Other Remotes ??
Hi guys im wondering it is posible to get on working third party remotes.???
i have some laying arround and i would like to use them Smile Big Grin
thanks!
i have tried by connecting the ir receiver and open the port receiver like a pine64 remote but no codes recveived i have check the ir and is working fine
any ideas thanks again Smile
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
(08-29-2016, 07:23 PM)Zoidiano0 Wrote: Hi guys im wondering it is posible to get on working third party remotes.???
thanks!
First of all, there is a chance that not all remotes will just work. The remote that the pine64 was optimised for transmits IR codes using the NEC protocol, so remotes for devices like sony products may not work (and didn't for the one I tried)... Sony use their own protocol just to be different! Wink
If you have attached an IR receiver into the IR socket, on debian, you can use the evtest command. It's not installed by default, you'll need to run "sudo apt-get install evtest" first to install it. Then, when you run it as sudo like below, you'll want to enter the number for the "sunxi_ir_recv" device... which is number 4 on my system. You'll then get a long list of events that the device supports (all the different buttons), and a prompt saying "Testing ... (interrupt to exit)". At this point, you can press a few buttons on your test remote, and see the the pine64 responds. I pressed the 1 - 9 keys on a NEC-IR-complaint remote I use for for my lighting system, and each button was detected. Once you have events being triggered, it's just a matter of setting up some sort of handler to monitor for those events, and respond accordingly.
pfeerick@pine64:~$ sudo evtest No device specified, trying to scan all of /dev/input/event* Available devices: /dev/input/event0:      sunxi-keyboard /dev/input/event1:      axp81x-supplyer /dev/input/event2:      sunxi-ths /dev/input/event3:      audiocodec sunxi Audio Jack /dev/input/event4:      sunxi_ir_recv /dev/input/event5:      MCE IR Keyboard/Mouse (sunxi-rc-recv) Select the device event number [0-5]: 4 Input driver version is 1.0.1 Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100 Input device name: "sunxi_ir_recv" Supported events:   Event type 0 (EV_SYN)   Event type 1 (EV_KEY)     Event code 1 (KEY_ESC)     Event code 2 (KEY_1)     Event code 3 (KEY_2)     Event code 4 (KEY_3)     Event code 5 (KEY_4)     Event code 6 (KEY_5)     Event code 7 (KEY_6)     Event code 8 (KEY_7)     Event code 9 (KEY_8)     Event code 10 (KEY_9)     Event code 11 (KEY_0)     Event code 12 (KEY_MINUS)     Event code 13 (KEY_EQUAL)     Event code 14 (KEY_BACKSPACE)     Event code 15 (KEY_TAB)     Event code 16 (KEY_Q)     Event code 17 (KEY_W)     Event code 18 (KEY_E)     Event code 19 (KEY_R)     Event code 20 (KEY_T)     Event code 21 (KEY_Y)     Event code 22 (KEY_U)     Event code 23 (KEY_I)     Event code 24 (KEY_O)     Event code 25 (KEY_P)     Event code 26 (KEY_LEFTBRACE)     Event code 27 (KEY_RIGHTBRACE)     Event code 28 (KEY_ENTER)     Event code 29 (KEY_LEFTCTRL)     Event code 30 (KEY_A)     Event code 31 (KEY_S)     Event code 32 (KEY_D)     Event code 33 (KEY_F)     Event code 34 (KEY_G)     Event code 35 (KEY_H)     Event code 36 (KEY_J)     Event code 37 (KEY_K)     Event code 38 (KEY_L)     Event code 39 (KEY_SEMICOLON)     Event code 40 (KEY_APOSTROPHE)     Event code 41 (KEY_GRAVE)     Event code 42 (KEY_LEFTSHIFT)     Event code 43 (KEY_BACKSLASH)     Event code 44 (KEY_Z)     Event code 45 (KEY_X)     Event code 46 (KEY_C)     Event code 47 (KEY_V)     Event code 48 (KEY_B)     Event code 49 (KEY_N)     Event code 50 (KEY_M)     Event code 51 (KEY_COMMA)     Event code 52 (KEY_DOT)     Event code 53 (KEY_SLASH)     Event code 54 (KEY_RIGHTSHIFT)     Event code 55 (KEY_KPASTERISK)     Event code 56 (KEY_LEFTALT)     Event code 57 (KEY_SPACE)     Event code 58 (KEY_CAPSLOCK)     Event code 59 (KEY_F1)     Event code 60 (KEY_F2)     Event code 61 (KEY_F3)     Event code 62 (KEY_F4)     Event code 63 (KEY_F5)     Event code 64 (KEY_F6)     Event code 65 (KEY_F7)     Event code 66 (KEY_F8)     Event code 67 (KEY_F9)     Event code 68 (KEY_F10)     Event code 69 (KEY_NUMLOCK)     Event code 70 (KEY_SCROLLLOCK)     Event code 71 (KEY_KP7)     Event code 72 (KEY_KP8)     Event code 73 (KEY_KP9)     Event code 74 (KEY_KPMINUS)     Event code 75 (KEY_KP4)     Event code 76 (KEY_KP5)     Event code 77 (KEY_KP6)     Event code 78 (KEY_KPPLUS)     Event code 79 (KEY_KP1)     Event code 80 (KEY_KP2)     Event code 81 (KEY_KP3)     Event code 82 (KEY_KP0)     Event code 83 (KEY_KPDOT)     Event code 84 (?)     Event code 85 (KEY_ZENKAKUHANKAKU)     Event code 86 (KEY_102ND)     Event code 87 (KEY_F11)     Event code 88 (KEY_F12)     Event code 89 (KEY_RO)     Event code 90 (KEY_KATAKANA)     Event code 91 (KEY_HIRAGANA)     Event code 92 (KEY_HENKAN)     Event code 93 (KEY_KATAKANAHIRAGANA)     Event code 94 (KEY_MUHENKAN)     Event code 95 (KEY_KPJPCOMMA)     Event code 96 (KEY_KPENTER)     Event code 97 (KEY_RIGHTCTRL)     Event code 98 (KEY_KPSLASH)     Event code 99 (KEY_SYSRQ)     Event code 100 (KEY_RIGHTALT)     Event code 101 (KEY_LINEFEED)     Event code 102 (KEY_HOME)     Event code 103 (KEY_UP)     Event code 104 (KEY_PAGEUP)     Event code 105 (KEY_LEFT)     Event code 106 (KEY_RIGHT)     Event code 107 (KEY_END)     Event code 108 (KEY_DOWN)     Event code 109 (KEY_PAGEDOWN)     Event code 110 (KEY_INSERT)     Event code 111 (KEY_DELETE)     Event code 112 (KEY_MACRO)     Event code 113 (KEY_MUTE)     Event code 114 (KEY_VOLUMEDOWN)     Event code 115 (KEY_VOLUMEUP)     Event code 116 (KEY_POWER)     Event code 117 (KEY_KPEQUAL)     Event code 118 (KEY_KPPLUSMINUS)     Event code 119 (KEY_PAUSE)     Event code 120 (KEY_SCALE)     Event code 121 (KEY_KPCOMMA)     Event code 122 (KEY_HANGUEL)     Event code 123 (KEY_HANJA)     Event code 124 (KEY_YEN)     Event code 125 (KEY_LEFTMETA)     Event code 126 (KEY_RIGHTMETA)     Event code 127 (KEY_COMPOSE)     Event code 128 (KEY_STOP)     Event code 129 (KEY_AGAIN)     Event code 130 (KEY_PROPS)     Event code 131 (KEY_UNDO)     Event code 132 (KEY_FRONT)     Event code 133 (KEY_COPY)     Event code 134 (KEY_OPEN)     Event code 135 (KEY_PASTE)     Event code 136 (KEY_FIND)     Event code 137 (KEY_CUT)     Event code 138 (KEY_HELP)     Event code 139 (KEY_MENU)     Event code 140 (KEY_CALC)     Event code 141 (KEY_SETUP)     Event code 142 (KEY_SLEEP)     Event code 143 (KEY_WAKEUP)     Event code 144 (KEY_FILE)     Event code 145 (KEY_SENDFILE)     Event code 146 (KEY_DELETEFILE)     Event code 147 (KEY_XFER)     Event code 148 (KEY_PROG1)     Event code 149 (KEY_PROG2)     Event code 150 (KEY_WWW)     Event code 151 (KEY_MSDOS)     Event code 152 (KEY_SCREENLOCK)     Event code 153 (KEY_DIRECTION)     Event code 154 (KEY_CYCLEWINDOWS)     Event code 155 (KEY_MAIL)     Event code 156 (KEY_BOOKMARKS)     Event code 157 (KEY_COMPUTER)     Event code 158 (KEY_BACK)     Event code 159 (KEY_FORWARD)     Event code 160 (KEY_CLOSECD)     Event code 161 (KEY_EJECTCD)     Event code 162 (KEY_EJECTCLOSECD)     Event code 163 (KEY_NEXTSONG)     Event code 164 (KEY_PLAYPAUSE)     Event code 165 (KEY_PREVIOUSSONG)     Event code 166 (KEY_STOPCD)     Event code 167 (KEY_RECORD)     Event code 168 (KEY_REWIND)     Event code 169 (KEY_PHONE)     Event code 170 (KEY_ISO)     Event code 171 (KEY_CONFIG)     Event code 172 (KEY_HOMEPAGE)     Event code 173 (KEY_REFRESH)     Event code 174 (KEY_EXIT)     Event code 175 (KEY_MOVE)     Event code 176 (KEY_EDIT)     Event code 177 (KEY_SCROLLUP)     Event code 178 (KEY_SCROLLDOWN)     Event code 179 (KEY_KPLEFTPAREN)     Event code 180 (KEY_KPRIGHTPAREN)     Event code 181 (KEY_NEW)     Event code 182 (KEY_REDO)     Event code 183 (KEY_F13)     Event code 184 (KEY_F14)     Event code 185 (KEY_F15)     Event code 186 (KEY_F16)     Event code 187 (KEY_F17)     Event code 188 (KEY_F18)     Event code 189 (KEY_F19)     Event code 190 (KEY_F20)     Event code 191 (KEY_F21)     Event code 192 (KEY_F22)     Event code 193 (KEY_F23)     Event code 194 (KEY_F24)     Event code 195 (?)     Event code 196 (?)     Event code 197 (?)     Event code 198 (?)     Event code 199 (?)     Event code 200 (KEY_PLAYCD)     Event code 201 (KEY_PAUSECD)     Event code 202 (KEY_PROG3)     Event code 203 (KEY_PROG4)     Event code 204 (KEY_DASHBOARD)     Event code 205 (KEY_SUSPEND)     Event code 206 (KEY_CLOSE)     Event code 207 (KEY_PLAY)     Event code 208 (KEY_FASTFORWARD)     Event code 209 (KEY_BASSBOOST)     Event code 210 (KEY_PRINT)     Event code 211 (KEY_HP)     Event code 212 (KEY_CAMERA)     Event code 213 (KEY_SOUND)     Event code 214 (KEY_QUESTION)     Event code 215 (KEY_EMAIL)     Event code 216 (KEY_CHAT)     Event code 217 (KEY_SEARCH)     Event code 218 (KEY_CONNECT)     Event code 219 (KEY_FINANCE)     Event code 220 (KEY_SPORT)     Event code 221 (KEY_SHOP)     Event code 222 (KEY_ALTERASE)     Event code 223 (KEY_CANCEL)     Event code 224 (KEY_BRIGHTNESSDOWN)     Event code 225 (KEY_BRIGHTNESSUP)     Event code 226 (KEY_MEDIA)     Event code 227 (KEY_SWITCHVIDEOMODE)     Event code 228 (KEY_KBDILLUMTOGGLE)     Event code 229 (KEY_KBDILLUMDOWN)     Event code 230 (KEY_KBDILLUMUP)     Event code 231 (KEY_SEND)     Event code 232 (KEY_REPLY)     Event code 233 (KEY_FORWARDMAIL)     Event code 234 (KEY_SAVE)     Event code 235 (KEY_DOCUMENTS)     Event code 236 (KEY_BATTERY)     Event code 237 (KEY_BLUETOOTH)     Event code 238 (KEY_WLAN)     Event code 239 (KEY_UWB)     Event code 241 (KEY_VIDEO_NEXT)     Event code 242 (KEY_VIDEO_PREV)     Event code 243 (KEY_BRIGHTNESS_CYCLE)     Event code 244 (KEY_BRIGHTNESS_ZERO)     Event code 245 (KEY_DISPLAY_OFF)     Event code 246 (KEY_WIMAX)     Event code 247 (KEY_RFKILL)     Event code 248 (?)     Event code 249 (?)     Event code 250 (?)     Event code 251 (?)     Event code 252 (?)     Event code 253 (?)     Event code 254 (?)     Event code 255 (?)   Event type 4 (EV_MSC)     Event code 4 (MSC_SCAN) Key repeat handling:   Repeat type 20 (EV_REP)     Repeat code 0 (REP_DELAY)       Value    500     Repeat code 1 (REP_PERIOD)       Value    125 Properties: Testing ... (interrupt to exit) Event: time 1472527024.225265, type 4 (EV_MSC), code 4 (MSC_SCAN), value 0c Event: time 1472527024.225265, -------------- EV_SYN ------------ Event: time 1472527024.642609, type 4 (EV_MSC), code 4 (MSC_SCAN), value 18 Event: time 1472527024.642609, -------------- EV_SYN ------------ Event: time 1472527025.043661, type 4 (EV_MSC), code 4 (MSC_SCAN), value 5e Event: time 1472527025.043661, -------------- EV_SYN ------------ Event: time 1472527026.480844, type 4 (EV_MSC), code 4 (MSC_SCAN), value 08 Event: time 1472527026.480844, -------------- EV_SYN ------------ Event: time 1472527027.716175, type 4 (EV_MSC), code 4 (MSC_SCAN), value 1c Event: time 1472527027.716175, -------------- EV_SYN ------------ Event: time 1472527028.518139, type 4 (EV_MSC), code 4 (MSC_SCAN), value 5a Event: time 1472527028.518139, -------------- EV_SYN ------------ Event: time 1472527029.242932, type 4 (EV_MSC), code 4 (MSC_SCAN), value 42 Event: time 1472527029.242932, -------------- EV_SYN ------------ Event: time 1472527029.965370, type 4 (EV_MSC), code 4 (MSC_SCAN), value 52 Event: time 1472527029.965370, -------------- EV_SYN ------------ Event: time 1472527030.656292, type 4 (EV_MSC), code 4 (MSC_SCAN), value 4a Event: time 1472527030.656292, -------------- EV_SYN ------------
I'd like to use a Logitech Harmony remote, which interacts with all my other devices. Does anyone know of a suitable NEC protocol mapping in the Harmony database?
BR.
  Add-On remotes SkimMilk 1 5,382 01-23-2016, 12:18 PM
