HW Acceleration Working
@longsleep after update no audio device is detected. If you need any log please let me know.
http://imgur.com/a/wCEaa
(08-01-2016, 09:53 AM)Monochrome Wrote: @longsleep after update no audio device is detected. If you need any log please let me know.
Mhm i do not see how that could be related.
Please post the outputs of
aplay -l
and
lsmod
and the full output of `dmesg` after fresh boot.
(07-31-2016, 03:57 PM)xalius Wrote: I had not luck so far with enabling armsoc-drv with X, with the version from the PPA I get a kernel oops,
Finally figured out that problem. Launchpad build is updated - should work fine with 1.4.0-0ubuntu2+0sunxi5. Thanks for testing!
Ok seems to work now with the version from the PPA, thanks! Back to fixing the allocation problem I guess Tongue
@longsleep
aplay: device_list:268: no soundcards found...
debian@pine64:~$ lsmod
Module                  Size  Used by
bnep                   17511  2
bluetooth             195943  5 bnep
vfe_v4l2              747618  0
vfe_io                 34085  1 vfe_v4l2
mali                  238217  0
ir_lirc_codec          12756  0
lirc_dev               17032  1 ir_lirc_codec
videobuf2_dma_contig    17668  1 vfe_v4l2
videobuf2_memops       12546  1 videobuf2_dma_contig
ir_sony_decoder        12489  0
ir_sanyo_decoder       12491  0
ir_jvc_decoder         12487  0
ir_mce_kbd_decoder     12628  0
ir_rc6_decoder         12520  0
ir_rc5_decoder         12487  0
ir_nec_decoder         12487  0
videobuf2_core         30952  1 vfe_v4l2
sunxi_ir_rx            12902  0
deinterlace            18524  0
cedar_ve               17368  0
ss                     33083  0
8723bs               1365012  0
cfg80211              374207  1 8723bs
dmesg http://pastebin.com/vi0bgg0p
(08-01-2016, 11:54 AM)Monochrome Wrote: dmesg http://pastebin.com/vi0bgg0p
Ok the DMESG shows the error
[ 13.552150] sndhdmi sound.7: ASoC: can't create pcm SUNXI-HDMIAUDIO :-12
[ 13.571547] sndhdmi sound.7: ASoC: failed to instantiate card -12
[ 13.590409] sndhdmi sound.7: snd_soc_register_card() failed: -12
[ 13.609061] sndhdmi: probe of sound.7 failed with error -12
As of why i have no clue. Anyone else gets this?
Btw its supposed to look like this:
root@pine64:~# dmesg|grep -i sndhdmi
[ 12.454417] sndhdmi sound.7: sndhdmi <-> 1c22800.daudio mapping ok
[ 12.625219] #0: sndhdmi
(08-01-2016, 11:40 AM)xalius Wrote: Ok seems to work now with the version from the PPA, thanks! Back to fixing the allocation problem I guess Tongue
Something is not right with the continues memory allocation of the drm driver. I am not particularly keen to dig into this. A possible workaround is to add
optargs=cma=256M
to your /boot/uEnv.txt - do not restart X11 to often and it is fine Tongue (and have Allwinner fix their driver)
Ok. So I tried every possible way [from forum] to change resolution from 4K to 1080p. Nothing worked. Once [don't know why] it booted with desktop in 720p. I checked sound card and it was present. I can't replicate it. Somehow I think maybe the 4k is the problem based on what happened.
Maybe - you can play around with the various KMS parameters - some work, others don't. See https://wiki.archlinux.org/index.php/ker...de_setting for a rather good summary.
Also when in X11, xrandr works fine to change the resolution.
Wait do we have a timeline for the Mali Blobs?
If they are IP isn't it game over?
BTW, thanks for all the images and work.. having a lot of fun working with these now.
The source is licensed.
... the blob is being tested, and there are issue to sort... be patient.
(08-01-2016, 03:06 PM)longsleep Wrote: Maybe - you can play around with the various KMS parameters - some work, others don't. See https://wiki.archlinux.org/index.php/ker...de_setting for a rather good summary.
Thanks for the link. I will read it but I do not think I can get much out of it. With xrandr I'm getting "xrandr failed to get size of gamma for output default". Probably doing something wrong but sadly I just can't get it to work.
  Brand New LCD not working adamjedgar 3 11,003 03-11-2017, 12:20 AM
Last Post: simplexdan
  Pine64+: 3 working, 1 shows nothing on tv zumtra 1 6,302 07-30-2016, 05:47 PM
Users browsing this thread: 13 Guest(s)
