06-28-2016, 11:25 PM
As long as the SoC temp in Linux stays below 80 it's fine without heat sink.
Accelerated H.264 and HEVC video decoding with Cedrus
07-03-2016, 11:53 AM
Latest update. Running test 1080p video H264 decoding, measured temperature do not go over 44C with heat sink (modified heat sink - cutted to SoC dimension) just layed on top of it, wthout any termal conductive paste.
07-04-2016, 11:42 AM
(07-03-2016, 11:53 AM)janeku Wrote: Latest update. Running test 1080p video H264 decoding, measured temperature do not go over 44C with heat sink (modified heat sink - cutted to SoC dimension) just layed on top of it, wthout any termal conductive paste. Please post foto of your colling system. My experiments can be found here: http://forum.pine64.org/showthread.php?t...4#pid14694.
07-24-2016, 01:22 AM
(05-11-2016, 02:03 AM)lenny.raposo-pine64.pro Wrote: ok here is the list of the packages available (05-13-2016, 12:18 PM)lenny.raposo-pine64.pro Wrote: sudo -i Those packages are missing in Debian.
07-26-2016, 12:44 PM
I am trying to get this working in VLC but i can't seem to get it right. I have tried mplayer using longsleep's script to run the big buck bunny test video and that worked fine. For VLC i tried to force VDPAU decoding in the preferences(under the codec tab) and nothing seems to be happening. Is there some step i am missing?
08-30-2016, 05:17 AM
A little something. I don't know if this can apply to the Pine64-board, but it sure does work on the CHIP (which also use the Cedar VPU).
http://free-electrons.com/blog/support-f...ux-kernel/
08-30-2016, 05:26 AM
(This post was last modified: 08-30-2016, 05:27 AM by MarkHaysHarris777.)
(08-30-2016, 05:17 AM)CaptainZalo Wrote: A little something. I don't know if this can apply to the Pine64-board, but it sure does work on the CHIP (which also use the Cedar VPU). hi Captain ! ... exactly ! Take a look at this. ... what is key, the tree NO ONE is barking up right now, is a browser that fully supports VDPAU. VDPAU and the Cedrus project are the key, potentially, for video in gnu+linux without proprietary kernel blobs on the PineA64 (IMHO). Unfortunately, no such browser exists at the moment (for the PineA64) that supports VDPAU. But this is a conversation (which longsleep has started many times) that needs to be pursued.
marcushh777
please join us for a chat @ irc.pine64.xyz:6667 or ssl irc.pine64.xyz:6697 ( I regret that I am not able to respond to personal messages; let's meet on irc! )
08-30-2016, 06:11 AM
(08-30-2016, 05:26 AM)MarkHaysHarris777 Wrote: Unfortunately, no such browser exists at the moment (for the PineA64) that supports VDPAU. But this is a conversation (which longsleep has started many times) that needs to be pursued. Who's responsible for handling this? AllWinner, SBC makers or the true Lunix spirit; communities of all the different flavours of AllWinner based SBCs?
09-13-2016, 03:29 PM
(08-30-2016, 05:26 AM)MarkHaysHarris777 Wrote:(08-30-2016, 05:17 AM)CaptainZalo Wrote: A little something. I don't know if this can apply to the Pine64-board, but it sure does work on the CHIP (which also use the Cedar VPU). Chrome is a total jackass regarding VDPAU/VA-API acceleration under Linux - they support it under ChromeOS, using all the same libraries and setups - but not under Linux. Firefox, however, at least has VDPAU/VA-API acceleration through freshplayerplugin, so that should work, in theory.
Flash for arm? Is there such a thing?
From what I read on chromium's mailing list the real problem is that no one is working on a vdpau solution. As always with open-source you're free to do it yourself ...... RrrrrightEdit.... the hardware codec support in chromium OS is done by vaapi, it seems, not by vdpau. |
| Video wall? | monty1 | 2 | 7,428 |
04-12-2017, 04:34 PM Last Post: monty1 |
| pine64 accelerated jpeg decoding | jacklau | 1 | 6,166 |
01-12-2017, 01:12 AM Last Post: Trizna |
| Pine64 accelerated H.264 encoding | hngjms | 7 | 18,924 |
10-18-2016, 03:15 AM Last Post: pfeerick |
| The sunxi transform module is very slow, how to do video rotation? | jacklau | 0 | 3,839 |
09-19-2016, 12:24 AM Last Post: jacklau |
| Video encoding h.265/HEVC | tomaThoma | 1 | 8,413 |
07-02-2016, 11:35 PM Last Post: tllim |
| Question about video acceleration | BringItOn | 10 | 23,357 |
06-23-2016, 10:33 AM Last Post: ssvb |
| Linux accelerated graphics | nomadewolf | 1 | 6,472 |
12-29-2015, 11:26 PM Last Post: tllim |
