Having difficulty installing PostmarketOS on Pinephone Convergence Beta edition
(10-09-2024, 02:29 AM)spazz Wrote: Thanks again Mike!
You are welcome!
unxz JUMPDRIVEIMAGE.img.xz
Over the years, I have seen to many people flash the zipped up image to the phone thinking it will work.
sudo dd if=JUMPDRIVEIMAGE.img of=sdX status=progress
Over the years, I have seen to many people taking this code, doing a copy and paste, and thinking it will work.
Oops.
Apologies. From memory what I wrote is what worked for me. Thought it was based on your video, but perhaps not.
If I have put misinformation, should I delete my previous post (and this one)?
Or modify it?
Don't want to lead anyone in the wrong direction.
I thought unzipping jumpdrive then simply dd'ing jumpdrive to an SD card was the way to go for the first steps.
Anyway, as mentioned, it's a redundant post and doesn't really need to exist.
Thanks.
Mike's comments do not say you wrote something wrong. Quite the opposite, his point is that many users forget the unxz command that your instructions correctly mention, and that many users do not understand what is meant by something like "sdX" and try to copy&paste that instruction verbatim (but that is not really your fault).
I used Etcher to install Tow-Boot. Then I reformatted the SD card and used Etcher to uncompress and flash PostmarketOS to the card. Put the card in the phone and everything worked!
  "USB access to SD" disappeared on a Pinephone Pro jebez 0 596 06-19-2026, 06:40 PM
Last Post: jebez
  what stopped pinephone pro? heocb 1 1,542 01-14-2026, 09:56 AM
  beta release of a Linux mobile app strength training app coryholl 1 2,351 08-29-2025, 06:12 PM
Last Post: coryholl
  PinePhone Pro: Camera App very laggy Martin87 3 5,692 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 14,998 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 3,674 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 2,838 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 4,819 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 3,364 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 3,396 06-29-2025, 11:48 AM
