Pelican Case?
Has anyone considered a Pelican-style case?  I've seen it used for a lot of different electronic devices and computer equipment, so I thought this might be a possibility.  I'm not familiar with the different models/styles, but it does seem very versatile and adaptable.  Any thoughts?
(08-16-2016, 07:06 AM)burbs Wrote: Has anyone considered a Pelican-style case?  I've seen it used for a lot of different electronic devices and computer equipment, so I thought this might be a possibility.  I'm not familiar with the different models/styles, but it does seem very versatile and adaptable.  Any thoughts?
I'm curious what you mean by pelican style cases;  do you have a link?
Marcus, Pelican is a well known brand name of cases and enclosures, usually designed to be waterproof, shockproof, and generally weather resistant. A quick internet search for "pelican case" should get you what you need.
(08-16-2016, 08:33 AM)montero65 Wrote: Marcus, Pelican is a well known brand name of cases and enclosures, usually designed to be waterproof, shockproof, and generally weather resistant.  A quick internet search for "pelican case" should get you what you need.
oh... I thought maybe you had a particular style or idea in mind.  I think its a good idea to make case manufacturers aware of the pineA64 (the way we did with the C4Labs Zebra case with fan)!
Except for my cb&dt play box, my other PineA64 boards are still operational 'guts' spread out on my desktop.  I'm pretty sure I'm going to wrap them in C4Labs cases at this point, but still have not made up my mind.
Edit:  the small Pelican 1120 case might be appropriate for transporting a PineA64 lab, pine guts, LED lab and GPIO boards, and gps. Its a rugged little case and is not overly bulky nor heavy (and its weather proof too).  The only down-side is that the case it as much as the Pine board !  (the one in the link was regularly $43.50, now $27.93)
Photo Weatherproof case build ltorsini 12 40,666 07-07-2026, 07:01 PM
Last Post: ltorsini
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 97,664 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 7,104 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 19,901 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 18,489 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 29,776 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 16,266 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 139,997 03-30-2017, 11:36 AM
Last Post: Luke
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 22,005 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 8,827 10-04-2016, 02:45 AM
Last Post: modmypi
