08-19-2016, 07:50 AM
Is possible to use two wires as Power and Reset Bottons? If so, in which holes I have to solder them? The more distant or closest?
Wires as power button
08-19-2016, 10:20 AM
If you're referring to the pc board pads, its the two closest to the edge of the board. You could certainly just use two wires without a switch, but I think you'll find that more of a hassle than you want, for a variety of reasons.
You may find this recent thread helpful: http://forum.pine64.org/showthread.php?tid=2043
08-19-2016, 12:59 PM
... recursive link here ...
08-19-2016, 01:08 PM
(08-19-2016, 10:20 AM)DonFL Wrote: If you're referring to the pc board pads, its the two closest to the edge of the board. You could certainly just use two wires without a switch, but I think you'll find that more of a hassle than you want, for a variety of reasons. Yes, I know it. But I can't find this switch in my city. Definitely I will buy it on the net, but I need a temporary solution beacuse everytime I have to turn it off I have to disconnect the power supply. Thanks for the help
08-19-2016, 02:21 PM
(08-19-2016, 12:59 PM)martinayotte Wrote: ... recursive link here ... http://forum.pine64.org/showthread.php?tid=2032
08-19-2016, 03:35 PM
hi, I will point out also that the best solution is to use an actual switch for both power off button , and the reset button. Any momentary close switch will work, and may be fastened to the EXP header via jumper wires.
This is a duplicate thread (closing).
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697 ( I regret that I am not able to respond to personal messages; let's meet on irc! ) |
+LTS/SOPINE USB voltage on power off using LiPo battery | GregH | 0 | 5,220 |
05-06-2020, 11:23 PM Last Post: GregH |
| Battery case and power question | Twistedx | 2 | 9,692 |
12-24-2018, 08:04 PM Last Post: Twistedx |
| Power Cord & SD Card | Maximum | 1 | 4,882 |
01-09-2017, 04:41 PM Last Post: Ghost |
| Can't get power button to work | AidenH | 17 | 35,670 |
08-28-2016, 07:19 AM Last Post: DonFL |
| Push button on/off switch | Wolfenstein | 6 | 14,780 |
08-01-2016, 11:05 AM Last Post: MarkHaysHarris777 |
| Power Jumper | rahlquist | 12 | 26,345 |
04-03-2016, 09:29 AM Last Post: SkimMilk |
