07-17-2026, 04:47 PM
(This post was last modified: 07-18-2026, 04:36 AM by mara.)
installation README.TXT
kernel 6.6.144
mirror 1, mirror 2, mirror 3, mirror 4, mirror 5
irradium-3.8-riscv64-core-starpro64-6.6.144-build-20260717.img.zst
irradium-3.8-riscv64-core-starpro64-6.6.144-build-20260717.img.zst.sha256
irradium-3.8-riscv64-xfce-starpro64-6.6.144-build-20260717.img.zst
irradium-3.8-riscv64-xfce-starpro64-6.6.144-build-20260717.img.zst.sha256
kernel 7.2.0-rc3
irradium-3.8-riscv64-core-starpro64-7.2.0-rc3-build-20260717.img.zst
irradium-3.8-riscv64-core-starpro64-7.2.0-rc3-build-20260717.img.zst.sha256
irradium-3.8-riscv64-xfce-starpro64-7.2.0-rc3-build-20260717.img.zst
irradium-3.8-riscv64-xfce-starpro64-7.2.0-rc3-build-20260717.img.zst.sha256
Code: [ 0.000000] Booting Linux on hartid 3
[ 0.000000] Linux version 7.2.0-rc3 (root@irradium) (riscv64-unknown-linux-gnu-gcc (crosstool-NG 1.26.0) 13.2.0, GNU ld (crosstool-NG 1.26.0) 2.40) #1 SMP PREEMPT_DYNAMIC Fri Jul 17 22:54:03 UTC 2026
[ 0.000000] Machine model: Pine64 StarPro64
[ 0.000000] SBI specification v0.3 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x10000
[ 0.000000] SBI TIME extension detected
[ 0.000000] SBI IPI extension detected
[ 0.000000] SBI RFENCE extension detected
[ 0.000000] SBI SRST extension detected
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x00000002dfe00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x00000002dfe00000..0x00000002ffdfffff (524288 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x00000000dfff0000..0x00000000dfffffff (64 KiB) nomap non-reusable lpcpures@dfff0000
[ 0.000000] OF: reserved mem: 0x00000000e0000000..0x00000000e1ffffff (32768 KiB) nomap non-reusable region@e0000000
[ 0.000000] OF: reserved mem: 0x0000001000000000..0x00000010003fffff (4096 KiB) map non-reusable mmode_resv1@10,0
[ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) map non-reusable mmode_resv0@80000000
[ 0.000000] OF: reserved mem: 0x0000000059000000..0x00000000593fffff (4096 KiB) nomap non-reusable sprammemory@59000000
[ 0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable lpcpu@a0000000
[ 0.000000] OF: reserved mem: 0x00000000fffff000..0x00000000ffffffff (4 KiB) nomap non-reusable g2d_4GB_boundary_reserved_4k
[ 0.000000] OF: reserved mem: 0x00000001fffff000..0x00000001ffffffff (4 KiB) nomap non-reusable g2d_8GB_boundary_reserved_4k
[ 0.000000] OF: reserved mem: 0x00000002fffff000..0x00000002ffffffff (4 KiB) nomap non-reusable g2d_12GB_boundary_reserved_4k
[ 0.000000] OF: reserved mem: 0x0000000300000000..0x000000047fffffff (6291456 KiB) nomap non-reusable mmz_nid_0_part_0
[ 0.000000] SBI HSM extension detected
[ 0.000000] Using physical memory alias for noncached mappings
[ 0.000000] riscv: base ISA extensions acdfhim
[ 0.000000] riscv: ELF capabilities acdfim
[ 0.000000] Ticket spinlock: enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000059000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000059000000-0x00000000593fffff]
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009fffffff]
[ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000a00fffff]
[ 0.000000] node 0: [mem 0x00000000a0100000-0x00000000dffeffff]
[ 0.000000] node 0: [mem 0x00000000dfff0000-0x00000000e1ffffff]
[ 0.000000] node 0: [mem 0x00000000e2000000-0x00000000ffffefff]
[ 0.000000] node 0: [mem 0x00000000fffff000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffefff]
[ 0.000000] node 0: [mem 0x00000001fffff000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000200000000-0x00000002ffffefff]
[ 0.000000] node 0: [mem 0x00000002fffff000-0x000000047fffffff]
[ 0.000000] node 0: [mem 0x0000000480000000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000059000000-0x000000087fffffff]
[ 0.000000] On node 0, zone DMA32: 4096 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA32: 27648 pages in unavailable ranges
[ 0.000000] percpu: Embedded 54 pages/cpu s97368 r8192 d115624 u221184
[ 0.000000] pcpu-alloc: s97368 r8192 d115624 u221184 alloc=54*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Kernel command line: root=UUID=32539e08-a5c0-4084-9f32-0932043d95e3 ro rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty1 consoleblank=0 loglevel=4 earlycon=sbi clk_ignore_unused usb-storage.quirks= rootdelay=2 clk_ignore_unused
[ 0.000000] printk: log buffer data + meta data: 262144 + 1114112 = 1376256 bytes
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8389632
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Dynamic Preempt: full
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] riscv-intc: 64 local interrupts mapped
[ 0.000000] riscv: providing IPIs using SBI IPI extension
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 3526361616960 ns
[ 0.000002] sched_clock: 64 bits at 1000kHz, resolution 1000ns, wraps every 2199023255500ns
[ 0.000940] Console: colour dummy device 80x25
[ 0.000961] printk: legacy console [tty1] enabled
[ 0.001122] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000)
[ 0.001139] pid_max: default: 32768 minimum: 301
[ 0.004514] landlock: Up and running.
[ 0.004526] Yama: becoming mindful.
[ 0.005019] AppArmor: AppArmor initialized
[ 0.006714] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.006801] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.008217] VFS: Finished mounting rootfs on nullfs
[ 0.014629] ASID allocator disabled (0 bits)
[ 0.014981] rcu: Hierarchical SRCU implementation.
[ 0.014992] rcu: Max phase no-delay instances is 1000.
[ 0.015510] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.016298] EFI services will not be available.
[ 0.017143] smp: Bringing up secondary CPUs ...
[ 0.021599] smp: Brought up 1 node, 4 CPUs
[ 0.021982] Memory: 25984528K/33558528K available (13703K kernel code, 8735K rwdata, 8192K rodata, 6410K init, 1283K bss, 7042076K reserved, 524288K cma-reserved)
[ 0.027311] devtmpfs: initialized
[ 0.044252] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.044308] futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
[ 0.052299] DMI: not present or invalid.
[ 0.054359] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.055222] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.055295] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.055398] audit: initializing netlink subsys (disabled)
[ 0.055773] audit: type=2000 audit(0.052:1): state=initialized audit_enabled=0 res=1
[ 0.056435] thermal_sys: Registered thermal governor 'fair_share'
[ 0.056448] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.056454] thermal_sys: Registered thermal governor 'step_wise'
[ 0.056458] thermal_sys: Registered thermal governor 'user_space'
[ 0.056463] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.056613] cpuidle: using governor ladder
[ 0.056686] cpuidle: using governor menu
[ 0.057293] CCACHE: 4 banks, 16 ways, sets/bank=1024, bytes/block=64
[ 0.057307] CCACHE: Index of the largest way enabled: 15
[ 0.065987] /soc/i2c@50950000/es8388-0@10: Fixed dependency cycle(s) with /soc/i2s1@50210000
[ 0.066371] /soc/i2s0@50200000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[ 0.066390] /soc/i2s1@50210000: Fixed dependency cycle(s) with /soc/i2c@50950000/es8388-0@10
[ 0.066418] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[ 0.066429] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/es_wb
[ 0.066442] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/mipi_dsi@50270000
[ 0.066475] /soc/es_wb: Fixed dependency cycle(s) with /soc/display_control@502c0000
[ 0.066500] /soc/mipi_dsi@50270000: Fixed dependency cycle(s) with /soc/display_control@502c0000
[ 0.066521] /soc/hdmi@502a0000: Fixed dependency cycle(s) with /soc/i2s0@50200000
[ 0.066538] /soc/hdmi@502a0000: Fixed dependency cycle(s) with /soc/display_control@502c0000
[ 0.066617] /soc/csidma@0x52048000: Fixed dependency cycle(s) with /soc/csi2@51050000
[ 0.066639] /soc/csi2@51050000: Fixed dependency cycle(s) with /soc/csidma@0x52048000
[ 0.135450] /soc/i2c@50950000/es8388-0@10: Fixed dependency cycle(s) with /soc/i2s1@50210000
[ 0.136936] eswin-pinctrl 51600080.pinctrl: eswin pinctrl initialized
[ 0.138597] /soc/i2s0@50200000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[ 0.138755] /soc/i2c@50950000/es8388-0@10: Fixed dependency cycle(s) with /soc/i2s1@50210000
[ 0.138796] /soc/i2s1@50210000: Fixed dependency cycle(s) with /soc/i2c@50950000/es8388-0@10
[ 0.139122] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[ 0.139135] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/es_wb
[ 0.139147] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/mipi_dsi@50270000
[ 0.139320] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/es_wb
[ 0.139360] /soc/es_wb: Fixed dependency cycle(s) with /soc/display_control@502c0000
[ 0.139532] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/mipi_dsi@50270000
[ 0.139573] /soc/mipi_dsi@50270000: Fixed dependency cycle(s) with /soc/display_control@502c0000
[ 0.139774] /soc/display_control@502c0000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[ 0.139841] /soc/i2s0@50200000: Fixed dependency cycle(s) with /soc/hdmi@502a0000
[ 0.139878] /soc/hdmi@502a0000: Fixed dependency cycle(s) with /soc/i2s0@50200000
[ 0.139916] /soc/hdmi@502a0000: Fixed dependency cycle(s) with /soc/display_control@502c0000
[ 0.141286] /soc/csidma@0x52048000: Fixed dependency cycle(s) with /soc/csi2@51050000
[ 0.141413] /soc/csidma@0x52048000: Fixed dependency cycle(s) with /soc/csi2@51050000
[ 0.141466] /soc/csi2@51050000: Fixed dependency cycle(s) with /soc/csidma@0x52048000
[ 0.149758] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.149766] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.149772] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.149776] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.159996] iommu: Default domain type: Translated
[ 0.160003] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.160736] SCSI subsystem initialized
[ 0.160833] libata version 3.00 loaded.
[ 0.160996] usbcore: registered new interface driver usbfs
[ 0.161020] usbcore: registered new interface driver hub
[ 0.161040] usbcore: registered new device driver usb
[ 0.161087] pps_core: LinuxPPS API ver. 1 registered
[ 0.161092] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.161102] PTP clock support registered
[ 0.161139] EDAC MC: Ver: 3.0.0
[ 0.162287] NetLabel: Initializing
[ 0.162293] NetLabel: domain hash size = 128
[ 0.162298] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.162340] NetLabel: unlabeled traffic allowed by default
[ 0.162603] mctp: management component transport protocol core
[ 0.162609] NET: Registered PF_MCTP protocol family
[ 0.162737] vgaarb: loaded
[ 0.162946] clocksource: Switched to clocksource riscv_clocksource
[ 0.165488] VFS: Disk quotas dquot_6.6.0
[ 0.165618] VFS: Dquot-cache hash table entries: 512 (4096 bytes)
[ 0.166736] AppArmor: AppArmor Filesystem Enabled
[ 0.173879] NET: Registered PF_INET protocol family
[ 0.174281] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.186327] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.186423] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.186456] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.187249] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.188140] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.188547] MPTCP token hash table entries: 32768 (order: 8, 786432 bytes, linear)
[ 0.188810] UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 0.189452] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.189488] NET: Registered PF_XDP protocol family
[ 0.189508] PCI: CLS 0 bytes, default 64
[ 0.189617] kvm [1]: hypervisor extension available
[ 0.189623] kvm [1]: highest G-stage page table mode is Sv48x4
[ 0.189628] kvm [1]: VMID 0 bits available
[ 0.189833] Trying to unpack rootfs image as initramfs...
[ 0.194552] Initialise system trusted keyrings
[ 0.194634] Key type blacklist registered
[ 0.194806] workingset: timestamp_bits=46 (anon: 41) max_order=23 bucket_order=0 (anon: 0)
[ 0.205658] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.208419] fuse: init (API version 7.45)
[ 0.209147] integrity: Platform Keyring initialized
[ 0.209185] integrity: Machine keyring initialized
[ 0.248486] Key type asymmetric registered
[ 0.248496] Asymmetric key parser 'x509' registered
[ 0.248727] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.248897] io scheduler mq-deadline registered
[ 0.250416] riscv-plic: interrupt-controller@c000000: mapped 521 interrupts with 4 handlers for 8 contexts.
[ 0.251446] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.252635] eswin-pcie 54000000.pcie: host bridge /soc/pcie@0x54000000 ranges:
[ 0.252667] eswin-pcie 54000000.pcie: IO 0x0040800000..0x0040ffffff -> 0x0040800000
[ 0.252688] eswin-pcie 54000000.pcie: MEM 0x0041000000..0x004fffffff -> 0x0041000000
[ 0.252700] eswin-pcie 54000000.pcie: MEM 0x8000000000..0x81ffffffff -> 0x8000000000
[ 0.367060] eswin-pcie 54000000.pcie: iATU: unroll T, 8 ob, 4 ib, align 4K, limit 8G
[ 0.445872] Freeing initrd memory: 9144K
[ 0.566962] eswin-pcie 54000000.pcie: PCIe Gen.3 x4 link up
[ 0.567792] eswin-pcie 54000000.pcie: PCI host bridge to bus 0000:00
[ 0.567805] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.567814] pci_bus 0000:00: root bus resource [io 0x0000-0x7fffff] (bus address [0x40800000-0x40ffffff])
[ 0.567821] pci_bus 0000:00: root bus resource [mem 0x41000000-0x4fffffff]
[ 0.567827] pci_bus 0000:00: root bus resource [mem 0x8000000000-0x81ffffffff pref]
[ 0.567877] pci 0000:00:00.0: [1fe1:2030] type 01 class 0x060400 PCIe Root Port
[ 0.567895] pci 0000:00:00.0: BAR 0 [mem 0x00000000-0x07ffffff]
[ 0.567902] pci 0000:00:00.0: BAR 1 [mem 0x00000000-0x000fffff]
[ 0.567909] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.567918] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff]
[ 0.567924] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 0.567934] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff 64bit pref]
[ 0.567993] pci 0000:00:00.0: supports D1 D2
[ 0.567999] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 0.571223] pci 0000:01:00.0: [1cc1:8201] type 00 class 0x010802 PCIe Endpoint
[ 0.571333] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00003fff 64bit]
[ 0.571364] pci 0000:01:00.0: Upstream bridge's Max Payload Size set to 256 (was 512, max 512)
[ 0.571377] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 256)
[ 0.578965] pci 0000:01:00.0: ASPM: default states L1
[ 0.579015] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.579052] pci 0000:00:00.0: BAR 0 [mem 0x48000000-0x4fffffff]: assigned
[ 0.579062] pci 0000:00:00.0: BAR 1 [mem 0x41000000-0x410fffff]: assigned
[ 0.579069] pci 0000:00:00.0: bridge window [mem 0x41100000-0x411fffff]: assigned
[ 0.579078] pci 0000:01:00.0: BAR 0 [mem 0x41100000-0x41103fff 64bit]: assigned
[ 0.579086] pci 0000:01:00.0: BAR 0: error updating (0x41100004 != 0xffffffff)
[ 0.579101] fbcon: Taking over console
[ 0.579135] pci 0000:01:00.0: BAR 0: error updating (high 0x00000000 != 0xffffffff)
[ 0.579148] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.579155] pci 0000:00:00.0: bridge window [mem 0x41100000-0x411fffff]
[ 0.579164] pci_bus 0000:00: resource 4 [io 0x0000-0x7fffff]
[ 0.579170] pci_bus 0000:00: resource 5 [mem 0x41000000-0x4fffffff]
[ 0.579176] pci_bus 0000:00: resource 6 [mem 0x8000000000-0x81ffffffff pref]
[ 0.579182] pci_bus 0000:01: resource 1 [mem 0x41100000-0x411fffff]
[ 0.579672] pcieport 0000:00:00.0: PME: Signaling with IRQ 13
[ 0.579933] pcieport 0000:00:00.0: AER: enabled with IRQ 13
[ 0.581725] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.583280] printk: legacy console [ttyS0] disabled
[ 0.603564] 50900000.serial: ttyS0 at MMIO 0x50900000 (irq = 14, base_baud = 12500000) is a 16550A
[ 0.603609] printk: legacy console [ttyS0] enabled
[ 0.639466] 50910000.serial: ttyS1 at MMIO 0x50910000 (irq = 15, base_baud = 12500000) is a 16550A
[ 0.660110] 50920000.serial: ttyS2 at MMIO 0x50920000 (irq = 16, base_baud = 12500000) is a 16550A
[ 0.666958] loop: module loaded
[ 0.667549] SCSI Media Changer driver v0.25
[ 0.668250] tun: Universal TUN/TAP device driver, 1.6
[ 0.668374] PPP generic driver version 2.4.2
[ 0.668819] dwc3-generic-plat soc:usb0@50480000: missing memory resource
[ 0.678165] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.678182] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 0.678582] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe45 hci version 0x110 quirks 0x0000808000000010
[ 0.678611] xhci-hcd xhci-hcd.0.auto: irq 17, io mem 0x50480000
[ 0.678731] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 0.678741] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 0.678750] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 0.678913] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.02
[ 0.678923] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.678929] usb usb1: Product: xHCI Host Controller
[ 0.678935] usb usb1: Manufacturer: Linux 7.2.0-rc3 xhci-hcd
[ 0.678956] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 0.679296] hub 1-0:1.0: USB hub found
[ 0.679350] hub 1-0:1.0: 1 port detected
[ 0.679635] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.679716] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.02
[ 0.679725] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.679731] usb usb2: Product: xHCI Host Controller
[ 0.679737] usb usb2: Manufacturer: Linux 7.2.0-rc3 xhci-hcd
[ 0.679742] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 0.680015] hub 2-0:1.0: USB hub found
[ 0.680037] hub 2-0:1.0: 1 port detected
[ 0.680380] usbcore: registered new interface driver uas
[ 0.680449] usbcore: registered new interface driver usb-storage
[ 0.680478] usbcore: registered new interface driver ums-alauda
[ 0.680505] usbcore: registered new interface driver ums-cypress
[ 0.680548] usbcore: registered new interface driver ums-datafab
[ 0.680576] usbcore: registered new interface driver ums_eneub6250
[ 0.680602] usbcore: registered new interface driver ums-freecom
[ 0.680644] usbcore: registered new interface driver ums-isd200
[ 0.680672] usbcore: registered new interface driver ums-jumpshot
[ 0.680698] usbcore: registered new interface driver ums-karma
[ 0.680724] usbcore: registered new interface driver ums-onetouch
[ 0.680751] usbcore: registered new interface driver ums-realtek
[ 0.680777] usbcore: registered new interface driver ums-sddr09
[ 0.680804] usbcore: registered new interface driver ums-sddr55
[ 0.680846] usbcore: registered new interface driver ums-usbat
[ 0.681027] mousedev: PS/2 mouse device common for all mice
[ 0.681036] i2c_dev: i2c /dev entries driver
[ 0.681200] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 0.681318] device-mapper: uevent: version 1.0.3
[ 0.681519] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[ 0.681612] EDAC DEVICE0: Giving out device to module Sifive ECC Manager controller sifive_edac.0: DEV sifive_edac.0 (INTERRUPT)
[ 0.683561] riscv-pmu-sbi: SBI PMU extension is available
[ 0.683596] riscv-pmu-sbi: 15 firmware and 6 hardware counters
[ 0.686349] drop_monitor: Initializing network drop monitor service
[ 0.687244] NET: Registered PF_INET6 protocol family
[ 0.688236] Segment Routing with IPv6
[ 0.688265] In-situ OAM (IOAM) with IPv6
[ 0.688322] NET: Registered PF_PACKET protocol family
[ 0.688406] Key type dns_resolver registered
[ 0.706159] cpu0: scalar unaligned word access speed is 0.00x byte access speed (slow)
[ 0.706166] cpu1: scalar unaligned word access speed is 0.00x byte access speed (slow)
[ 0.706169] cpu3: scalar unaligned word access speed is 0.00x byte access speed (slow)
[ 0.706173] cpu2: scalar unaligned word access speed is 0.00x byte access speed (slow)
[ 0.710864] registered taskstats version 1
[ 0.711704] Loading compiled-in X.509 certificates
[ 0.712921] Loaded X.509 cert 'Build time autogenerated kernel key: 15a8b74936898510ca5af0403a4a80ba6fccc350'
[ 0.726694] Key type .fscrypt registered
[ 0.726704] Key type fscrypt-provisioning registered
[ 0.746951] mmc0: SDHCI controller on 50450000.mmc [50450000.mmc] using ADMA 64-bit
[ 0.750145] Key type encrypted registered
[ 0.750155] AppArmor: AppArmor sha256 policy hashing enabled
[ 0.750165] ima: No TPM chip found, activating TPM-bypass!
[ 0.750181] Loading compiled-in module X.509 certificates
[ 0.751224] Loaded X.509 cert 'Build time autogenerated kernel key: 15a8b74936898510ca5af0403a4a80ba6fccc350'
[ 0.751232] ima: Allocated hash algorithm: sha256
[ 0.751288] ima: No architecture policies found
[ 0.751330] evm: Initialising EVM extended attributes:
[ 0.751334] evm: security.selinux
[ 0.751338] evm: security.SMACK64
[ 0.751341] evm: security.SMACK64EXEC
[ 0.751345] evm: security.SMACK64TRANSMUTE
[ 0.751349] evm: security.SMACK64MMAP
[ 0.751352] evm: security.apparmor
[ 0.751356] evm: security.ima
[ 0.751359] evm: security.capability
[ 0.751363] evm: HMAC attrs: 0x1
[ 0.769483] clk: Not disabling unused clocks
[ 0.810954] mmc2: SDHCI controller on 50470000.mmc [50470000.mmc] using ADMA 64-bit
[ 0.810960] mmc1: SDHCI controller on 50460000.mmc [50460000.mmc] using ADMA 64-bit
[ 0.814514] Freeing unused kernel image (initmem) memory: 6408K
[ 0.821884] Checked W+X mappings: passed, no W+X pages found
[ 0.821924] Run /init as init process
[ 0.821928] with arguments:
[ 0.821933] /init
[ 0.821936] with environment:
[ 0.821940] HOME=/
[ 0.821944] TERM=linux
[ 0.834140] udevd[100]: starting version 3.2.14
[ 0.897640] mmc1: new UHS-I speed SDR104 SDXC card at address 5048
[ 0.898051] mmcblk1: mmc1:5048 SD64G 58.0 GiB
[ 0.903320] mmcblk1: p1 p2
[ 0.927382] mmc0: Failed to initialize a non-removable card
[ 0.991351] mmc2: Failed to initialize a non-removable card
[ 6.658953] random: crng init done
[ 6.662596] udevd[106]: starting eudev-3.2.14
[ 6.664389] udevd[110]: failed to execute '/usr/sbin/nfsrahead' '/usr/sbin/nfsrahead 179:0': No such file or directory
[ 8.823490] EXT4-fs (mmcblk1p2): mounted filesystem 32539e08-a5c0-4084-9f32-0932043d95e3 ro without journal. Quota mode: none.
[ 8.831400] raid6: using intx1 recovery algorithm
[ 8.898944] raid6: int64x1 gen() 2753 MB/s
[ 8.966951] raid6: int64x2 gen() 3146 MB/s
[ 9.034942] raid6: int64x4 gen() 3058 MB/s
[ 9.102947] raid6: int64x8 gen() 2107 MB/s
[ 9.102951] raid6: using algorithm int64x2 gen() 3146 MB/s
[ 9.170945] raid6: .... xor() 1674 MB/s, rmw enabled
[ 9.180921] xor: measuring software checksum speed
[ 9.181504] 32regs : 5705 MB/sec
[ 9.182078] 8regs : 5786 MB/sec
[ 9.182082] xor: using function: 8regs (5786 MB/sec)
[ 9.333645] Btrfs loaded, zoned=yes, fsverity=yes
[ 9.658655] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[ 10.979583] ------------[ cut here ]------------
[ 10.979590] WARNING: kernel/irq/manage.c:1502 at __setup_irq+0x40a/0x6d6, CPU#3: kworker/u16:4/94
[ 10.979601] Modules linked in: xfs btrfs xor libblake2b raid6_pq
[ 10.979618] CPU: 3 UID: 0 PID: 94 Comm: kworker/u16:4 Not tainted 7.2.0-rc3 #1 PREEMPT(full)
[ 10.979623] Hardware name: Pine64 StarPro64 (DT)
[ 10.979626] Workqueue: events_unbound deferred_probe_work_func
[ 10.979640] epc : __setup_irq+0x40a/0x6d6
[ 10.979644] ra : __setup_irq+0x30/0x6d6
[ 10.979647] epc : ffffffff800dd51c ra : ffffffff800dd142 sp : ffff8f8000a93980
[ 10.979650] gp : ffffffff82299c20 tp : ffffaf80a8c95a00 t0 : ffffaf80a87f2700
[ 10.979653] t1 : 0000000000000000 t2 : 0000000000000000 s0 : ffff8f8000a939e0
[ 10.979656] s1 : ffffaf80a7a6ca00 a0 : 0000000000000001 a1 : 0000000000000000
[ 10.979659] a2 : 0000000000000000 a3 : 0000000000000400 a4 : 0000000000000000
[ 10.979662] a5 : 0000000000002004 a6 : 0000000000000000 a7 : e219567d37232e33
[ 10.979665] s2 : ffffaf80a87f2680 s3 : 000000000000001a s4 : 0000000000000000
[ 10.979668] s5 : 0000000000000000 s6 : ffffaf80a7beba80 s7 : 0000000000002004
[ 10.979671] s8 : ffffaf80a7a6ca30 s9 : ffffaf80a7a6ca00 s10: 0000000000000000
[ 10.979674] s11: 0000000000000000 t3 : 0000000000000000 t4 : 0000000000000000
[ 10.979677] t5 : 0000000000000000 t6 : 0000000000000000 ssp : 0000000000000000
[ 10.979680] status: 0000000200000120 badaddr: 0000000000000000 cause: 0000000000000003
[ 10.979683] [<ffffffff800dd51c>] __setup_irq+0x40a/0x6d6
[ 10.979688] [<ffffffff800dd8e0>] request_threaded_irq+0xf8/0x1b0
[ 10.979692] [<ffffffff800e0bb8>] devm_request_threaded_irq+0x60/0xec
[ 10.979700] [<ffffffff80a3d986>] eswin_fan_control_probe+0x162/0x3c8
[ 10.979707] [<ffffffff80889356>] platform_probe+0x46/0x7e
[ 10.979713] [<ffffffff8088628c>] really_probe+0x8c/0x394
[ 10.979720] [<ffffffff80886604>] __driver_probe_device+0x70/0x162
[ 10.979726] [<ffffffff808867be>] driver_probe_device+0x30/0x9e
[ 10.979732] [<ffffffff808868a8>] __device_attach_driver+0x7c/0x104
[ 10.979737] [<ffffffff80883ed8>] bus_for_each_drv+0x66/0xc6
[ 10.979742] [<ffffffff80886c92>] __device_attach+0x84/0x178
[ 10.979748] [<ffffffff80886f6c>] device_initial_probe+0x46/0x48
[ 10.979754] [<ffffffff80884f24>] bus_probe_device+0x24/0x84
[ 10.979759] [<ffffffff808855e2>] deferred_probe_work_func+0x90/0xfe
[ 10.979764] [<ffffffff80078426>] process_one_work+0x122/0x390
[ 10.979777] [<ffffffff80078d1e>] worker_thread+0x132/0x282
[ 10.979783] [<ffffffff800809b8>] kthread+0xde/0x100
[ 10.979793] [<ffffffff800156b0>] ret_from_fork_kernel+0x1a/0x23c
[ 10.979805] [<ffffffff80d63cfa>] ret_from_fork_kernel_asm+0x16/0x18
[ 10.979815] ---[ end trace 0000000000000000 ]---
[ 10.979848] eswin_fan_control_driver 50b50000.fan_control: Failed to request pwm device: -517
[ 10.988465] platform 51800000.spi: deferred probe pending: platform: wait for supplier /soc/gpio@51600000/gpio-port@3
[ 10.988474] platform soc:usb1@50490000: deferred probe pending: platform: wait for supplier /soc/gpio@51600000/gpio-port@1
[ 10.988479] platform 50b50000.fan_control: deferred probe pending: (reason unknown)
[ 13.930335] udevd[161]: starting version 3.2.14
[ 13.991373] udevd[162]: starting eudev-3.2.14
[ 14.107271] dw_axi_dmac_platform 50430000.dma-controller-hsp: probe with driver dw_axi_dmac_platform failed with error -2
[ 14.112864] eswin_fan_control_driver 50b50000.fan_control: state.period: 100000 state.duty_cycle: 99609
[ 14.113982] hwmon hwmon0: temp1_input not attached to any thermal zone
[ 14.115718] hwmon hwmon1: temp1_input not attached to any thermal zone
[ 14.118402] dw_axi_dmac_platform 518c0000.dma-controller-aon: probe with driver dw_axi_dmac_platform failed with error -2
[ 14.118510] eswin_fan_control_driver 50b50000.fan_control: eswin fan control init done
[ 14.125307] eswin-rtc 51818000.rtc: registered as rtc0
[ 14.125315] eswin-rtc 51818000.rtc: setting system clock to 1970-01-01T00:00:00 UTC (0)
[ 14.176381] eswin-bootspi 51800000.spi: ssi_max_xfer_size=32
[ 14.176596] eswin-bootspi 51800000.spi: fifo_len 256, polling mode.
[ 14.176732] dwc3-generic-plat soc:usb1@50490000: missing memory resource
[ 14.185021] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 14.185038] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
[ 14.185456] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe45 hci version 0x110 quirks 0x0000808000000010
[ 14.185490] xhci-hcd xhci-hcd.2.auto: irq 62, io mem 0x50490000
[ 14.185579] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 14.185587] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 4
[ 14.185595] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 14.185709] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.02
[ 14.185717] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.185723] usb usb3: Product: xHCI Host Controller
[ 14.185727] usb usb3: Manufacturer: Linux 7.2.0-rc3 xhci-hcd
[ 14.185732] usb usb3: SerialNumber: xhci-hcd.2.auto
[ 14.186683] hub 3-0:1.0: USB hub found
[ 14.186725] hub 3-0:1.0: 1 port detected
[ 14.187141] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 14.187210] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.02
[ 14.187217] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 14.187222] usb usb4: Product: xHCI Host Controller
[ 14.187227] usb usb4: Manufacturer: Linux 7.2.0-rc3 xhci-hcd
[ 14.187231] usb usb4: SerialNumber: xhci-hcd.2.auto
[ 14.187475] hub 4-0:1.0: USB hub found
[ 14.187494] hub 4-0:1.0: 1 port detected
[ 14.215769] eic7700-eth-dwmac 50400000.ethernet: Deprecated MDIO bus assumption used
[ 14.215794] OF: /soc/ethernet@50400000/stmmac-axi-config: Read of boolean property 'snps,lpi_en' with a value.
[ 14.215826] eic7700-eth-dwmac 50400000.ethernet: PTP uses main clock
[ 14.216116] eic7700-eth-dwmac 50400000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[ 14.216125] eic7700-eth-dwmac 50400000.ethernet: DWMAC4/5
[ 14.216132] eic7700-eth-dwmac 50400000.ethernet: DMA HW capability register supported
[ 14.216137] eic7700-eth-dwmac 50400000.ethernet: Active PHY interface: RGMII (1)
[ 14.216142] eic7700-eth-dwmac 50400000.ethernet: RX Checksum Offload Engine supported
[ 14.216147] eic7700-eth-dwmac 50400000.ethernet: TX Checksum insertion supported
[ 14.216151] eic7700-eth-dwmac 50400000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 14.216157] eic7700-eth-dwmac 50400000.ethernet: Enabled L3L4 Flow TC (entries=4)
[ 14.216162] eic7700-eth-dwmac 50400000.ethernet: Enabled RFS Flow TC (entries=10)
[ 14.216167] eic7700-eth-dwmac 50400000.ethernet: platform requests unsupported TSO
[ 14.216173] eic7700-eth-dwmac 50400000.ethernet: Using 48/48 bits DMA host/device width
[ 14.234121] nvme 0000:01:00.0: of_irq_parse_pci: failed with rc=134
[ 14.241261] nvme nvme0: pci function 0000:01:00.0
[ 14.241274] nvme 0000:01:00.0: Unable to change power state from D3cold to D0, device inaccessible
[ 14.250459] nvme 0000:01:00.0: error -ENODEV: probe failed
[ 14.435047] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 14.477514] YT8531 Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 14.478359] eic7700-eth-dwmac 50410000.ethernet: Deprecated MDIO bus assumption used
[ 14.478393] OF: /soc/ethernet@50410000/stmmac-axi-config: Read of boolean property 'snps,lpi_en' with a value.
[ 14.478427] eic7700-eth-dwmac 50410000.ethernet: PTP uses main clock
[ 14.478642] eic7700-eth-dwmac 50410000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[ 14.478650] eic7700-eth-dwmac 50410000.ethernet: DWMAC4/5
[ 14.478656] eic7700-eth-dwmac 50410000.ethernet: DMA HW capability register supported
[ 14.478661] eic7700-eth-dwmac 50410000.ethernet: Active PHY interface: RGMII (1)
[ 14.478666] eic7700-eth-dwmac 50410000.ethernet: RX Checksum Offload Engine supported
[ 14.478670] eic7700-eth-dwmac 50410000.ethernet: TX Checksum insertion supported
[ 14.478675] eic7700-eth-dwmac 50410000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 14.478683] eic7700-eth-dwmac 50410000.ethernet: device MAC address 96:78:e6:73:cc:e0
[ 14.478689] eic7700-eth-dwmac 50410000.ethernet: Enabled L3L4 Flow TC (entries=4)
[ 14.478694] eic7700-eth-dwmac 50410000.ethernet: Enabled RFS Flow TC (entries=10)
[ 14.478699] eic7700-eth-dwmac 50410000.ethernet: platform requests unsupported TSO
[ 14.478704] eic7700-eth-dwmac 50410000.ethernet: Using 48/48 bits DMA host/device width
[ 14.576085] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
[ 14.576098] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 14.576104] usb 3-1: Product: USB2.0 Hub
[ 14.633851] hub 3-1:1.0: USB hub found
[ 14.634098] hub 3-1:1.0: 4 ports detected
[ 14.700896] YT8531 Gigabit Ethernet stmmac-1:00: attached PHY driver (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 14.761174] EXT4-fs: Remounting file system with no journal so ignoring journalled data option
[ 14.779902] EXT4-fs (mmcblk1p2): re-mounted 32539e08-a5c0-4084-9f32-0932043d95e3 r/w.
[ 14.816034] EXT4-fs (mmcblk1p1): mounted filesystem 5c205338-1b02-4bc9-a396-dc0fe556357f r/w with ordered data mode. Quota mode: none.
[ 14.828357] Adding 131068k swap on /swap. Priority:5 extents:2 across:139260k SS
[ 14.918973] usb 3-1.3: new high-speed USB device number 3 using xhci-hcd
[ 15.011344] usb 3-1.3: New USB device found, idVendor=0bda, idProduct=b812, bcdDevice= 2.10
[ 15.011359] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 15.011365] usb 3-1.3: Product: USB3.0 802.11ac 1200M Adapter
[ 15.011370] usb 3-1.3: Manufacturer: Realtek
[ 15.011374] usb 3-1.3: SerialNumber: 123456
[ 15.175137] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 15.175801] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 15.176121] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 15.182951] faux_driver regulatory: Direct firmware load for regulatory.db failed with error -2
[ 15.182968] cfg80211: failed to load regulatory.db
The jump from 6.6.138 to 6.6.157 then 6.6.159 across those builds is a bit odd since 6.6.138 is the lowest number but listed last with the newest date. Anyone know whether the 20261030 image is actually ahead of the 6.6.159 build in terms of fixes, or is the kernel number just tracking a separate branch? I'd want to compare the core and xfce images before flashing, and the sha256 files being separate is helpful for checking integrity after download.
The 6.6.15x kernel versions are based on a rather old release from the vendor.
The 6.6.138 kernel version is the current, ongoing release from Eswin.
