Remix OS 2.0 Image Release 20160718
Star
[Image: Logo_remix.jpg]
  • Suitable for 2GB Pine A64+ Board, can runs on 1GB Pine A64+ Board with performance lagging, not suitable for 512MB Pine A64 Board
  • Add Remix apps market
  • Video setting supports both 720P and 1080P
  • Supports video screen scaling function
  • New MAC address assignment method, tags to board and SoC unique ID.
  • Support UVC USB camera as front camera
  • Known issues:
    • Not yet support 5M Pixel camera module as real camera
    • Even the HDMI output can set to 720P, but during boot up time, the boot logo stil maintain as 1080P.
  • DD image (for 8GB microSD Card):
Downloading it now, guess the gigabit Ethernet will still NOT work??  If you can get this Ethernet problem solved, for both the Remix and Android, you will have a very nice board.   Until it works, I test a few functions then put it back into a drawer, because it is not usable for Android or Remix for me.
OTA Update?
After first observations, this version goes backward, back into the drawer this board goes.
Ethernet does not work, but that was expected.
No settings to change display fonts, everything to small to read from the couch. DPI set at 160 and no way to change it to 240. May be OK to use as a computer with the screen 16 inches from your eyes.
No audio settings, "audio output mode" is blank. "output raw audio signal", can't be enabled. My AV receiver has to be turned up to max setting just to hear something.
This update, is a very big step backwards.
Where can I find full change log?
Sent from my iPhone using Tapatalk
(07-22-2016, 02:10 PM)clarkss12 Wrote: After first observations, this version goes backward, back into the drawer this board goes.
Thank you for this short review. Saved me some time.
Cheers,
Matt
ETA-
LCD/HDMI review?
Cheers,
Matt
ETA-
LCD/HDMI review?
As reported by another user (can not remember the name but it is a genius !!!) in a post on Android Lollipop, you need to change your Ethernet cable for the internet connection.
Ie the cable must be completely cut brown and white brown cables, cut the blue and blue cables.
In this manner connected the cables 3,6, 7, and 8, that the orange and green pairs.
Both Android and Remix Ethernet now goes to the full !!!   Smile Smile Smile
Cheers,
Matt
ETA-
LCD/HDMI review?
well, yes.  until they fix the signals, if they fix the signal route you then have bad cable.
I did try that method of opening the cable and cutting the pairs of wires, but did not help me. It would not connect at all.
When I received my board back the first part of July, I made a video showing all three OS's running on my board.  At that time, Android and Remix needed work, but were functional.  Since then, both Android and Remix had an update.  Unfortunately, both updates were a step backward, now neither Android or Remix is functional.
https://www.youtube.com/watch?v=nPaSRIurhj8
Hello to all,
someone has issues with Play Store?
I have constantly problems downloading App, also following the recovery procedure proposed by Google works once out of ten.
I noticed that the problem occurs especially if you switch from Ethernet to Wifi and vice versa.
What could it be ???
In addition, you do not see a trace of this in the settings can be set larger characters.
Ciao.
  sourround sound - Remix MrSarkasmus 0 5,168 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
  Remix os os 64bits ?? Matroxplay 1 7,055 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 252,282 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,574 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,361 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,646 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 33,839 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,469 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,661 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
  Build 20160718, can't boot from PhoenixCard image EricL 0 4,905 09-04-2016, 08:34 PM
Last Post: EricL
