16:51:42:  480MHz   4    43  4.06   -308    89 16:51:52:  480MHz   4    43  4.05   -311    89 16:52:13:  480MHz   4    43  4.06   -308    89 16:52:23:  480MHz   4    43  4.05   -312    89 16:59:35:  480MHz   4    43  4.05   -310    88 17:05:56:  480MHz   4    44  4.04   -312    88 17:06:07:  480MHz   4    43  4.05   -308    88 17:06:27:  480MHz   4    43  4.04   -311    88 17:06:32:  480MHz   4    44  4.05   -307    88 17:07:22:  480MHz   4    43  4.04   -308    88 17:08:53:  480MHz   4    43  4.04   -308    87 17:17:55:  480MHz   4    44  4.04   -309    86 17:21:16:  480MHz   4    44  4.03   -311    86 17:27:18:  480MHz   4    43  4.03   -309    85 17:33:09:  480MHz   4    44  4.01   -423    85 17:33:20:  480MHz   4    44  4.03   -309    85 17:35:30:  480MHz   4    44  4.02   -310    85 17:36:31:  480MHz   4    43  4.02   -310    84 17:45:53:  480MHz   4    43  4.02   -311    83 17:49:44:  480MHz   4    44  4.01   -314    83 17:49:54:  480MHz   4    43  4.02   -310    83 17:50:05:  480MHz   4    43  4.01   -315    83 17:50:15:  480MHz   4    44  4.02   -309    83 17:50:35:  480MHz   4    43  4.01   -310    83 17:55:16:  480MHz   4    43  4.01   -309    82 18:02:58:  480MHz   4    43  4.00   -311    82 18:04:29:  480MHz   4    43  4.00   -312    81 18:10:51:  480MHz   4    43  3.97   -468    81 18:11:01:  480MHz   4    43  3.99   -386    81 18:11:11:  480MHz   4    43  4.00   -309    81 18:13:22:  480MHz   4    44  3.99   -312    81 18:13:42:  480MHz   4    44  3.99   -312    80 18:23:04:  480MHz   4    43  3.99   -312    79 18:27:16:  480MHz   4    44  3.98   -314    79 18:27:26:  480MHz   4    44  3.99   -313    79 18:27:56:  480MHz   4    44  3.98   -314    79 18:32:17:  480MHz   4    43  3.98   -316    78 18:36:03:  480MHz   4    44  3.97   -385    78 18:36:13:  480MHz   4    44  3.98   -311    78 18:41:35:  480MHz   4    44  3.98   -311    77 18:43:25:  480MHz   4    44  3.97   -312    77 18:44:36:  480MHz   4    44  3.96   -385    77 18:44:46:  480MHz   4    44  3.97   -312    77 18:44:56:  480MHz   4    43  3.96   -384    77 18:45:06:  480MHz   4    44  3.97   -312    77 18:45:16:  480MHz   4    44  3.96   -385    77 18:45:26:  480MHz   4    44  3.97   -312    77 18:50:38:  480MHz   4    43  3.97   -314    76 18:59:00:  480MHz   4    44  3.96   -312    76 18:59:20:  480MHz   4    44  3.97   -312    76 18:59:31:  480MHz   4    44  3.96   -312    76 18:59:51:  480MHz   4    44  3.96   -312    75 19:09:13:  480MHz   4    43  3.96   -316    74 19:16:15:  480MHz   4    43  3.95   -312    74 19:18:26:  480MHz   4    43  3.95   -312    73 19:27:39:  480MHz   4    43  3.95   -313    72 19:30:09:  480MHz   4    43  3.94   -318    72 19:30:20:  480MHz   4    43  3.95   -314    72 19:30:50:  480MHz   4    43  3.94   -316    72 19:31:20:  480MHz   4    43  3.95   -312    72 19:31:30:  480MHz   4    43  3.94   -319    72 19:36:52:  480MHz   4    43  3.94   -322    71 19:45:34:  480MHz   4    43  3.93   -312    71 19:46:04:  480MHz   4    43  3.93   -312    70 19:53:36:  480MHz   4    43  3.92   -319    70 19:53:47:  480MHz   4    43  3.93   -314    70 19:53:57:  480MHz   4    43  3.92   -316    70 19:54:07:  480MHz   4    43  3.93   -315    70 19:54:42:  480MHz   4    43  3.92   -314    70 19:55:22:  480MHz   4    43  3.92   -314    69 20:04:35:  480MHz   4    43  3.92   -312    68 20:11:27:  480MHz   4    43  3.91   -312    68 20:13:48:  480MHz   4    43  3.91   -315    67 20:23:00:  480MHz   4    43  3.91   -314    66 20:26:31:  480MHz   4    43  3.90   -319    66 20:26:41:  480MHz   4    43  3.91   -313    66 20:27:12:  480MHz   4    43  3.90   -315    66 20:32:13:  480MHz   4    43  3.90   -315    65 20:41:26:  480MHz   4    43  3.90   -313    64 20:43:36:  480MHz   4    43  3.89   -315    64 20:50:38:  480MHz   4    43  3.89   -321    63 20:57:30:  480MHz   4    42  3.88   -321    63 20:57:40:  480MHz   4    42  3.89   -316    63 20:59:11:  480MHz   4    42  3.88   -316    63 20:59:51:  480MHz   4    42  3.88   -316    62 21:08:44:  480MHz   4    42  3.88   -314    61 21:15:26:  480MHz   4    42  3.87   -315    61 21:17:56:  480MHz   4    42  3.87   -317    60 21:27:09:  480MHz   4    42  3.87   -318    59 21:29:25:  480MHz   4    42  3.86   -321    59 21:29:35:  480MHz   4    42  3.87   -313    59 21:30:05:  480MHz   4    42  3.86   -314    59 21:36:17:  480MHz   4    42  3.86   -314    58 21:37:57:  480MHz   4    42  3.85   -328    58 21:38:08:  480MHz   4    42  3.86   -316    58 21:39:58:  480MHz   4    42  3.85   -316    58 21:40:08:  480MHz   4    42  3.86   -316    58 21:40:18:  480MHz   4    42  3.85   -316    58 21:45:30:  480MHz   4    42  3.85   -314    57 21:54:33:  480MHz   4    42  3.85   -314    56 21:57:13:  480MHz   4    42  3.84   -318    56 21:57:34:  480MHz   4    42  3.85   -314    56 21:57:44:  480MHz   4    42  3.84   -319    56 22:03:45:  480MHz   4    42  3.84   -315    55 22:12:58:  480MHz   4    42  3.84   -313    54 22:14:39:  480MHz   4    41  3.83   -315    54 22:22:11:  480MHz   4    41  3.83   -318    53 22:30:43:  480MHz   4    42  3.82   -320    53 22:30:53:  480MHz   4    42  3.83   -316    53 22:31:14:  480MHz   4    42  3.82   -321    53 22:31:24:  480MHz   4    41  3.82   -315    52 22:40:26:  480MHz   4    41  3.82   -314    51 22:46:33:  480MHz   4    41  3.81   -317    51 22:46:43:  480MHz   4    41  3.82   -317    51 22:47:04:  480MHz   4    41  3.81   -319    51 22:49:34:  480MHz   4    41  3.81   -317    50 22:58:37:  480MHz   4    41  3.81   -318    49 23:00:58:  480MHz   4    41  3.80   -326    49 23:01:08:  480MHz   4    41  3.81   -315    49 23:02:38:  480MHz   4    41  3.80   -316    49 23:02:48:  480MHz   4    41  3.81   -315    49 23:02:59:  480MHz   4    41  3.80   -337    49 23:07:50:  480MHz   4    41  3.80   -321    48 23:16:53:  480MHz   4    41  3.80   -316    47 23:17:13:  480MHz   4    41  3.79   -317    47 23:17:23:  480MHz   4    41  3.80   -316    47 23:17:33:  480MHz   4    41  3.79   -316    47 23:26:06:  480MHz   4    41  3.79   -318    46 23:26:16:  480MHz   4    41  3.78   -318    46 23:26:26:  480MHz   4    41  3.79   -316    46 23:26:36:  480MHz   4    41  3.78   -319    46 23:35:08:  480MHz   4    41  3.78   -317    45 23:41:00:  480MHz   4    41  3.77   -324    45 23:44:21:  480MHz   4    41  3.77   -321    44 23:53:24:  480MHz   4    41  3.77   -317    43 23:57:55:  480MHz   4    41  3.76   -326    43 00:02:32:  480MHz   4    41  3.76   -317    42 00:11:34:  480MHz   4    40  3.76   -319    41 00:13:25:  480MHz   4    40  3.75   -322    41 00:13:35:  480MHz   4    41  3.76   -318    41 00:13:45:  480MHz   4    40  3.75   -319    41 00:20:37:  480MHz   4    40  3.75   -317    40 00:29:40:  480MHz   4    40  3.75   -320    39 00:30:00:  480MHz   4    40  3.74   -320    39 00:38:42:  480MHz   4    40  3.74   -318    38 00:45:04:  480MHz   4    40  3.73   -331    38 00:45:14:  480MHz   4    40  3.74   -319    38 00:47:35:  480MHz   4    40  3.73   -319    38 00:47:45:  480MHz   4    40  3.73   -321    37 00:56:38:  480MHz   4    40  3.73   -322    36 01:01:49:  480MHz   4    40  3.72   -320    36 01:05:40:  480MHz   4    40  3.72   -320    35 01:12:02:  480MHz   4    40  3.71   -321    35 01:14:33:  480MHz   4    40  3.71   -322    34 01:23:31:  480MHz   4    39  3.71   -323    33 01:26:22:  480MHz   4    40  3.70   -325    33 01:27:42:  480MHz   4    40  3.71   -320    33 01:27:52:  480MHz   4    40  3.70   -323    33 01:32:34:  480MHz   4    39  3.70   -321    32 01:41:36:  480MHz   4    40  3.70   -321    31 01:43:37:  480MHz   4    39  3.69   -321    31 01:50:29:  480MHz   4    39  3.69   -321    30 01:59:01:  480MHz   4    39  3.68   -328    30 01:59:32:  480MHz   4    40  3.68   -329    29 02:00:32:  480MHz   4    39  3.64   -573    29 02:00:42:  480MHz   4    40  3.67   -404    29 02:00:52:  480MHz   4    39  3.68   -335    29 02:01:12:  480MHz   4    40  3.67   -401    29 02:01:23:  480MHz   4    39  3.68   -326    29 02:08:15:  480MHz   4    40  3.68   -322    28 02:17:07:  480MHz   4    40  3.67   -326    27 02:17:27:  480MHz   4    40  3.68   -324    27 02:17:37:  480MHz   4    39  3.67   -325    27 02:26:10:  480MHz   4    40  3.67   -324    26 02:34:22:  480MHz   4    39  3.66   -330    26 02:34:32:  480MHz   4    39  3.67   -327    26 02:34:53:  480MHz   4    39  3.66   -326    26 02:34:58:  480MHz   4    39  3.66   -327    25 02:43:50:  480MHz   4    39  3.66   -325    24 02:52:43:  480MHz   4    39  3.65   -325    24 02:52:53:  480MHz   4    39  3.66   -324    23 02:53:03:  480MHz   4    39  3.65   -324    23 03:01:46:  480MHz   4    39  3.65   -326    22 03:05:07: 1152MHz   4    43  3.62   -525    22 03:05:17: 1152MHz   4    46  3.60   -597    22 03:05:27: 1152MHz   4    42  3.63   -431    22 03:05:37:  480MHz   4    40  3.64   -330    22 03:10:08:  480MHz   4    41  3.61   -541    22 03:10:18:  480MHz   4    39  3.64   -328    21 03:19:11:  480MHz   4    39  3.64   -325    20 03:24:53:  480MHz   4    39  3.63   -330    20 03:25:03:  480MHz   4    39  3.64   -327    20 03:25:43:  480MHz   4    39  3.63   -328    20 03:25:53:  480MHz   4    39  3.64   -325    20 03:26:03:  480MHz   4    39  3.63   -327    20 03:26:24:  480MHz   4    39  3.64   -327    20 03:26:34:  480MHz   4    39  3.63   -329    20 03:28:04:  480MHz   4    38  3.63   -331    19 03:36:57:  480MHz   4    39  3.63   -325    18 03:45:49:  480MHz   4    39  3.63   -335    17 03:53:47:  480MHz   4    39  3.62   -331    17 03:53:57:  480MHz   4    38  3.63   -325    17 03:54:37:  480MHz   4    38  3.63   -325    16 03:54:57:  480MHz   4    38  3.62   -325    16 03:59:39:  480MHz   4    39  3.62   -324    15 04:00:39:  480MHz   4    39  3.62   -326    14 04:01:39:  480MHz   4    39  3.62   -324    13 04:02:40:  480MHz   4    38  3.62   -325    12 04:03:40:  480MHz   4    38  3.62   -326    11 04:04:40:  480MHz   4    39  3.62   -325    10 04:05:41:  480MHz   4    38  3.62   -326     9 04:06:41:  480MHz   4    39  3.62   -327     8 04:07:42:  480MHz   4    38  3.62   -327     7 04:12:23:  480MHz   4    39  3.62   -324     6 04:20:35:  480MHz   4    39  3.61   -332     6 04:20:45:  480MHz   4    38  3.62   -326     6 04:21:06:  480MHz   4    38  3.61   -329     6 04:21:16:  480MHz   4    39  3.62   -325     6 04:21:46:  480MHz   4    39  3.61   -326     6 04:21:56:  480MHz   4    39  3.62   -325     6 04:22:06:  480MHz   4    38  3.61   -325     6 04:22:26:  480MHz   4    38  3.62   -324     6 04:22:37:  480MHz   4    38  3.61   -326     6 04:22:47:  480MHz   4    38  3.62   -324     6 04:22:57:  480MHz   4    38  3.61   -326     6 04:33:20:  480MHz   4    39  3.61   -327     5 04:48:54:  480MHz   4    38  3.60   -337     5 04:49:04:  480MHz   4    38  3.61   -328     5 04:49:25:  480MHz   4    38  3.61   -327     4 04:51:15:  480MHz   4    38  3.60   -331     4 05:25:00:  480MHz   4    38  3.59   -330     4 05:25:30:  480MHz   4    38  3.60   -330     4 05:25:50:  480MHz   4    38  3.59   -329     4 05:31:12:  480MHz   4    38  3.59   -326     3 05:59:00:  480MHz   4    38  3.58   -332     3 05:59:10:  480MHz   4    38  3.59   -330     3 05:59:30:  480MHz   4    38  3.58   -332     3
And when it was drained to 3.10v the next day after recharging:
           CPU              Battery Time        Freq Cores Temp  Volt Curr Capacity 18:38:03: 1152MHz   4    47  4.19      3   100 18:38:38: 1152MHz   4    47  4.13   -355   100 18:38:53: 1152MHz   4    47  4.12   -464   100 18:40:03: 1152MHz   4    47  4.11   -440   100 18:40:13: 1152MHz   4    47  4.12   -437   100 18:40:24: 1152MHz   4    47  4.11   -438   100 18:40:34:  480MHz   4    46  4.12   -382   100 18:40:54:  480MHz   4    44  4.13   -306   100 18:42:24:  480MHz   4    43  4.13   -309    99 18:51:57:  480MHz   4    41  4.12   -301    98 18:53:57:  480MHz   4    42  4.11   -429    98 18:54:18:  480MHz   4    42  4.12   -303    98 19:01:19:  480MHz   4    42  4.12   -304    97 19:03:10:  480MHz   4    41  4.11   -308    97 19:03:20:  480MHz   4    41  4.12   -305    97 19:04:10:  480MHz   4    41  4.11   -304    97 19:04:31:  480MHz   4    42  4.12   -303    97 19:04:41:  480MHz   4    41  4.11   -311    97 19:10:52:  480MHz   4    42  4.11   -306    96 19:17:04:  480MHz   4    42  4.10   -307    96 19:20:25:  480MHz   4    42  4.10   -307    95 19:28:47:  480MHz   4    42  4.09   -314    95 19:28:57:  480MHz   4    42  4.10   -304    95 19:29:58:  480MHz   4    42  4.10   -303    94 19:30:28:  480MHz   4    42  4.09   -304    94 19:39:20:  480MHz   4    42  4.09   -308    93 19:42:51:  480MHz   4    42  4.08   -311    93 19:43:01:  480MHz   4    42  4.09   -306    93 19:43:52:  480MHz   4    42  4.08   -309    93 19:48:53:  480MHz   4    42  4.08   -311    92 19:54:45:  480MHz   4    42  4.07   -308    92 19:54:55:  480MHz   4    42  4.08   -306    92 19:55:05:  480MHz   4    42  4.07   -314    92 19:58:16:  480MHz   4    42  4.07   -311    91 20:06:48:  480MHz   4    42  4.06   -308    91 20:06:58:  480MHz   4    42  4.07   -306    91 20:07:09:  480MHz   4    42  4.06   -308    91 20:07:39:  480MHz   4    42  4.06   -308    90 20:17:06:  480MHz   4    42  4.06   -306    89 20:20:37:  480MHz   4    42  4.05   -310    89 20:20:58:  480MHz   4    42  4.06   -306    89 20:21:08:  480MHz   4    42  4.05   -333    89 20:26:29:  480MHz   4    42  4.05   -307    88 20:35:22:  480MHz   4    42  4.04   -306    88 20:35:32:  480MHz   4    42  4.05   -306    88 20:35:52:  480MHz   4    42  4.04   -308    87 20:36:02:  480MHz   4    42  4.05   -306    87 20:36:12:  480MHz   4    42  4.04   -306    87 20:45:05:  480MHz   4    42  4.04   -307    86 20:49:56:  480MHz   4    42  4.03   -308    86 20:54:27:  480MHz   4    42  4.03   -307    85 21:03:50:  480MHz   4    42  4.02   -311    84 21:04:10:  480MHz   4    42  4.03   -307    84 21:04:30:  480MHz   4    42  4.01   -383    84 21:04:40:  480MHz   4    42  4.02   -310    84 21:05:41:  480MHz   4    42  4.01   -383    84 21:05:51:  480MHz   4    42  4.02   -327    84 21:13:13:  480MHz   4    42  4.02   -309    83 21:18:54:  480MHz   4    42  4.01   -312    83 21:19:15:  480MHz   4    42  4.02   -308    83 21:19:25:  480MHz   4    42  4.01   -308    83 21:22:36:  480MHz   4    42  4.01   -307    82 21:30:18:  480MHz   4    42  4.00   -317    82 21:30:28:  480MHz   4    42  4.01   -309    82 21:31:18:  480MHz   4    42  4.00   -308    82 21:31:58:  480MHz   4    42  4.00   -311    81 21:41:21:  480MHz   4    42  4.00   -313    80 21:41:41:  480MHz   4    42  3.99   -313    80 21:41:46:  480MHz   4    42  4.00   -311    80 21:41:56:  480MHz   4    42  3.99   -311    80 21:42:07:  480MHz   4    42  4.00   -309    80 21:42:17:  480MHz   4    42  3.99   -311    80 21:50:39:  480MHz   4    42  3.99   -308    79 21:56:51:  480MHz   4    42  3.98   -314    79 21:57:01:  480MHz   4    42  3.99   -309    79 21:57:41:  480MHz   4    42  3.98   -311    79 22:00:02:  480MHz   4    42  3.98   -310    78 22:09:15:  480MHz   4    42  3.98   -308    77 22:12:25:  480MHz   4    42  3.97   -312    77 22:12:36:  480MHz   4    41  3.98   -309    77 22:12:46:  480MHz   4    41  3.97   -312    77 22:18:37:  480MHz   4    41  3.97   -310    76 22:28:00:  480MHz   4    42  3.97   -309    75 22:28:50:  480MHz   4    41  3.96   -309    75 22:29:10:  480MHz   4    41  3.97   -310    75 22:29:31:  480MHz   4    42  3.96   -309    75 22:37:23:  480MHz   4    41  3.96   -310    74 22:45:35:  480MHz   4    41  3.95   -309    74 22:45:45:  480MHz   4    41  3.96   -308    74 22:45:55:  480MHz   4    41  3.95   -310    74 22:46:46:  480MHz   4    41  3.95   -311    73 22:56:08:  480MHz   4    41  3.95   -310    72 23:00:10:  480MHz   4    41  3.94   -312    72 23:05:21:  480MHz   4    41  3.94   -310    71 23:14:19:  480MHz   4    41  3.93   -312    71 23:14:29:  480MHz   4    41  3.94   -307    71 23:14:39:  480MHz   4    41  3.94   -308    70 23:14:59:  480MHz   4    41  3.93   -312    70 23:23:21:  480MHz   4    41  3.92   -316    70 23:23:41:  480MHz   4    41  3.93   -313    70 23:23:52:  480MHz   4    41  3.92   -317    70 23:24:02:  480MHz   4    41  3.92   -316    69 23:33:24:  480MHz   4    40  3.92   -308    68 23:40:26:  480MHz   4    41  3.91   -308    68 23:40:37:  480MHz   4    40  3.92   -308    68 23:40:57:  480MHz   4    41  3.91   -309    68 23:42:47:  480MHz   4    40  3.91   -310    67 23:52:10:  480MHz   4    40  3.91   -308    66 23:56:11:  480MHz   4    40  3.90   -312    66 23:56:31:  480MHz   4    41  3.91   -309    66 23:56:41:  480MHz   4    41  3.90   -312    66 00:01:33:  480MHz   4    40  3.90   -309    65 00:10:45:  480MHz   4    40  3.90   -309    64 00:12:36:  480MHz   4    40  3.89   -312    64 00:20:08:  480MHz   4    40  3.89   -310    63 00:28:41:  480MHz   4    40  3.88   -313    63 00:29:31:  480MHz   4    41  3.88   -312    62 00:38:34:  480MHz   4    41  3.88   -310    61 00:44:50:  480MHz   4    40  3.87   -310    61 00:45:01:  480MHz   4    40  3.88   -310    61 00:45:41:  480MHz   4    40  3.87   -312    61 00:47:41:  480MHz   4    40  3.87   -312    60 00:57:04:  480MHz   4    40  3.87   -311    59 01:00:35:  480MHz   4    40  3.86   -311    59 01:06:17:  480MHz   4    40  3.86   -316    58 01:09:38:  480MHz   4    40  3.85   -317    58 01:09:48:  480MHz   4    40  3.86   -313    58 01:09:58:  480MHz   4    40  3.85   -313    58 01:10:18:  480MHz   4    40  3.86   -313    58 01:10:38:  480MHz   4    40  3.85   -312    58 01:15:40:  480MHz   4    40  3.85   -310    57 01:24:53:  480MHz   4    40  3.85   -311    56 01:28:24:  480MHz   4    40  3.84   -314    56 01:28:44:  480MHz   4    39  3.85   -311    56 01:28:54:  480MHz   4    40  3.84   -311    56 01:34:05:  480MHz   4    40  3.84   -316    55 01:43:18:  480MHz   4    39  3.83   -318    55 01:43:28:  480MHz   4    40  3.84   -317    54 01:44:19:  480MHz   4    40  3.83   -317    54 01:44:29:  480MHz   4    40  3.84   -312    54 01:44:39:  480MHz   4    40  3.83   -313    54 01:52:41:  480MHz   4    40  3.83   -313    53 02:01:19:  480MHz   4    39  3.82   -318    53 02:01:29:  480MHz   4    39  3.83   -312    53 02:01:39:  480MHz   4    40  3.82   -312    53 02:01:49:  480MHz   4    39  3.82   -312    52 02:11:12:  480MHz   4    39  3.82   -313    51 02:16:43:  480MHz   4    39  3.81   -320    51 02:20:24:  480MHz   4    39  3.81   -313    50 02:29:37:  480MHz   4    39  3.81   -313    49 02:33:28:  480MHz   4    39  3.80   -313    49 02:33:38:  480MHz   4    39  3.81   -312    49 02:33:49:  480MHz   4    40  3.80   -313    49 02:38:50:  480MHz   4    39  3.80   -314    48 02:47:43:  480MHz   4    39  3.79   -318    48 02:48:03:  480MHz   4    39  3.79   -316    47 02:57:15:  480MHz   4    39  3.78   -317    46 02:57:26:  480MHz   4    39  3.79   -315    46 02:57:36:  480MHz   4    39  3.78   -317    46 03:05:18: 1152MHz   4    44  3.75   -531    46 03:05:28: 1152MHz   4    42  3.76   -433    46 03:05:38:  480MHz   4    41  3.78   -317    46 03:05:48:  480MHz   4    40  3.77   -360    46 03:05:58:  480MHz   4    40  3.78   -323    46 03:06:08:  480MHz   4    40  3.78   -317    45 03:10:10: 1152MHz   4    41  3.74   -553    45 03:10:20:  480MHz   4    40  3.77   -364    45 03:10:30:  480MHz   4    40  3.78   -315    45 03:12:15:  480MHz   4    39  3.77   -316    45 03:15:16:  480MHz   4    39  3.77   -315    44 03:24:29:  480MHz   4    39  3.77   -320    43 03:28:20:  480MHz   4    39  3.76   -318    43 03:28:40:  480MHz   4    39  3.77   -315    43 03:28:51:  480MHz   4    39  3.76   -318    43 03:29:11:  480MHz   4    39  3.77   -315    43 03:29:21:  480MHz   4    39  3.76   -315    43 03:33:32:  480MHz   4    39  3.76   -315    42 03:42:45:  480MHz   4    39  3.76   -317    41 03:43:55:  480MHz   4    39  3.75   -320    41 03:44:05:  480MHz   4    39  3.76   -318    41 03:44:15:  480MHz   4    39  3.75   -319    41 03:51:58:  480MHz   4    39  3.75   -318    40 03:59:00:  480MHz   4    39  3.74   -328    40 03:59:10:  480MHz   4    39  3.75   -320    40 03:59:50:  480MHz   4    39  3.74   -322    40 04:00:00:  480MHz   4    39  3.75   -320    40 04:00:10:  480MHz   4    39  3.74   -322    40 04:01:01:  480MHz   4    39  3.74   -322    39 04:10:13:  480MHz   4    39  3.74   -319    38 04:17:05:  480MHz   4    39  3.73   -319    38 04:17:16:  480MHz   4    39  3.74   -318    38 04:17:36:  480MHz   4    39  3.73   -318    38 04:17:46:  480MHz   4    39  3.74   -318    38 04:17:56:  480MHz   4    39  3.73   -318    38 04:19:11:  480MHz   4    39  3.73   -317    37 04:28:04:  480MHz   4    39  3.73   -319    36 04:32:05:  480MHz   4    39  3.72   -318    36 04:37:07:  480MHz   4    39  3.72   -323    35 04:42:58:  480MHz   4    39  3.71   -317    35 04:46:19:  480MHz   4    39  3.71   -320    34 04:55:22:  480MHz   4    39  3.71   -318    33 04:58:33:  480MHz   4    38  3.70   -318    33 05:04:25:  480MHz   4    38  3.70   -318    32 05:13:27:  480MHz   4    38  3.70   -319    31 05:14:18:  480MHz   4    39  3.69   -321    31 05:14:28:  480MHz   4    39  3.70   -320    31 05:14:48:  480MHz   4    39  3.69   -320    31 05:22:30:  480MHz   4    39  3.69   -321    30 05:30:43:  480MHz   4    38  3.68   -323    30 05:30:53:  480MHz   4    38  3.69   -324    30 05:31:13:  480MHz   4    39  3.68   -323    30 05:31:33:  480MHz   4    39  3.69   -322    29 05:31:53:  480MHz   4    39  3.68   -325    29 05:40:31:  480MHz   4    38  3.68   -320    28 05:49:24:  480MHz   4    38  3.68   -320    27 05:49:54:  480MHz   4    39  3.67   -326    27 05:58:26:  480MHz   4    38  3.67   -321    26 06:07:29:  480MHz   4    38  3.67   -321    25 06:07:39:  480MHz   4    38  3.66   -324    25 06:07:49:  480MHz   4    38  3.67   -321    25 06:08:19:  480MHz   4    38  3.66   -324    25 06:08:29:  480MHz   4    38  3.67   -320    25 06:09:00:  480MHz   4    38  3.66   -323    25 06:16:32:  480MHz   4    38  3.66   -325    24 06:25:24:  480MHz   4    38  3.66   -322    23 06:26:25:  480MHz   4    38  3.65   -322    23 06:26:35:  480MHz   4    38  3.66   -322    23 06:26:45:  480MHz   4    38  3.65   -324    23 06:34:27:  480MHz   4    38  3.65   -327    22 06:37:08:  480MHz   4    38  3.65   -325    21 06:37:18:  480MHz   4    38  3.64   -329    21 06:37:28:  480MHz   4    38  3.65   -327    21 06:37:59:  480MHz   4    38  3.64   -326    21 06:38:09:  480MHz   4    38  3.64   -327    20 06:39:09:  480MHz   4    38  3.64   -324    19 06:39:29:  480MHz   4    38  3.65   -323    19 06:39:39:  480MHz   4    38  3.64   -328    19 06:40:10:  480MHz   4    38  3.64   -324    18 06:41:10:  480MHz   4    38  3.64   -325    17 06:42:10:  480MHz   4    38  3.64   -323    16 06:43:06:  480MHz   4    38  3.64   -323    15 06:44:06:  480MHz   4    38  3.64   -323    14 06:45:17:  480MHz   4    38  3.64   -323    13 06:46:17:  480MHz   4    38  3.64   -323    12 06:47:17:  480MHz   4    38  3.64   -322    11 06:48:18:  480MHz   4    38  3.64   -324    10 06:49:18:  480MHz   4    38  3.64   -322     9 06:50:18:  480MHz   4    38  3.64   -325     8 06:51:19:  480MHz   4    38  3.64   -327     7 06:52:19:  480MHz   4    38  3.64   -328     6 07:00:31:  480MHz   4    38  3.63   -323     6 07:00:42:  480MHz   4    38  3.64   -324     6 07:01:32:  480MHz   4    38  3.63   -323     6 07:01:42:  480MHz   4    38  3.64   -323     6 07:01:52:  480MHz   4    38  3.63   -322     6 07:02:12:  480MHz   4    38  3.64   -324     6 07:02:23:  480MHz   4    38  3.63   -322     6 07:02:53:  480MHz   4    38  3.63   -322     5 07:16:17:  480MHz   4    38  3.63   -322     4 07:28:00:  480MHz   4    38  3.62   -328     4 07:28:10:  480MHz   4    38  3.63   -329     4 07:28:30:  480MHz   4    38  3.62   -331     4 07:28:40:  480MHz   4    38  3.63   -329     4 07:29:01:  480MHz   4    38  3.62   -329     4 07:29:11:  480MHz   4    38  3.63   -324     4 07:29:21:  480MHz   4    38  3.62   -327     4 07:29:41:  480MHz   4    38  3.63   -326     4 07:30:01:  480MHz   4    38  3.62   -326     4 07:30:11:  480MHz   4    38  3.63   -325     4 07:30:21:  480MHz   4    38  3.62   -326     4 07:50:22:  480MHz   4    38  3.62   -327     3 07:58:35:  480MHz   4    39  3.61   -329     3 07:58:45:  480MHz   4    38  3.62   -324     3 07:59:05:  480MHz   4    38  3.61   -332     3 07:59:15:  480MHz   4    38  3.62   -324     3 07:59:25:  480MHz   4    38  3.61   -328     3 08:31:54:  480MHz   4    38  3.60   -325     3 08:32:04:  480MHz   4    38  3.61   -325     3 08:32:25:  480MHz   4    38  3.60   -326     3 08:37:36:  480MHz   4    39  3.59   -400     3 08:37:56:  480MHz   4    39  3.60   -328     3 08:47:59:  480MHz   4    39  3.60   -328     2 09:03:24:  480MHz   4    38  3.59   -337     2 09:03:34:  480MHz   4    38  3.60   -327     2 09:05:24:  480MHz   4    38  3.59   -328     2 09:05:35:  480MHz   4    38  3.60   -326     2 09:05:45:  480MHz   4    38  3.59   -327     2 09:05:55:  480MHz   4    38  3.57   -496     2 09:06:00:  480MHz   4    38  3.59   -326     2 09:36:19:  480MHz   4    39  3.57   -403     2 09:36:29:  480MHz   4    39  3.59   -328     2 09:42:00:  480MHz   4    39  3.58   -335     2 09:42:10:  480MHz   4    39  3.59   -329     2 09:42:31:  480MHz   4    39  3.58   -332     2 09:46:42:  480MHz   4    40  3.57   -404     2 09:46:52:  480MHz   4    40  3.58   -333     2 09:49:33:  480MHz   4    40  3.58   -331     1 10:01:56:  480MHz   4    40  3.57   -405     1 10:02:07:  480MHz   4    40  3.58   -331     1 10:08:28:  480MHz   4    40  3.57   -332     1 10:08:39:  480MHz   4    40  3.58   -333     1 10:08:49:  480MHz   4    40  3.57   -331     1 10:44:24:  480MHz   4    40  3.56   -410     1 10:44:34:  480MHz   4    40  3.57   -331     1 10:51:26:  480MHz   4    41  3.56   -347     1 10:51:36:  480MHz   4    40  3.57   -336     1 10:53:37:  480MHz   4    41  3.56   -346     1 10:53:57:  480MHz   4    40  3.57   -336     1 10:54:07:  480MHz   4    41  3.56   -340     1 10:54:17:  480MHz   4    40  3.57   -338     1 10:55:48:  480MHz   4    40  3.56   -340     1 10:55:58:  480MHz   4    41  3.57   -333     1 10:57:08:  480MHz   4    41  3.56   -338     1 10:59:19:  480MHz   4    41  3.57   -331     1 10:59:29:  480MHz   4    41  3.56   -334     1 11:34:59:  480MHz   4    41  3.55   -393     1 11:35:09:  480MHz   4    41  3.56   -334     1 11:41:41:  480MHz   4    41  3.55   -356     1 11:41:51:  480MHz   4    41  3.56   -338     1 11:42:42:  480MHz   4    41  3.55   -338     1 11:43:02:  480MHz   4    41  3.56   -336     1 11:43:12:  480MHz   4    41  3.55   -337     1 11:43:22:  480MHz   4    41  3.56   -334     1 11:43:32:  480MHz   4    41  3.55   -338     1 11:44:02:  480MHz   4    41  3.56   -335     1 11:44:23:  480MHz   4    41  3.55   -336     1 11:45:33:  480MHz   4    41  3.56   -333     1 11:45:48:  480MHz   4    41  3.55   -340     1 12:11:56:  480MHz   4    42  3.54   -409     1 12:12:06:  480MHz   4    41  3.55   -334     1 12:13:36:  480MHz   4    42  3.54   -399     1 12:13:46:  480MHz   4    41  3.55   -335     1 12:20:58:  480MHz   4    42  3.54   -392     1 12:21:09:  480MHz   4    42  3.55   -338     1 12:21:59:  480MHz   4    42  3.54   -402     1 12:22:09:  480MHz   4    42  3.55   -336     1 12:22:59:  480MHz   4    42  3.54   -373     1 12:23:10:  480MHz   4    42  3.55   -337     1 12:25:00:  480MHz   4    42  3.54   -352     1 12:25:10:  480MHz   4    41  3.55   -344     1 12:28:41:  480MHz   4    42  3.54   -340     1 12:28:51:  480MHz   4    42  3.55   -339     1 12:30:22:  480MHz   4    42  3.54   -338     1 12:30:32:  480MHz   4    42  3.55   -335     1 12:31:22:  480MHz   4    42  3.54   -344     1 12:31:33:  480MHz   4    42  3.55   -336     1 12:31:43:  480MHz   4    42  3.54   -338     1 12:33:23:  480MHz   4    42  3.55   -338     1 12:33:33:  480MHz   4    42  3.54   -338     1 13:08:48:  480MHz   4    42  3.54   -343     0 13:12:40:  480MHz   4    42  3.53   -346     0 13:12:50:  480MHz   4    42  3.54   -342     0 13:13:30:  480MHz   4    42  3.53   -345     0 13:13:50:  480MHz   4    42  3.54   -338     0 13:14:00:  480MHz   4    42  3.53   -341     0 13:14:10:  480MHz   4    42  3.54   -336     0 13:14:31:  480MHz   4    42  3.53   -341     0 13:14:41:  480MHz   4    42  3.54   -337     0 13:15:21:  480MHz   4    42  3.53   -339     0 13:15:31:  480MHz   4    42  3.54   -338     0 13:15:41:  480MHz   4    42  3.53   -337     0 13:32:06:  480MHz   4    42  3.51   -491     0 13:32:16:  480MHz   4    42  3.53   -338     0 13:45:50:  480MHz   4    42  3.52   -350     0 13:46:00:  480MHz   4    42  3.53   -344     0 13:46:10:  480MHz   4    42  3.52   -349     0 13:46:20:  480MHz   4    42  3.53   -342     0 13:46:51:  480MHz   4    42  3.52   -346     0 13:47:41:  480MHz   4    42  3.53   -342     0 13:47:51:  480MHz   4    42  3.52   -346     0 14:05:16:  480MHz   4    42  3.51   -416     0 14:05:26:  480MHz   4    43  3.52   -342     0 14:05:46:  480MHz   4    43  3.51   -412     0 14:06:06:  480MHz   4    42  3.52   -340     0 14:18:55:  480MHz   4    42  3.51   -375     0 14:19:15:  480MHz   4    43  3.52   -344     0 14:19:46:  480MHz   4    43  3.51   -343     0 14:21:56:  480MHz   4    42  3.50   -420     0 14:22:06:  480MHz   4    43  3.51   -343     0 14:22:57:  480MHz   4    43  3.50   -409     0 14:23:07:  480MHz   4    42  3.51   -341     0 14:23:57:  480MHz   4    42  3.50   -413     0 14:24:07:  480MHz   4    42  3.51   -342     0 14:24:58:  480MHz   4    42  3.50   -413     0 14:25:08:  480MHz   4    42  3.51   -346     0 14:25:58:  480MHz   4    43  3.50   -414     0 14:26:08:  480MHz   4    42  3.51   -340     0 14:30:39:  600MHz   4    42  3.50   -411     0 14:30:50:  480MHz   4    43  3.51   -342     0 14:36:51:  480MHz   4    43  3.50   -355     0 14:37:02:  480MHz   4    43  3.51   -344     0 14:37:42:  480MHz   4    43  3.50   -386     0 14:37:52:  480MHz   4    42  3.51   -341     0 14:40:43:  480MHz   4    43  3.49   -414     0 14:40:53:  480MHz   4    43  3.51   -341     0 14:41:53:  480MHz   4    43  3.50   -340     0 14:42:03:  480MHz   4    42  3.51   -341     0 14:42:14:  480MHz   4    43  3.50   -343     0 14:56:08:  480MHz   4    43  3.49   -420     0 14:56:28:  480MHz   4    43  3.50   -349     0 15:00:59:  480MHz   4    42  3.49   -372     0 15:01:09:  480MHz   4    42  3.50   -344     0 15:01:39:  480MHz   4    43  3.49   -399     0 15:01:50:  480MHz   4    43  3.50   -341     0 15:04:51:  480MHz   4    43  3.49   -419     0 15:05:01:  480MHz   4    43  3.50   -341     0 15:08:17:  480MHz   4    43  3.49   -356     0 15:08:27:  480MHz   4    43  3.50   -341     0 15:09:07:  480MHz   4    43  3.49   -342     0 15:35:15:  480MHz   4    43  3.48   -345     0 15:35:25:  480MHz   4    43  3.49   -341     0 15:37:15:  480MHz   4    43  3.48   -343     0 15:37:25:  480MHz   4    43  3.49   -346     0 15:37:56:  480MHz   4    43  3.48   -347     0 16:04:13:  480MHz   4    43  3.47   -349     0 16:04:23:  480MHz   4    43  3.48   -347     0 16:05:14:  480MHz   4    43  3.47   -349     0 16:05:24:  480MHz   4    43  3.48   -348     0 16:05:44:  480MHz   4    43  3.47   -350     0 16:05:54:  480MHz   4    43  3.48   -345     0 16:06:14:  480MHz   4    43  3.47   -349     0 16:06:34:  480MHz   4    43  3.48   -345     0 16:07:05:  480MHz   4    43  3.47   -344     0 16:07:15:  480MHz   4    43  3.48   -346     0 16:07:45:  480MHz   4    43  3.47   -346     0 16:16:38:  480MHz   4    43  3.46   -418     0 16:16:58:  480MHz   4    43  3.47   -346     0 16:33:27:  480MHz   4    43  3.46   -349     0 16:33:58:  480MHz   4    43  3.47   -343     0 16:34:08:  480MHz   4    42  3.46   -345     0 16:57:04:  480MHz   4    42  3.45   -349     0 16:57:35:  480MHz   4    43  3.46   -343     0 16:57:45:  480MHz   4    43  3.45   -345     0 17:04:57:  480MHz   4    43  3.44   -420     0 17:05:07:  480MHz   4    43  3.43   -496     0 17:05:17:  480MHz   4    43  3.44   -421     0 17:05:27:  480MHz   4    43  3.45   -351     0 17:05:37:  480MHz   4    43  3.44   -423     0 17:05:47:  480MHz   4    43  3.45   -347     0 17:16:21:  480MHz   4    43  3.44   -346     0 17:16:31:  480MHz   4    43  3.45   -347     0 17:16:41:  480MHz   4    43  3.44   -346     0 17:18:01:  480MHz   4    43  3.45   -349     0 17:18:11:  480MHz   4    43  3.44   -347     0 17:31:25:  480MHz   4    43  3.43   -348     0 17:31:35:  480MHz   4    43  3.44   -347     0 17:32:06:  480MHz   4    43  3.43   -347     0 17:32:16:  480MHz   4    43  3.44   -346     0 17:32:26:  480MHz   4    42  3.43   -349     0 17:32:41:  480MHz   4    43  3.44   -346     0 17:32:51:  480MHz   4    43  3.43   -348     0 17:49:46:  480MHz   4    43  3.42   -355     0 17:49:56:  480MHz   4    43  3.43   -350     0 17:50:16:  480MHz   4    43  3.42   -353     0 17:50:26:  480MHz   4    43  3.43   -347     0 17:50:37:  480MHz   4    43  3.42   -349     0 17:56:08:  480MHz   4    43  3.41   -398     0 17:56:18:  480MHz   4    43  3.42   -348     0 18:09:42:  480MHz   4    43  3.41   -355     0 18:09:52:  480MHz   4    43  3.42   -347     0 18:11:03:  480MHz   4    43  3.41   -350     0 18:37:00:  480MHz   4    43  3.40   -350     0 19:01:37:  480MHz   4    43  3.39   -350     0 19:02:02:  480MHz   4    43  3.40   -348     0 19:02:23:  480MHz   4    43  3.39   -350     0 19:02:33:  480MHz   4    43  3.40   -348     0 19:02:43:  480MHz   4    43  3.39   -350     0 19:20:48:  480MHz   4    42  3.38   -348     0 19:20:58:  480MHz   4    43  3.39   -349     0 19:21:28:  480MHz   4    42  3.38   -349     0 19:21:39:  480MHz   4    42  3.39   -348     0 19:21:59:  480MHz   4    43  3.38   -350     0 19:24:09:  480MHz   4    42  3.39   -355     0 19:24:20:  480MHz   4    43  3.38   -354     0 19:27:00:  480MHz   4    43  3.37   -427     0 19:27:21:  480MHz   4    43  3.38   -348     0 19:31:42:  480MHz   4    42  3.37   -355     0 19:40:14:  480MHz   4    43  3.36   -353     0 19:46:56:  480MHz   4    43  3.35   -355     0 19:52:08:  480MHz   4    43  3.34   -353     0 19:56:29:  480MHz   4    43  3.33   -355     0 20:00:51:  480MHz   4    42  3.32   -356     0 20:04:32:  480MHz   4    43  3.31   -359     0 20:08:23:  480MHz   4    43  3.30   -357     0 20:10:44:  480MHz   4    42  3.29   -355     0 20:14:05:  480MHz   4    43  3.28   -353     0 20:14:30:  480MHz   4    43  3.27   -428     0 20:14:40:  480MHz   4    42  3.28   -353     0 20:16:00:  480MHz   4    42  3.27   -428     0 20:16:11:  480MHz   4    42  3.28   -354     0 20:17:01:  480MHz   4    42  3.27   -354     0 20:20:02:  480MHz   4    42  3.26   -357     0 20:22:53:  480MHz   4    42  3.25   -357     0 20:23:03:  480MHz   4    42  3.26   -354     0 20:23:13:  480MHz   4    42  3.25   -358     0 20:25:54:  480MHz   4    42  3.24   -356     0 20:28:25:  480MHz   4    42  3.23   -355     0 20:29:45:  480MHz   4    42  3.22   -356     0 20:32:16:  480MHz   4    42  3.21   -357     0 20:34:37:  480MHz   4    42  3.20   -357     0 20:36:47:  480MHz   4    42  3.19   -358     0 20:39:08:  480MHz   4    42  3.18   -367     0 20:41:09:  480MHz   4    42  3.17   -366     0 20:43:09:  480MHz   4    43  3.16   -362     0 20:44:20:  480MHz   4    43  3.15   -363     0 20:46:10:  480MHz   4    42  3.14   -362     0 20:48:01:  480MHz   4    42  3.13   -362     0 20:49:41:  480MHz   4    42  3.12   -361     0 20:51:12:  480MHz   4    42  3.11   -364     0 20:52:42:  480MHz   4    42  3.10   -366     0
And the board state and uptime which was captured by the low voltage monitor script was:
Batt Status    Discharging   Batt Voltage   3.09 v  Batt Current   -366 mA  Batt Capacity  0 %  CPU freq       480.00 MHz  CPU count      4   SOC Temp       42 C  Cooling state  0    20:54:13 up 1 day,  2:30,  0 users,  load average: 0.18, 0.13, 0.14
  +LTS/SOPINE +PINEBOOK configuring Euler Bus pin generate interrupt RANJITT76 0 4,015 01-10-2019, 02:45 AM
Last Post: RANJITT76
  Mapping Euler bus DC in and 5v DC out pins g_t_j 8 17,801 07-02-2016, 09:30 PM
Question What exactly is a Euler Bus? Ghost 10 50,022 05-06-2016, 06:49 PM
  Euler Bus hrh1818 4 18,400 01-29-2016, 01:56 PM
