Touch Display Detail
Can you provide some addition details on the upcoming 7inch touch display such as:
  • Capacitive or Resistive Touch?
  • TN or IPS?
  • Transmissive / Reflective / Transflective?
  • Viewing Angle?
  • PPI  (pixel density)?
  • DSI / LVDS or HDMI interface?
  • 18bit / 24bit color?
  • Refresh Rate?
  • etc..
Maybe just a link to the data sheet would be best.
Thanks,
-MG
(12-12-2015, 02:10 AM)manny89 Wrote: Can you provide some addition details on the upcoming 7inch touch display such as:
  • TN or IPS?
  • Viewing Angle?
  • Refresh Rate?
  • etc..
Thanks,
-MG
I will publish the LCD panel datasheet on next week.
- Capacitive touch
- a-si TFT active matrix
- dot pitch: 0.1506(H) x 0.1432(V)
- 24 bit RGB color
- MIPI Interface
  • TN or IPS?
  • Viewing Angle?
  • Refresh Rate?
  • etc..
Thanks,
-MG
- Capacitive touch
- 24 bit RGB color
- MIPI Interface
Thank TL... this is helpful. Looking forward to seeing the LCD data sheet as well.
-MG
  • TN or IPS?
  • Viewing Angle?
  • Refresh Rate?
  • etc..
Thanks,
-MG
- Capacitive touch
- 24 bit RGB color
- MIPI Interface
-MG
@MG, you are welcome. The LCD Panel datasheet already posted at pine.org wiki site. Here is the link: http://wiki.pine64.org/index.php/Main_Page#Datasheet
  • TN or IPS?
  • Viewing Angle?
  • Refresh Rate?
  • etc..
Thanks,
-MG
- Capacitive touch
- 24 bit RGB color
- MIPI Interface
-MG
@tllim -- Thanks for the pointer. I noticed the data sheet made no reference to the touch screen. Is that in a separate data sheet?
  • TN or IPS?
  • Viewing Angle?
  • Refresh Rate?
  • etc..
Thanks,
-MG
- Capacitive touch
- 24 bit RGB color
- MIPI Interface
-MG
Yes, TC is separate data sheet and we will make the final selection on next week. The reason on the slow selection is due to EMI concern cause the cable length.
can you support a resistive touch panels?
can you add resistive touch-screen as an alternative option (so that we can order "LCD + resistive touch-screen" as a one module)?
(01-21-2016, 12:55 PM)genpix Wrote: can you support a resistive touch panels?
Why you need resistive touch panel? this is not a popular request.
we are manufacturing lab equipment.
All lab instruments (biotech, (semi)clean-room, optical, etc.) are using resistive touch screens.
It's a requirement.
You can not use capacitive touch screen if you are wearing gloves.
Added:
it make sense to move a discussion to the other thread (with similar question)
  7 inch LCD touch panel is upside down? joshpl 2 4,282 12-07-2023, 06:18 AM
Last Post: stormwyrm
  I2C Touch Panel mbt28 0 3,153 06-12-2017, 11:32 AM
Last Post: mbt28
  Armbian display manager issues modsbyus 0 4,060 02-08-2017, 06:18 PM
Last Post: modsbyus
  8inch display compatible to FY07024DI26A30-D mbt28 0 3,409 01-26-2017, 10:07 AM
Last Post: mbt28
  LCD touch panel emits low power Naccies 4 9,471 01-09-2017, 07:45 PM
  Touch screen support shariq_2001 14 29,357 12-07-2016, 07:47 AM
Last Post: Luke
  LCD Touch Screen Problem. Gavin 8 14,463 11-27-2016, 10:26 PM
Last Post: michaelquezon
  lcd and hdmi dual display jodybrown99 8 16,836 11-12-2016, 08:07 PM
Last Post: Chisel_86
  Touchscreen display mods atomicSoC 2 9,561 08-26-2016, 05:44 PM
Last Post: pfeerick
  Trouble with LCD display jdmwrx94 3 7,215 07-25-2016, 12:21 PM
