bookworm vs trixie discussion for mobian in pinephone regular.
#41
The problem with audio went away about two weeks ago, no freeze, it's so much better now in my daily use Smile
By the way, I use the headset "beats studio 3", the bluetooth coupling is a bit cumbersome but it works when you play the test sound once very soon after the connection.
Does anybody know how to turn off in trixie the flashlight notification which is triggered by not answering a phone call?
(11-27-2024, 10:39 AM)fernando_c_m Wrote: Does anybody know how to turn off  in trixie the flashlight notification which is triggered by not answering a phone call?
You can simply turn on and off the flashlight as a workaround, it used to work for a long time but today it doesn't Huh
That is what I do. But if you are not aware of it (phone in the pocket) the battery will be most likely empty by the time you realise. There must be a way of disabling it for good.
Hello
The screen remains black after a rotation when the terminal is maximized, it's often reproducible. This regression appeared about two days ago after an important upgrade. It's very annoying as I have to use this feature to work around the problem with my dying screen to type some letters. It's like a good comedy sketch, I have to keep my dock and an USB mouse on me in order to be able to turn on my phone anew after a crash...
I had to change an udev rule anew to avoid frequent loss of connectivity.
Sending SMS in Chatty by pressing Enter helps me to work around my dying screen too Smile
By the way, you can work around the regression I mentioned by going back to the home screen before rotating.
P.S: Bluetooth is broken too, no device is detected.
Hello
I no longer have a freeze when rotating even when I maximize the console since yesterday evening. The lack of Bluetooth remains.
Is megapixels broken on trixie for you?
Failed to initialize OpenGL context: Unable to create a GL context
Couldn't find current GLX or EGL context.
Aborted
friends; please  sudo apt install  stellarium  and run  stellarium  from terminal.   Does it start?       Please share output  of  terminal command   glxinfo
(03-07-2025, 05:04 PM)dragonhospital Wrote: Is megapixels broken on trixie for you?
Aborted
Yes it's broken for me too, I noticed that Saturday April 3rd 2025.
That is because they (Debian trixie) upgraded their GTK to 4.18. You need a GTK patched with the patches from https://github.com/kkofler/gtk.
  Mobian MMS/SMS text problem bcnaz 16 37,662 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,492 04-27-2026, 09:57 AM
Last Post: Korfou
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,062 12-23-2025, 04:34 AM
  camera not usable with trixie? JChdeL 0 965 12-05-2025, 01:45 AM
Last Post: JChdeL
  trixie update poll questions suggestions j_s 5 2,642 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 71,679 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,231 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 336,442 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 2,914 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,985 06-07-2025, 03:19 PM
