4K video output
Video
Good morning,
Has anyone tested the 4K video output on a 4K television or monitor?
(I know that Android outputs in 1080p.)
Thanks!
Nobody with a 4K tv?
Or is it something else?
(04-24-2016, 09:47 AM)Danton Wrote: Nobody with a 4K tv?
If you take a quick look around a some people havent even gotten theirs to work with a display at all yet since currenty all it supports directly is 1080p 60hz
Hi there,
bug/defect report :
system setup: PIne64, running mashmallow and kodi 16.1.
HDMI passthru. to an onkyo TN -NR 737 avr.
discription:
when playing 4k video with dolby or DTS , 4k video is perfect but the sound will pause every 2 seconds.
KODI 16.1 Audio settings:
-the audio options for playback of encoded audio such as Dolby Digital(AC3), DTS, True HD and DTS HD are all enabled in KODI 16.1 audio output.
expected result:
playing 4K video with Dolby or DTS sounds great and without any pause.
have you tried a 4k video outside of kodi and without kodi running, or , is the successful 4k video (not including audio)just because of something to do with kodi?
you could probably try external audio software and use kodio for video only to test.
  Video freeze caused by overheating? wanthalf 4 12,647 07-14-2019, 08:26 AM
Last Post: hmuller
  Can android 6.0 output spidf or coaxial if a buy the DAC? v1n1c1uS 0 3,388 03-03-2018, 10:40 AM
Last Post: v1n1c1uS
  Android 6.0 (HDMI Video Output) [20170112 v2.0.1] no sound philips 0 4,016 07-23-2017, 11:14 AM
Last Post: philips
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,525 05-05-2017, 01:50 AM
Last Post: Quezbeme
  No HDMI Output Arkhanjel 5 10,462 05-03-2017, 09:21 AM
Last Post: Arkhanjel
  Video Player apk wappi 4 9,539 01-18-2017, 02:40 PM
Last Post: wappi
  Best Video Player for Android wappi 0 3,784 11-27-2016, 12:49 PM
Last Post: wappi
  Video Signal Loss (Android 7.0 builds) JonnyRial 4 9,402 11-23-2016, 09:17 PM
Last Post: JonnyRial
Photo Pine A64 - Portrait h264 video renders incorrectly edup 0 3,619 09-16-2016, 02:12 AM
Last Post: edup
  Build the Lichee and Android source-"Android 5.1.1 Image (HDMI Video Output) Release SuperX 2 7,179 08-12-2016, 02:00 AM
Last Post: xalius
