A way to view or log the splash screen on Pinephone Pro running ArchLinux (Danctnix)
Good day!
I've been using Pinephone Pro as a daily driver for 7 months now. Mainly with Arch Linux Danctnix OS. Recently, I'm having problems with connecting to the wifi. It can scan available SSIDs but could not connect after a 90 second timeout.
I've tried manually connecting the wifi via nmcli, manually installing the firmware for brcmfmac from github repos and rebuilding the initramfs. But it doesn't seem to fix my problem.
I'm thinking whether this is a hardware problem (given that I charge it with a 5v:3000ma charger overnight) or a software problem (since I usually update with yay first then sudo pacman -Syu. The updates could've messed with the firmware.)
SInce I use the phone almost always for online activities, I can't use it and I usually reboot it often following the wifi connectivity error. While doing so, I read something in the splash screen at boot-time stating something along the lines of "Failed to read chip id 258" Hopefully anyone here could point me to a way to log or view the messages at the splash screen, or a more appropriate forum or discussion board to bring up my concern.
Help a bro out, links or advice would be greatly appreciated.
(07-29-2024, 06:26 AM)PHLEMON Wrote: Help a bro out, links or advice would be greatly appreciated.
Thank you for providing OS.
I currently have no issues connecting to WiFi or creating a hot spot for my laptop.
I do remember a long time ago that I got duplicate connections on nmcli that were stepping on one another.
run command
nmcli connection show
Device: PinePhonePro (Daily driver)
OS: DanctNIX Arch with Phosh
(07-29-2024, 12:04 PM)mikehenson Wrote: I do remember a long time ago that I got duplicate connections on nmcli that were stepping on one another.
run command
Thanks for this man, was able to see the different UUIDs for each saved networks. However, nothing appeared as duplicates even after 'nmcli con delete UUID' and reconnecting.
I was able to view the splash screen by crudely taking a video of my PPP at boot-up using my other phone. The error showed up to be "ov8850 1-0036: Failed to read reg 208906: -6" "Probe with driver: driver imx258 failed with error -5. or failed to read chip id 258" both ov8850 and imx258 turns out to be the driver for the camera modules of the PPP which is unrelated to my concern.
I think these logs would be relevant:
Upon "sudo dmesg | grep -i sdio"
Output:
[ 6.653028] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.pine64,pinephone-pro.bin failed with error -2
Upon "sudo journalctl -u NetworkManager -f"
Output:
Jul 29 01:54:28 danctnix NetworkManager[3797]: <info> [1722189268.9366] device (wlan0): supplicant interface state: scanning -> associating
Jul 29 01:54:28 danctnix NetworkManager[3797]: <info> [1722189268.9368] device (p2p-dev-wlan0): supplicant management interface state: scanning -> associating
Jul 29 01:54:29 danctnix NetworkManager[3797]: <info> [1722189269.0558] device (wlan0): supplicant interface state: associating -> disconnected
Jul 29 01:54:29 danctnix NetworkManager[3797]: <info> [1722189269.0561] device (p2p-dev-wlan0): supplicant management interface state: associating -> disconnected
Jul 29 01:54:29 danctnix NetworkManager[3797]: <warn> [1722189269.4720] device (wlan0): Activation: (wifi) association took too long
Jul 29 01:54:29 danctnix NetworkManager[3797]: <info> [1722189269.4723] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jul 29 01:54:29 danctnix NetworkManager[3797]: <warn> [1722189269.4747] device (wlan0): Activation: (wifi) asking for new secrets
Upon "sudo dmesg | grep -i brcmfmac"
Output:
[ 7.041425] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.082935] usbcore: registered new interface driver brcmfmac [ 7.236643] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[ 7.238651] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
[ 12.117766] brcmfmac: brcmf_set_channel: set chanspec 0x100c fail, reason -52
[ 12.126424] brcmfmac: brcmf_set_channel: set chanspec 0x100d fail, reason -52
[ 12.135012] brcmfmac: brcmf_set_channel: set chanspec 0x100e fail, reason -52
and so on... repeating the "chanspec fail, reason -52"
Upon "sudo modprobe -r brcmfmac && sudo modprobe brcmfmac"
Output:
modprobe: FATAL: Module brcmfmac is in use.
I'll try looking for other solutions specifically on chanspec reason -52 (Although I don't see this issue happening on PPP but on Raspberry Pis)
Hopefully you know something about this. But if all fails, I might go reinstalling the OS.
(07-30-2024, 08:11 AM)PHLEMON Wrote: Hopefully you know something about this. But if all fails, I might go reinstalling the OS.[/size][/color]
I just did a full update of arch (2024 July 30) and I got the same issue as you.
Downgrading wpa_supplicant to 2.10 and restarting the phone worked for me
From another post, some said to downgrade the wpa_supplicant package.
wpa_supplicant was just updated on July 20[1] to 2:2.11
you can download wpa_supplicant 2:2.10 here[2]
if you are lazy, here are the commands you will need to run on the phone.
cd Downloads
wget http://tardis.tiny-vps.com/aarm/repos/2024/06/11/aarch64/core/wpa_supplicant-2%3A2.10-8-aarch64.pkg.tar.xz
wget http://tardis.tiny-vps.com/aarm/repos/2024/06/11/aarch64/core/wpa_supplicant-2%3A2.10-8-aarch64.pkg.tar.xz.sig
sudo pacman -U wpa_supplicant-2\:2.10-8-aarch64.pkg.tar.xz
sudo reboot
[1] https://w1.fi/releases/
[2] http://tardis.tiny-vps.com/aarm/repos/20...ch64/core/
**THIS MAY NOT BE THE CORRECT FIX**
(07-30-2024, 06:55 PM)mikehenson Wrote: I just did a full update of arch (2024 July 30) and I got the same issue as you.
Issue solved, thank you for your time, sir!
This saved me a lot of hassle. I will consider downgrading software packages the next time I encounter a similar issue.
  what stopped pinephone pro? heocb 1 788 01-14-2026, 09:56 AM
  PinePhone Pro: Camera App very laggy Martin87 3 4,829 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 10,737 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 2,650 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 2,033 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 3,478 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 2,444 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 2,449 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 1,651 06-26-2025, 11:47 AM
Last Post: zetabeta
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 14,259 03-13-2025, 08:40 PM
Last Post: pcb
