MicroSD Size mismatch with Image
#21
Thanks TL. Glad to hear that you do have input on the image size after all, that makes things much better for all of us. The SanDisk cards I have are in fact marked with the Class 10 logo, not the UHS-I logo.
While the next round of images should be sized correctly per your comment, any chance of going back and re-sizing the previous releases as well? Sometimes updates can bring new problems while fixing old ones, and some of us might want to keep the older builds if they work better for us. If the earlier builds can be resized as well, that might be helpful to some people in the community. Not a necessity, but might be a nice option to have. Thanks again for your hard work.
#22
(08-05-2016, 12:27 PM)tllim Wrote: I plan to make the build image smaller for sub sequence build. Currently, I am collecting the physical capacity size of microSD card in market to determine the build size. I also don't want to be too small and waste capacity.
I'm so glad you took up the baton TLLIM, thanks. Bet all of us are waiting for the right image to fit our 64GB cards
#23
@tllim Is there any good news on the rework progress?
#24
I would also like to know how this is coming along so I can finally start using all of my SD card.
  Reducing Android Image download size. KPhillisJr 4 13,245 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,556 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,110 05-05-2017, 01:50 AM
Last Post: Quezbeme
  Error formatting MicroSD Terra854 21 57,698 03-07-2017, 01:31 AM
Last Post: AnaNova
  android image & sd card size problems tomarneson 11 27,924 01-24-2017, 05:31 AM
Last Post: ayufan
  Tutorial: How to create DD images with appropriate size tkaiser 5 19,082 12-20-2016, 08:17 AM
Last Post: Bluphire
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,102 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,434 10-17-2016, 11:42 AM
Last Post: mathiraj
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 3,331 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 9,033 09-04-2016, 12:05 PM
Last Post: Boring
