OwnCloud on pine64
Is there any way to run owncloud on the pine?
main reason I got it was to make a personal cloud out of it.
Owncloud package exists on Arch Aarch64
[Image: 3316269c5072e45f814a390d5f81cfe7.jpg]
Yes, for sure! I run it and it works great. It is much faster than the Pi that it replaces. You need to be sure that you install all the pre-requisites, but it is an easy install.
(08-09-2016, 01:01 PM)jl_678 Wrote: Hi,
I'm a newbie here, if you could throw together a quick guide that would be amazing!.
By the way, I assume you are storing data on a external HDD and not on the SD card, right ?
Mine is using the SD card for storage because I am not storing much. It is not too difficult to store on a hard drive, but you should get that setup prior to installing Owncloud.
I have not setup an auto mounting hard drive on Pine, but it should not be difficult. The key is to make sure that it is externally powered.
Regarding Owncloud, it is straightforward and there is nothing special required for the Pine. There are many tutorials on the web. Here is an example https://www.howtoforge.com/tutorial/ownc...-8-jessie/
Feel free to ask questions here or on irc if you experience difficulties.
Sent from my XT1254 using Tapatalk
Which image should I build it on top off
Debian or Ubuntu ?
Both will work, but I would recommend Debian. It is easier to find HowTo's for Debian in my experience since it relies on more mature packages. The HowTo I provided assumes Debian Jessie which is the version supported on Pine.
  Programming languages support under PINE64 baryluk 6 20,690 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,664 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,186 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,669 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,130 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,216 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,981 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,600 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,687 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 60,118 10-26-2017, 05:51 PM
Last Post: gregjo
