External DAC
#21
(02-03-2016, 10:52 AM)tllim Wrote: The Pine A64 board has the master clock where RPi doesn't have, no sure whether still need the clock divider.
Current highest bit rate is 192KHz, we have not try out the 384kHz and not sure whether works.
The DSD data pump to I2S bus is software implementation and needs developers to try out. However, the ES9023 DAC don't accept DSD data and needs to convert over to PCM.
Design a small adapter for Euler I2S pins over u.fl is possible. However, this depend on collaboration and popularity.
Thank you for the answers, few more questions if I may.
Just for clarification - you referenced 192KHz and 384KHz because they are the highest frequencies above 176.4KHz, 352.8KHz or because you only support 48Khz family as beaglebone does?
https://hifiduino.wordpress.com/2014/03/...for-audio/
So DSD over I2S is only a software issue, no hardware limitation on DSD out with:
64 Fs: 2.8224 MHz, 3.072MHz,
28 Fs 5.6448MHz, 6.144MHz,
256 Fs: 11.2896MHz, 12.288MHz
ES9023 DAC
don't accept DSD data, but ESS9018 does Wink
https://hifiduino.wordpress.com/2012/11/...ame-wires/
What I2S input formats do you support?
ES9023 DAC
The referenced 192KHz and 384Khz just because they are highest. The board hardware capable of handle both 44.1KHz and 48Khz.
The hardware threat the PCM and DSD as data that goes into audio circular buffer, 64 and 128 Fs should be OK, not sure about 256Fs.
Yes, if you plan to natively decode DSD, ESS9018 is a best choice. Please note that DSD and DSD2 make sense, Above 2XDSD is just plain silly and number games.
In general, the I2S input formats is Philips type. However, the hardware also can handles EIAJ type (also call as Sony type),
(02-02-2016, 11:53 AM)tllim Wrote:
(02-02-2016, 11:47 AM)joe Wrote:
(02-02-2016, 11:44 AM)tllim Wrote:
(02-02-2016, 07:20 AM)joe Wrote:
(02-02-2016, 05:00 AM)joe Wrote: @TL, Lim
Agree low costs and god performance DAC i2s board , is pine64 project.
and  ES9023 DAC sound is not too bad !
if you design ES9023  DAC i2s for pine64  you will support Volumio ?
This is Media player , boot from image file
if you can , try give Development board to Volumio or contact they
Volumio works on embedded systems , is open source .
someone is designed for Raspberry Pi  ES9023  DAC  support Volumio
https://volumio.org/
[Image: o71xqb.png]
We are happy to provide Pine A64 board and DAC module to Volumio when ready, this will happen some time around March. Do you have the Volumio contact info?
No , this web site i just to saw ,  ask you
I am not S........ Big Grin
Noted.
Sorry ,
Volumio  is music player , is not media player .
( my English is bad )
Thanks a bunch for the answers!
yes I know this numer games, I was asking to get the whole picture right.
Do you also support up to 24 bit 192Khz on the I2S input?
I could not find Master Clock input for the I2S input - is there one?
It would be great for other users to have this information on the pine64 audio wiki page
(02-04-2016, 07:25 AM)xaled Wrote: Thanks a bunch for the answers!
At current time I just try out I2S output and still not yet try out I2S input, not sure on the I2S input performance. The Master Clock is an output clock and this means the I2S in needs to sync with this clock. You cannot have two master clock (in and out) coexist at same time.
ESSTECH   ES9023 Data Sheet
http://www.esstech.com/index.php/en/products/dac/
SABRE Premier Audio DAC with integrated 2Vrms Driver
http://www.esstech.com/files/4114/4095/2...101103.pdf
I thinking pine64 they do it this external sound boards will have Spdif output + DAC output all in one?
This is low costs and god performance Big Grin
PINE boards Euler "e" Connector support DAC 3.3V + 5V Spdif
This design user need to replace for use
[Image: 70ezc6.png]
(02-12-2016, 03:10 AM)joe Wrote: I thinking pine64 they do it this external sound boards will have Spdif output + DAC output all in one?
[Image: 70ezc6.png]
Due to popularity, the audio DAC design will start on this week. It contains ESS Sabre ES9023 Audio DAC, opitcal Toslink and coaxial SPDIF output. This is two-in-one combo board as Joe mentioned. Please note that this board have not been included on Backerkit list and may include two weeks later.
How about plain analog out?
@ Tl Lim
Your choose this Pine64 HI-FI board , you will use nichicon hi-fi quality capacitors?
I don't know your HI-FI board will add capacitors and support 3.3v and 5v  , because some this Single-board computer HI-FI board have this capacitors , some is not use , so..................  Undecided
Update:*
This ES9023 Chip need to use capacitors?
You finish your kickstarter user after to talk about this , Thank !
  Popping on SPDIF - External DAC mjgoode 3 15,082 05-14-2019, 11:12 AM
Last Post: TrisWood
