IRC server issues
Issues solved
if you encounter issues do let me know on here.  If no one reports problems then I will take this post down in a weeks time Smile
We know that many are trying to connect to IRC and experiencing issues and/or ping timeouts.
We are working on solving the problems but it may take a bit of time.
Our apologies
[edit] for now you can use chat over at pine64.pro -- be patient, its running slow (also related to the problem we are experiencing)
(07-06-2016, 08:24 AM)Luke Wrote: We know that many are trying to connect to IRC and experiencing issues and/or ping timeouts.
Our apologies
Thanks Luke, 'preciate all you do !
marcus
Our apologies
Looking forward the IRC reconnect soon. Once I clear out the shipment work load, I will participate.
Our apologies
Great tllim :Smile we now have 60+ regulars and many more visitors Smile
Good luck !
Our apologies
Good luck !
That is good Smile
Well, I gave it the good 'ol college try to get connected on the irc server tonight with no luck... once I disconnected I could not reconnect (from anywhere on earth, literally).
The servers ping; but no connect :/
Have a good night, hope to speak with y'all soon... Big Grin
marcus
Solved, we shouldn't have any more issues henceforth
yup Marcus, everything is down - just starting on figuring what the hell is wrong
[edit] plz check if this resolves for you: http://irc.pine64.xyz/
Thanks, Luke !
... yous guys do good work;
  Plex server abrmx 3 8,760 08-16-2017, 05:09 PM
Last Post: abrmx
  [Solved] Boot Issues dedseason 9 16,049 06-08-2017, 08:21 PM
Last Post: MarkHaysHarris777
  Pi2 Server Comparison - Rough JCMPine64 10 22,455 04-19-2016, 11:06 AM
Last Post: androsch
