Script for building DD image - I hate 18GB zip files!
I've been trying to build Android for several days now without success.  I can build the kernel and I can build Android. What I can't do is assemble an image that will boot.  Does anyone have a script that will assemble the parts into a DD image? Currently I am using the Allwinner pack command with PhoenixCard and that is not making an image that will boot. There is something wrong with the ext2 partitions. Kernel starts but user space fails.
Also - could the Pine64 people please take a new snapshot of their Android source and this time use tar.gz on it instead of zip so that it preserves the files permissions? I had to hunt around and find a hundred files and set +x back on them. Get rid of those zip files and replace them with tar.gz.
Building Android would be so much easier if we just has access to delta repositories that overlay ASOP.
Remember this thread: http://forum.pine64.org/showthread.php?tid=1188
Or push a working build up to www.gitlab.com (not GitHub). GitLab will accept repos the size of Android. Heck, just do this to get rid of the bandwidth load on your own servers. Or I can push it up once I have working build. I uploaded the RK3128 tree a while ago. https://gitlab.com/jonsmirl/fireprime
No one is going to work on this code if it is impossible to build it.
I pretty much gave up on building a working image based on the provided SDK with broken file permission, no working config and no proper git repository. I guess by now that it would be easier to make a fresh port than trying to use the SDK...
  Reducing Android Image download size. KPhillisJr 4 13,279 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,578 07-18-2017, 08:49 AM
Last Post: eclay
Lightbulb New procedure for building Android from source jonsmirl 34 95,762 07-09-2017, 12:32 AM
Last Post: amitkma
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,187 05-05-2017, 01:50 AM
Last Post: Quezbeme
  android image & sd card size problems tomarneson 11 27,994 01-24-2017, 05:31 AM
Last Post: ayufan
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,180 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,461 10-17-2016, 11:42 AM
Last Post: mathiraj
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 3,341 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 9,049 09-04-2016, 12:05 PM
Last Post: Boring
  MicroSD Size mismatch with Image Hbtr 23 47,425 08-31-2016, 09:00 AM
Last Post: montero65
