USB C to USB C charging not working.
hello sorry if this has been answered but i couldnt find the info..my friend gave me his old mobian edition pine phone..it works great exept for it will only charge usb a to usb c and will not charge usb c to usb c...is this hardware firmware or OS? i have pbooted pmos currently running. thank you.
Are you sure your USB-C charging cable is good? The only time I had a problem with USB-C charging on my pinephone was when the cheap cable I bought from eBay went bad.
(08-15-2024, 06:53 AM)Zebulon Walton Wrote: Are you sure your USB-C charging cable is good? The only time I had a problem with USB-C charging on my pinephone was when the cheap cable I bought from eBay went bad.
yes it works on other phones
anyone have any suggestions?
bump...this forum dead?
Quote:Due to design limitation, this charger only work with PinePhone accompany USB-A to USB-C power cable and doesn’t work with USB-C to USB-C cable.
https://pine64.com/product/pinephone-battery-charger/
yes i saw that but this is the battery charger not the actual phone. under the phone it didnt say this.
Can be that same.
You are happy with your new phone?
Please write something about that in separate subject and send link to me.
https://pine64.com/product/usb-type-c-to...er-length/
what? so consensus is pine phone cant charge usb c to usb c?
USB C charging works via a negotiated protocol. Pine devices don't support it. (Some might? I don't know)
The reason you can use a wall wart is that they will send power even if the negotiation fails. Other devices don't (and shouldn't).
:wq
  Detecting when charging and discharging phobios 4 5,264 01-10-2024, 08:06 PM
  PPKB certain keys not working after kernel update ragreenburg 20 33,867 06-11-2023, 03:19 AM
Last Post: lectrode
  FDE installer not working user641 0 2,215 03-04-2023, 02:55 AM
Last Post: user641
  Ringtone not working through external speaker... tk1107 2 5,083 03-13-2022, 11:34 PM
Last Post: tk1107
  wifi not working someGermanGuy 7 17,771 01-20-2021, 10:47 AM
Last Post: Enginerrrd
