power Circuit
Is will possible to control the startup/shutdown of the Pin64, i think about a button connecting to some pin that manage software shutdown and  power circuit ?
(12-24-2015, 06:37 AM)polo Wrote: Is will possible to control the startup/shutdown of the Pin64, i think about a button connecting to some pin that manage software shutdown and  power circuit ?
Their is soft power switch option on the new rev B Pine A64 board (the board that deliver to developer on early January and to KS folks on February), Android OS already supported this switch. There is also a reset switch option on Rev B board. Another feature added on Rev B is UART console port.
Good to know I was wondering what the final power switch decision would be
(01-28-2016, 01:08 PM)Nilocsemliw Wrote: Good to know I was wondering what the final power switch decision would be
The button position is there. We don't stuff the button due to every case may has it owns button switch requirement such as short or long nose. If we solder a botton there, it is hard to get out and may damage the board if you are not good in soldering.
So the ability to have a switch will be there and we just need to solder the switch ourselves?
Hi tllim, so we won't be getting the button?
Can you advice what kind of button to use for us non-savvy users?
I'll want to have the buttons on hand when I receive the board.
(01-28-2016, 05:56 PM)SkimMilk Wrote: Hi tllim, so we won't be getting the button?
(01-28-2016, 05:44 PM)Nilocsemliw Wrote: So the ability to have a switch will be there and we just need to solder the switch ourselves?
That is correct.
Hi tllim, is this also for the reset button?
That is correct.
I am sorry I can't read Chinese characters. Could we wire the switch around 4 feet away from the board than?
Four *feet* away?? What are you housing it in? 'x3
  Z-Wave - Full and Low Power Inclusion mode B34N 1 7,312 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 7,517 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 24,312 01-05-2017, 12:37 AM
Last Post: swinging
  Power switch circuit drewh 43 100,519 09-19-2016, 09:17 AM
Last Post: tampadave
  Power Off / Reset Buttons - DietPi casmiguefl 4 14,047 08-12-2016, 05:28 PM
Last Post: casmiguefl
  Power over Ethernet (PoE) WLR 1 8,541 02-10-2016, 07:14 PM
  USB HDD Power eender 5 14,838 02-06-2016, 09:30 PM
Last Post: blktiger
