03-24-2025, 01:13 PM
Sim card network is registered i cannot make calls modem is enabled
Cannot make calls
03-25-2025, 10:31 AM
maybe you should try those basics first. update pmos to the latest packages.
i think tha commands were: Code: $ sudo apk update
$ sudo apk upgrade
## then reboot
03-26-2025, 04:55 AM
(03-24-2025, 01:13 PM)neithan76 Wrote: Sim card network is registered i cannot make calls modem is enabled As above check you are updated. Also, during boot is the modem found (especially at about 45 seconds)? Code: pmos:~$ sudo dmesg | grep "usb 2-1"
[ 45.632360] usb 2-1: new high-speed USB device number 3 using ehci-platform
[ 45.792522] usb 2-1: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18
[ 45.792567] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 45.792583] usb 2-1: Product: LTE Module
[ 45.792591] usb 2-1: Manufacturer: Quectel, Incorporated
[ 45.792605] usb 2-1: SerialNumber: community_fw
[ 45.869827] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 45.871254] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 45.873156] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 45.874451] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3And registering - what is output from Modem, Modem Info menu option? You should see IMEI, Operator details etc?
07-01-2025, 09:39 AM
(03-24-2025, 01:13 PM)neithan76 Wrote: Sim card network is registered i cannot make calls modem is enabled I'm assuming that you changed from Manjaro, because the pphone crashed after making calls. I am having no problem making and receiving calls, using PostmarketOS, however after not using the pphone for a few hours, the modem disappears and I have to reboot. I installed the software at The Modem Distro but that seems to have made no difference but maybe it would in your case? (I'm intrigued that @dukla2000 uses his as a daily driver. I would like to be able to do that.)
PinePhone Beta 2GB/16GB Arch Linux ARM danctnix from3 Oct 2025
(was Postmarket OS v24.12) PineTab2 Arch Danctnix 6.4.2 |
| Cannot send or receive calls | insidetrip101 | 2 | 4,846 |
11-04-2022, 06:47 PM Last Post: mob |
| Calls don't work on Softbank. Cellular data & SMS work. | yasmi | 1 | 3,844 |
03-24-2022, 04:10 AM Last Post: yasmi |
| sxmo image Verizon calls and SMS work! | Saliency | 8 | 15,534 |
08-22-2020, 03:28 AM Last Post: PureTryOut |
| How to make volume and power buttons do things | koampapapa | 3 | 8,847 |
07-31-2020, 12:49 PM Last Post: Boern |
| Making Calls | Zweitaktmotor | 11 | 24,619 |
07-19-2020, 04:59 AM Last Post: PureTryOut |
