Image without Guu
Hy guys,
do you plan to release a small debian image like netinst withou gui?
Is it possible to boot the actual debian image without the gui?
(07-06-2016, 09:03 PM)WhiteSnake86 Wrote: Is it possible to boot the actual debian image without the gui?
yes, it is.
... The base img (kernel 102bsp) boots to a CLI; you can access the serial console, or you can signon via hdmi terminal (cursorless fbcon), or you can ssh into the unit.
The base image is small, and its fast. It has a couple of glitches you should be aware of... its blue tooth is active by default and it often loops on bootup... I had to disable my bluetooth modules, & startup scripts. Also, if the ethernet is not plugged in the bootup can loop, or wait for an incredibly long time ... once I got the wifi running I disabled the ethernet (made it manual in /etc/network/interfaces). And, depending on your hdmi monitor, sometimes the bootup to hdmi will also loop... if you have a modern 1080p60 LED hdmi monitor it should work fine.
You can add what you wish to the base img, and it never needs a gui if you don't want it.
You can get the based image at https://www.pine64.pro/
marcus
  Is there just one fuctioning Debian Desktop image? KNERD 7 21,509 03-29-2019, 02:00 AM
Last Post: desai_amogh
  [help] Trying to build a close to mainline image erreip2221 7 13,202 12-26-2016, 12:26 PM
Last Post: erreip2221
  Gambas3 installation on Debian image linusky 0 3,545 11-29-2016, 11:10 AM
Last Post: linusky
  Very long boot time with Debian image Xabaras76 5 12,546 07-14-2016, 03:49 PM
Last Post: Xabaras76
  Cannot install Dstat on Debian Base PineA64 image ywoody 6 13,438 07-11-2016, 07:15 PM
Last Post: dkryder
  Pine64 not booting with image m16bishop 9 17,064 06-13-2016, 10:50 AM
Last Post: robertvaldimarsson
  dose the debian-mate-jessie-lenny.raposo image support lcd display? MicroDiery 1 4,966 06-03-2016, 07:59 AM
Last Post: Luke
