slight bumps causing phone to turn off.
Hi, My ppp started being super sensitive to any bumps, or too much pressure on it and I don't know why. if i slightly bump it or barely tap it against something it will immediately stop working and the screen will go blank, I don't think it's completely off because the screen, though black, still is slightly back lit. I've also found that if i even squeeze the phone slightly it does the same thing. I then have to turn it off, and then back on, which is not easy. I have to pop the battery out and back in, shake it, and sometimes tap on the back of it while holding the power button to get it to come back on, and then more often than not, it starts to boot, and then gets stuck, and  I have to repeat the process until it turns back on. im not sure what happened to cause this, I thought at first the battery was not making good contact with the terminals in the phone, but that isnt it. its like something is loose but im not sure where to begin in fixing it, has anyone else had this issue? are there any suggestions? Any help will be very much appreciated as my ppp is pretty much completely unusable right now. Thanks!
(11-11-2025, 01:16 PM)JadenSki Wrote: Hi, My ppp started being super sensitive to any bumps, or too much pressure on it and I don't know why. if i slightly bump it or barely tap it against something it will immediately stop working and the screen will go blank, I don't think it's completely off because the screen, though black, still is slightly back lit. I've also found that if i even squeeze the phone slightly it does the same thing. I then have to turn it off, and then back on, which is not easy. I have to pop the battery out and back in, shake it, and sometimes tap on the back of it while holding the power button to get it to come back on, and then more often than not, it starts to boot, and then gets stuck, and  I have to repeat the process until it turns back on. im not sure what happened to cause this, I thought at first the battery was not making good contact with the terminals in the phone, but that isnt it. its like something is loose but im not sure where to begin in fixing it, has anyone else had this issue? are there any suggestions? Any help will be very much appreciated as my ppp is pretty much completely unusable right now. Thanks!
Ihave a similar problem where I cant get the PPpro to boot unless I squeeze or strike it, it is caused by the RF shield on the top above the square modem-CPU shield to the left of the silkscreened PinephonePro text on the PCB breaking free of the solder.  Good old fashioned lead solder is pretty amazing stuff vs this tin alloy.
To be clear I suspect something on your PCB but it might not be the sae issue as mine, I ordered a new PCB form the store because the problem also prevents me waking from standby.
[Image: PPP-mainboard-nanosim-1.jpg]
(11-11-2025, 01:51 PM)Thank you so much for the prompt response, I will look and see if thats my issue as wellbiketool Wrote:
  No phone call audio, logs posted, modem can't init audio? biketool 12 5,850 12-22-2025, 05:09 PM
  New out of box phone, vibrates and solid red light on charging StuckInTheCloud 1 3,817 03-24-2023, 03:12 PM
Last Post: fxc
  Question on the keyboard battery with phone knoxvilles_joker 0 3,255 08-27-2022, 12:04 AM
Last Post: knoxvilles_joker
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 19,306 06-15-2022, 02:32 AM
Last Post: fxc
  Pine Store : Pine phone Pro Parts ? bcnaz 7 11,429 04-08-2022, 09:45 PM
Last Post: bcnaz
  Pine Phone Pro issues gmastap 0 3,138 03-14-2022, 07:21 AM
Last Post: gmastap
  Yet Another PPP That Won't Turn On thismarty 13 18,138 03-11-2022, 11:26 AM
Last Post: tckosvic
