USB Wireless Drivers with Longsleep Linux Kernel
(06-12-2016, 01:41 AM)longsleep Wrote: Kernel headers are in /usr/src/linux-headers-...
Okay, thanks for the help with that.  So using --kernelsourcedir=/usr/src/linux-headers..... I get farther but still not all the way.
I've uploaded an image with the process on it, there are a few bad exit statuses before it finally stops with an error of not finding a file.
[Image: dkms-build.jpg]
It seems that this driver I'm trying to install just either isn't finding the files it wants, or the symlinks it is expecting to be there aren't.  Should I move on from this and get a wifi dongle you already have a driver installed for? Do you have any wifi dongle suggestions?
I just used a vanilla debian distro with longsleep 101 kernel and did a 'sudo apt-get install linux-firmware'. It got my NetGear USB wifi dongle and my old dlink dongle running after a reboot. Did you try it?
Unless you have a very close relationship with your current linux-installation, you might want to consider reimaging the microsd-card with a current debian build and use the scripts in /usr/local/sbin to update uboot and kernel first, enlarge sd-card and then do a 'sudo apt-get update' before you install linux-firmware package.
It takes about an hour if you have a decent broadband connection (mine is 30/10 and it took 50 minutes).
(06-14-2016, 03:37 PM)CaptainZalo Wrote: I just used a vanilla debian distro with longsleep 101 kernel and did a 'sudo apt-get install linux-firmware'. It got my NetGear USB wifi dongle and my old dlink dongle running after a reboot. Did you try it?
Thanks Zalo. I might just do that. Sorry if this is a silly question, is the Debian distro headless or does it have the GUI? I like the headless distros and was hoping to stay with that.
I downloaded a tiny distro (Debian Base (3.10.65 BSP) from here @ only about 180 megs) and got just what I wanted - a GUI-less working Debian that I could customize as I wanted. The Mate Desktop Environment downloads and installs was the slow part. The rest worked as intended. Shellscripts and all.
In case anyone runs into this issue like me, i have managed to get this to work with lwfinger/rtl8188eu driver
You can read up on this here:
https://medium.com/@daniel.cohen/setting...41def83c75
(03-02-2019, 06:32 AM)dcohenb Wrote: In case anyone runs into this issue like me, i have managed to get this to work with lwfinger/rtl8188eu driver
Thanks on the post :-)
  +LTS/SOPINE Compilation procedure for U-Boot and Linux for pineA64 LTS. danpurprakash@gmail.com 1 6,835 06-05-2019, 11:50 PM
Last Post: igorp
  Frustrations with Wifi, VNC, Longsleep, etc. NexusDude 1 6,468 06-05-2019, 11:43 PM
Last Post: igorp
  Pine Board using linux stuck during boot sequence ktaragorn 0 5,051 03-23-2019, 04:06 AM
Last Post: ktaragorn
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,758 04-16-2018, 03:09 PM
Last Post: Rocklobster
Question Mali driver on linux? jamiechang917 8 18,779 03-04-2018, 03:01 PM
Last Post: Brian Beuken
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 926,580 01-31-2018, 11:58 AM
Last Post: Luke
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 5,999 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  config error installing XML-RPC on longsleep Ubuntu tinkertom 2 7,509 02-22-2017, 06:50 AM
  linux mint fra0hf 9 17,280 10-29-2016, 11:41 AM
Last Post: jkmooney
Rainbow Ubuntu with Android Kernel JasperBrown 5 12,519 07-05-2016, 06:49 AM
Last Post: xalius
