Dear DEV, I NEED NON ROOTED Image
I am noob or misunderstood??.. I cant get clear crystal from android image download.
I downloaded non rooted image.. But why still rooted?..
(Android 5.1.1 Image (HDMI Video Output) Release 20160711)
I cant streaming apps Astro On The Go and iFlix becuase of rooted..
Even i tried delete SU, BusyboxSmp, SU apk from ubuntu, it still detect as rooted..
[Image: Screenshot_2016_07_28_12_16_30.png]
[Image: Screenshot_2016_07_26_07_40_47.png]
[Image: Screenshot_2016_07_26_07_42_32.png]
(07-27-2016, 10:38 PM)suaji Wrote: I am noob or misunderstood??.. I cant get clear crystal from android image download.
For streaming apps, try installing hide my root app from Play Store. That should work with most streaming apps.
Here is the link - https://play.google.com/store/apps/detai...hidemyroot
also SuperSU has the option to disable SU for thoes pesky apps, which you can re-enable for root stuff later.
We provide both types of Android, rooted and non... and that is the beauty of the PineA64 for Android and the Play Store... for those apps that need root, plug in that SD card... and for those apps that get grumpy, plug in the non root SD card... no problema
marcus
(07-28-2016, 12:54 PM)MarkHaysHarris777 Wrote: We provide both types of Android, rooted and non... and that is the beauty of the PineA64 for Android and the Play Store... for those apps that need root, plug in that SD card... and for those apps that get grumpy, plug in the non root SD card... no problema
marcus
But that's what they're saying, they downloaded and burned the non-rooted image but are still having problems with the OS identifying the image as being rooted (or at least rootable). See the first screen-grab in the OPs message - it shows them highlighting the rooted and non-rooted image options, indicating that they specifically chose a non-rooted image.
(07-28-2016, 07:53 AM)ViperVi Wrote: Here is the link - https://play.google.com/store/apps/detai...hidemyroot
Same bro.. Still not working.. Tried using image for 8gb..
[Image: Pine64.png]
(07-28-2016, 10:39 AM)x1800MODMY360x Wrote: also SuperSU has the option to disable SU for thoes pesky apps, which you can re-enable for root stuff later.
I just delete it from system also not working.
marcus
Sir, u need try burn image for DD Image non root.. I tried both version 8gb and 16gb.. Still rooted.. Since rooted image from 20160505 version even on the page Download said got version rooted and not root..
I thought i will get not rooted image in version 20160711.. Huhu
Sir, i dont get it when you said "for those apps that need root, plug in that SD card... and for those apps that get grumpy, plug in the non root SD card"..
What is that mean?.. Sorry for been noob..
marcus
That is what i mean.. Thanks for clear it bro.. Sorry for my noob english ^_^v
i am wondering if the problem is that all of our Android images are developer images ?
... I was also able to  su -  to root on the console of my android system ( non root ).  In fact, the latest image I received from tllim for testing ( another issue ) i was also able to su to root on the console.
So, it looks like the images are 'able' to be root-able; which I certainly find interesting.
At this point, the engineers (main developers) are going to have to play with it to come up with a truly non root image.   On a philosophical point,  I'm not sure I would 'want' to run an app that demands that my device not be rooted.  To further push this philosophical point,  ALL devices should be rootable--- its your device , after all !
marcushh777
Mark if you have a Android image (supposed to be non-root) with shell acess, can you check if the 'su' and 'busybox' binaries are in /system/bin ?
  Reducing Android Image download size. KPhillisJr 4 13,404 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,658 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,525 05-05-2017, 01:50 AM
Last Post: Quezbeme
  android image & sd card size problems tomarneson 11 28,326 01-24-2017, 05:31 AM
Last Post: ayufan
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,593 10-29-2016, 04:31 AM
Last Post: joe
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,536 10-17-2016, 11:42 AM
Last Post: mathiraj
  Setting up SD card and installing rooted Android using an ubuntu machine edszr.co 4 10,900 09-22-2016, 03:56 PM
Last Post: edszr.co
  burning Android SD image with Ubuntu... Jessica Spongekipper 0 3,374 09-16-2016, 01:46 AM
Last Post: Jessica Spongekipper
Question Rooted Android 5.1.1 - Phone, Dialler & SMS Green Cherry 2 7,192 09-10-2016, 08:14 PM
Last Post: dkryder
  Can I rotate Screen Android 5.1.1 for LCD (not rooted) steveslim 4 12,477 09-04-2016, 09:35 PM
Last Post: steveslim
