Camera is working on Linux
You need to enable the sensor in the DTS and compile it.
The lsmod looks just fine.
First, you need to find out which sensor you have, i doubt there is OV6650 (352- by 288-pixel array
??) for the pine.
Please, if you can share a picture of your sensor and FPC cable would be nice.
BTW, we need to ask @tllim about the slightly modified s5k4ec.ko in some Android build, i don't know who is in charge of that build, but Android SDK 2.0 has outdated driver. May be the visible artifacts shown can be fixed if we find additional info about this specific s5k4ec source code and the clock used.
Anyway, if someone can get that source code and timings used we can improve the driver.
The camera module looks like this https://www.flickr.com/photos/96700120@N...ateposted/ and when attached like this https://www.flickr.com/photos/96700120@N...ateposted/
I found some info about compiling DTS from sunxi-wiki, but didn't find any sufficient instructions on how to do it. How do I enable and compile it?
I am also stuck. What is the role of apt-get install v4l-utils here?
In which log should I see exactly what that this video device has been detected as micko also says.
@micko
That is s5k4ec , same as mine. You need to enable this device in the DTS and compile it
Where i am right now i don't have access to the board, tomorrow i can share my DTB (the compiled DTS) with this device enabled.
@Pander
v4l-utils are used get some info about the camera, set some parms,etc.
If you have s5k4ec enabled you should see some debugging message (dmesg), like [s5kec] init sensor... (something like that).
I will update the instructions and logs (and DTB) so it will easy the use of the camera, sorry i am out of town right now.
(06-30-2016, 04:29 AM)@lex Wrote: @micko
Thanks!
Is there a guide or something about the DTS and how to compile it? I'm guessing it's the *.dts in /boot/pine64/, but how do I modify that? It looks like a binary file. I am quite familiar with compiling stuff myself but this is something I've never heard of.
Here is Basic instructions, should work with Debian / Ubuntu.
https://github.com/avafinger/pine64_camera
I did as you instructed and loading the modules worked. My dmesg from that operation http://pastebin.com/8XE8iEaw
However starting guvcview crashes. Here's output on terminal http://pastebin.com/kN56b4AT
And here's dmesg from that http://pastebin.com/QCjn9bs9
So no camera for me yet...
dmesg tell us Camera was recognized and is OK!
You are almost there, so now tell us a bit more about guvciew, how did you install it?
Print the output:
  * uname -ra
 * lsb_release -a
 * cat /etc/*release
 * cat /proc/version
Edit: Forgot to say DTB is for HDMI
Sorry for the intrusion; hope things are working better... I am wondering if anyone who has the camera connected and recognized successfully might post a close-in pic so that everyone can see how the cable is connected, side-up, side-down, and maybe some tips on the method that 'you' used to open the connector (or if you even did open it) and what your experience with that was... tnx
marcus
@lex
Quote:dmesg tell us Camera was recognized and is OK!
What lines exactly tell us that the Camera was recognized and is OK?
Also in GitHub there is a file "camera.cfg" where does that belong?
  Anyone get the camera to work yet? Havensal 16 41,214 09-13-2022, 03:31 AM
Last Post: harryaxe31
  camera port details? gourmand007 6 21,776 03-07-2021, 05:29 PM
Last Post: DippingMyToesIn
  About the camera robopo 11 31,741 03-06-2021, 12:28 AM
  CSI / Camera Module Compatibility? vade 8 25,626 04-03-2020, 05:39 AM
Last Post: Ellesar Dragon
  13MP Camera cable extension saviod 2 8,879 06-21-2019, 06:05 AM
Last Post: saviod
  Camera Sasank 15 40,138 12-13-2018, 09:08 PM
Last Post: Mutani
  Himax 5 Megapixel Camera Module cannot fit into 7″ LCD Touch Screen Panel themyshop 3 11,512 05-10-2018, 04:28 PM
  Webcam vs camera module on pine64+ fkpkot 4 15,385 02-27-2017, 03:57 PM
Last Post: MarkHaysHarris777
  camera module and lcd integration jodybrown99 5 15,282 10-11-2016, 11:35 AM
Last Post: hikaricore
