07-03-2016, 09:19 AM
A device tree source with working framebuffer on HDMI we would be a start. Or any image Android or whatever with working sunxi_drm HDMI driver might be helpful.
HW Acceleration Working
07-03-2016, 02:59 PM
(07-02-2016, 09:50 PM)tllim Wrote:(07-01-2016, 02:24 AM)CaptainZalo Wrote: Eagerly awaiting update once you're done meeting with Allwinner tech, @tllim Dear tllim, Thank you. I am encouraged by your report. I hope the negotiations continue well. Thanks for all you do ! marcus
07-03-2016, 08:25 PM
(This post was last modified: 07-03-2016, 08:26 PM by lenny.raposo-pine64.pro.)
longsleep still get nada in terms of the mali branch.
The question is what was used by AllWinner to get this to work successfully? Which BSP version or is it something that is yet to be released? Almost tempted to take the last untouched BS v2 and try it there then do a comparison between longsleep tree and bsp v2 tree.
If you like my work be sure to check out my site or wish to donate to the cause
Cheers ![]()
07-06-2016, 03:19 PM
scripts/Makefile.clean:94: recipe for target 'drivers/video/sunxi/disp2/disp' failed
make[3]: *** [drivers/video/sunxi/disp2/disp] Error 2 scripts/Makefile.clean:94: recipe for target 'drivers/video/sunxi' failed make[2]: *** [drivers/video/sunxi] Error 2 scripts/Makefile.clean:94: recipe for target 'drivers/video' failed make[1]: *** [drivers/video] Error 2 Makefile:1040: recipe for target '_clean_drivers' failed make: *** [_clean_drivers] Error 2 That's from longsleep's kernel additions Off to test what will happen with Pure BSP v2
Cheers ![]()
07-06-2016, 03:42 PM
I do not understand so much what is wrong with Allwiner and their drivers but someone explain me about this link on their page and download link to drivers ? Mali driver 64bit is interesting information but : did someone test it, already been implemented in existing kernels, issues with copyrights, something else ?
I jus can not believe that : everything is stuck becaue of © activities or missing driver informations or missing data about Mali graphic chip ?
07-06-2016, 03:46 PM
They're having trouble merging it with the kernel img; there is little documentation, and the coding might be sketchy...
... a couple of very sharp cookies are working on it. marcus
07-06-2016, 11:09 PM
(07-06-2016, 03:19 PM)lenny.raposo-pine64.pro Wrote: scripts/Makefile.clean:94: recipe for target 'drivers/video/sunxi/disp2/disp' failed Clean target is broken but not required.
07-07-2016, 07:41 AM
Ok will proceed and see what happens on the flipside the same thing happens with the stock BSP too so will try there too.
Cheers ![]()
07-07-2016, 08:50 AM
longsleep's mali experiment built
will be testing today
Cheers ![]()
07-07-2016, 09:19 AM
I'll keep my fingers crossed
| Brand New LCD not working | adamjedgar | 3 | 11,749 |
03-11-2017, 12:20 AM Last Post: simplexdan |
| Pine64+: 3 working, 1 shows nothing on tv | zumtra | 1 | 6,765 |
07-30-2016, 05:47 PM Last Post: tllim |
