Running Out Of Options LCD Panel Just Not Working
32Gb micro SD with the following on it
android-ver5.1.1-20160711-pine64-phoenixCard
No errors when I burned it with ApplePi Baker
Both ribbon cables are connected in their appropriate sockets
Thin one goes to TP (pads down)
Larger one with 2 blue ends in DSI (pads down)
and to the ribbon cable connector.  I even flipped the connector just in case.
MicroSD is a Adata class10 64GB
Power supply is the one that came with the Pine64.
When I plug the power in I see a little bleep on the panel but that's it.   Is there a LED on the panel itself to see if there's connection?
Also the Pine works fine with Adroid 5.1 and HDMI
Anybody can think of anything?
I'm running out of options.
OK I got it. 2 things if you start with ApplPi Baker stay with ApplePi Baker. I formated my micro SD using SD Formatter and burned the image with ApplePi Baker.
Second thing is power issue I cannot use the screen and the WiFi module together!!!
I guess I'm gonna have to bump up the Amps on that power supply they sent me.
(07-26-2016, 11:44 PM)AUDIOTEK Wrote: OK I got it.  2 things if you start with ApplPi Baker stay with ApplePi Baker.  I formated my micro SD using SD Formatter and burned the image with ApplePi Baker.
Also, the LCD panel uses a different Android OS image than the HDMI version. Find it here.
(07-26-2016, 11:44 PM)AUDIOTEK Wrote: Second thing is power issue   I cannot use the screen and the WiFi module together!!!
I have had the LCD and touchscreen working with also the wifi module plugged in and connected to the network, all while using the Pine64 power supply.
Are you sure you're using the right image, as Ghost suggested?
I finally got it to work with the module after a few reboot.
Exclamation LCD 7" Pine64 own not working with pine64 A64 board HL3D 0 10,775 01-27-2025, 10:51 AM
Last Post: HL3D
  7 inch LCD touch panel is upside down? joshpl 2 5,226 12-07-2023, 06:18 AM
Last Post: stormwyrm
  LCD panel Driver IC MIPIguy 1 5,590 08-12-2017, 05:04 PM
  I2C Touch Panel mbt28 0 3,575 06-12-2017, 11:32 AM
Last Post: mbt28
  LCD touch panel emits low power Naccies 4 10,659 01-09-2017, 07:45 PM
  Lcd panel's pixels are not square bokeer 0 3,157 11-22-2016, 08:08 PM
Last Post: bokeer
  LCD Panel not working at all treize 7 16,738 09-19-2016, 10:24 PM
Last Post: billjon
  LCD Panel Connected but does not work maipercaso 1 5,064 08-20-2016, 08:14 PM
Last Post: MarkHaysHarris777
  LCD Pannel working... Touch screen NOT working?? Why Chopshop13 3 9,015 06-13-2016, 08:24 AM
Last Post: PapaStahl
  LCD not working talvor 1 6,179 06-11-2016, 08:11 AM
Last Post: Luke
