incorporate a multimeter into the Pinecil
When looking at the schematic for the Pinecil I don’t think I see any open gpio pins, but I was bored and was curious to see what you guys thought about trying to incorporate a multimeter into the Pinecil. Has anyone attempted adding anything like this?
I had the same idea.
Below I will share my thoughts after a quick datasheet read for V1.
You might be able to repurpose the tip sensing mechanism although the measurement range would go from 0-0.01V without further voltage deviders. After that the Opamp will Saturate.
And I don't know if the driver for the tip would interfere.
Otherwise you defenitly need to use an addon board there are at least 3 pins routed to the usb port which can be used with ADCs.
Without additional circuitry you would only be able to measure 0-3.3v (presumably, didn't find any information on VREF and the QFN36 package).
Using the usb Port you could even create an osciloscope and display it on a Phone or PC.
12Mbit/s /16Bit/sample = 750ksamples or 1Msample/s with 12bit for a single channel minus usb overhead.
(07-31-2025, 03:39 PM)hinomi Wrote: I had the same idea.
And I don't know if the driver for the tip would interfere fnaf 2.
  Pinecil as a Pocket-Sized Wingman? Arsen 0 240 08-27-2026, 09:15 AM
Last Post: Arsen
  Question about firmware updates on Pinecil V2 helengrace 1 2,374 10-16-2025, 10:41 PM
Lightbulb Pinecil -> Pinegun? Avamander 21 41,496 01-21-2025, 01:09 PM
  Will the Pinecil work for repairing iPods, in particular the 30pin port connector? drewdavis 0 1,806 08-27-2024, 08:01 PM
Last Post: drewdavis
Exclamation What is this - Pinecil V3? andrea6 2 16,918 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 3,522 09-23-2022, 03:47 AM
  Just got my Pinecil donwynne 1 3,677 04-22-2022, 07:01 AM
Last Post: bbeeast
  Pinecil Broken? skaaq 4 11,210 01-25-2021, 11:28 AM
Last Post: skaaq
  Pinecil stuck in shipping? mbreese 3 8,478 01-07-2021, 07:46 AM
Last Post: moxx
  Pinecil - Tip Disconnected molzy 2 8,629 01-03-2021, 07:21 AM
Last Post: molzy
