Android Images (ROCK64)
#71
>>http://files.pine64.org/os/ROCK64/android/ROCK64_dd_20190621_stock_rooted_android_9.0_sdboot-64GB.img.gz
are these images also compatible with rockpro64 ?
(08-03-2020, 02:20 PM)seaurchin Wrote: >>http://files.pine64.org/os/ROCK64/android/ROCK64_dd_20190621_stock_rooted_android_9.0_sdboot-64GB.img.gz
Most likely not. For RockPro Android images, check the wiki page or subforum for that board.
This is the thread i was searching for, cool
Will the MT7601U wi-fi adapter work?
Where can I still download the android images? 9 doesn't work from the Wiki.
(05-09-2024, 02:40 PM)Blackheat45 Wrote: Where can I still download the android images? 9 doesn't work from the Wiki.
Hi, Were you able to find the Android Images else where?
I contacted support to see if I could get it, they just said to wait until June sometime, and hopefully the links on the wiki would be working again.
But If someone can provide me with a rooted image of AndroidTV 9 for the Rock64, I would be very appreciative.
Try to get the image up on this week, please visit wiki page on next week.
https://wiki.pine64.org/wiki/ROCK64_Soft...es#Android links seem to be working - at least the Android 9 / TV 64GB links.
I am curious why the Android TV 9 links are only for eMMC while Android 9 links are only for sdcard?
  rock64-android10-tv patchset for Firely AlexS 1 672 09-08-2026, 10:49 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,412 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,693 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,862 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,862 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,565 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,736 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,386 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,667 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,026 09-18-2020, 07:58 PM
Last Post: BowerR64
