New PinePhone Pro fails...
I have a PinePhone for three years and it still functions well. The battery is now doing less well, but it is still doable with a simple power bank. In addition, there is no damage and the screen does not have a single scratch.
Now I have a PinePhone Pro for a week, but after a few days it stopped working on the phone and sound. The SIM card works properly, so it is something with the software or hardware. In addition, the battery drains quite quickly.
What operating system are you using?
(07-21-2024, 12:00 PM)mikehenson Wrote: What operating system are you using?
Postmarket OS.
(07-21-2024, 06:10 AM)P. Siera Wrote: Now I have a PinePhone Pro for a week, but after a few days it stopped working on the phone and sound. The SIM card works properly, so it is something with the software or hardware. In addition, the battery drains quite quickly.
I never used Postmarket OS. I have read many great things about it. I personally use Arch with Phosh.
What applications have you installed? Like waydroid?
Did you manage to set/unset the default sleep time?
Battery Life for my PinePhone Pro:
In suspend mode, the battery drops maybe 10% per 4 hours.
With screen ON and texting or emailing, it drops maybe 15% per hour.
Have you tried replacing the battery with a new one? Batteries don't hold a charge as well as they get older. It could be that you're on the tail end of the useful lifetime of that battery you have.
The new PPP has a new battery!
  PinePhone Pro: Camera App very laggy Martin87 3 4,281 08-22-2025, 11:23 PM
Last Post: teekay
  PinePhone Pro discontinued teekay 9 7,254 08-22-2025, 11:19 PM
Last Post: teekay
Exclamation Pinephone Pro wont boot to anything! Supervisor 5 1,945 08-18-2025, 06:15 PM
  Pinephone pro ee bricked? dennylee 3 1,511 07-22-2025, 12:06 AM
Last Post: Dendrocalamus64
  Full desktop Surfing and Absolute Privacy on the pinephone? Www 8 2,596 06-30-2025, 10:51 AM
  Backing up data on Pinephone Pro to hard disk, optical disk and flash? Www 4 1,788 06-29-2025, 02:46 PM
  Printing and scanning documents with pinephone? Www 4 1,786 06-29-2025, 11:48 AM
  FM? A future new PinePhone? jebez 1 1,263 06-26-2025, 11:47 AM
Last Post: zetabeta
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 8 12,452 03-13-2025, 08:40 PM
Last Post: pcb
  New PinePhone Pro. No sudo command or access to root password. DanNewman 4 2,910 03-01-2025, 06:38 PM
